POV-Ray : Newsgroups : povray.programming : POV Plug-ins (was Re: pov to moray conversions: possible?) Server Time
10 Oct 2026 08:48:21 EDT (-0400)
  POV Plug-ins (was Re: pov to moray conversions: possible?) (Message 1 to 8 of 8)
Subject: POV Plug-ins (was Re: pov to moray conversions: possible?)
Date: 19 Mar 2000 01:56:59
Message: <38d47a3b$1@news.povray.org>
What if full plug-in support was added to POV-Ray?  Then something like this
would probably be possible.
This message brought to you by:
-=< Ian (the### [at] hotmailcom >=-
Please visit my site at http://spectere2000.cjb.net! :)
ryan constantine <rco### [at] yahoocom> wrote in message
news:38D15FCC.81CF80F3@yahoo.com...
> is there a way to convert pov and inc files into moray?  or is there a
> utility that allows one to search through pov and inc files for an
> object and import it into moray?  it seems to me that if moray can go
> from moray to pov, it should be able to go the other way as well.  does
> it?  how?
Subject: Re: POV Plug-ins (was Re: pov to moray conversions: possible?)
Date: 19 Mar 2000 05:56:19
Message: <ko=UOEv6av1Fa0MKuimmJTG93LxX@4ax.com>
On Sun, 19 Mar 2000 01:50:28 -0500, "Ian Burgmyer"
You do realise the difficulties with developing a cross-platform
plug-in architecture, don't you? Besides, plug-ins are somewhat
prohibited by POVLEGAL at this stage. They can easily be used to abuse
the hard work of the team.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 19 Mar 2000 06:13:04
Message: <38d4b640$1@news.povray.org>
Peter Popov <pet### [at] usanet> wrote in message
news:ko=UOEv6av1Fa0MKuimmJTG93LxX@4ax.com...
this
Yeah, you're right.  Then again, there's an interpreted language.  But good
luck writing an import/export plugin :)
Oh.  Okay.
How?  All it would be is a module adding to the existing code, even if a
cross-platform binary were possible.
Also, what would be the use of cross-platform plugins?  For instance, a file
export/import plugin would likely only be useful for that specific OS.
Exporting Moray files, for instance, on a Linux version of POV-Ray would be
a waste of time.
Date: 19 Mar 2000 09:39:18
Message: <chrishuff_99-92A0F1.09411919032000@news.povray.org>
In article <38d4b640$1@news.povray.org>, "Ian Burgmyer"
You mean a language you could write plugins in and then refer to their
files from a scene file?
Sounds a lot like POV-Script and include files, doesn't it?
But that module could do just about anything once it is called, unless
it is written in an interpreted language, in which case we already have
the "plugin" feature.
> a file export/import plugin would likely only be useful for that
> specific OS. Exporting Moray files, for instance, on a Linux version
> of POV-Ray would be a waste of time.
Most people think of plugins as doing the same things that include files
and macros do now. And I don't see how they would be very useful
otherwise...remove that one part and you don't have much left. I doubt
that import/export plugins will represent a large portion of their use.
If there was a way to make a cross platform plugin that was called from
POV script by object notation, like this:
PLUGIN_NAME {PARAMETERS, OBJECT MODIFIERS}
it would be very useful.
It could be made to use POV-Script, but that would make it nearly
impossible to write things like import/export plugins. Maybe a kind of
macro, "plugin_object" or something(I can't think of anything better at
the moment), which would make a new "plugin" when #declared.
Something like this:
// START PLUGIN INCLUDE FILE
#declare Tree =
plugin_object {
    parameters {RecuseDepth, Branches, BranchAngle}
    // POV-Script that does whatever the plugin is supposed to do
// END PLUGIN INCLUDE FILE
// START SCENE FILE
Tree {
    RecurseDepth 5
    Branches 2
    BranchAngle 30
// END SCENE FILE
Or maybe it could be declared with something more like macro notation:
#plugin_object PLUGIN_NAME(PARAMETERS)
Only the way it is called would be different.
Just a jumble of random, half-finished, caffeine deprived thoughts. I'm
going to get some coffee now...
Chris Huff
e-mail: chr### [at] yahoocom
Date: 19 Mar 2000 20:25:37
Message: <38d57e11@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote in message
news:chrishuff_99-92A0F1.09411919032000@news.povray.org...
I mean something like import/export plugins.
Not if someone wanted an export plugin.
We have that already.  #macro
Or did you mean something more interactive, flexible or more complex?
Caffeine. . .haven't had any all day.  Thanks for reminding me!  *runs down
and grabs an RC*
Date: 19 Mar 2000 20:37:10
Message: <38D57FED.4B8B56EC@pacbell.net>
I don't think you fully understand the technical details
involved with writing such a plugin for POV-Ray even if
POV-Ray offered a plugin architecture.
Date: 19 Mar 2000 20:38:43
Message: <chrishuff_99-C0BC70.20404419032000@news.povray.org>
In article <38d57e11@news.povray.org>, "Ian Burgmyer"
We already have an interpreted language, do you want another one?
Specifically for export plugins?
How do you want these things to work? Would they be accessed from the
scene file or the .ini file, or would they be part of the
platform-specific portion of the program?
Actually, what I mean is basically macros that can be called with the
object syntax. So you do MyObject {Position VALUE} instead of
MakeObject(VALUE). Or ExportToWhatever{OBJECTS}
Chris Huff
Date: 22 Mar 2000 00:06:35
Message: <38d854db$1@news.povray.org>
news:chrishuff_99-C0BC70.20404419032000@news.povray.org...
That's what I was thinking. . .something platform specific.  For instance,
it would be totally illogical to put Moray support in the Macintosh version.
Yes, that would be very nice.  I constantly mix it up :)
