Has anyone tried to compile a version of pov which works as a Win32 console
application? I am trying to do so at the moment with the Unix source code,
but am running into problems with unix.c.
Also: Has anyone yet made PVMPov work with Windows? I know there is a
version of PVM for windows and suggestions that it is easy to do, but have
not seen any results yet. That is why I am trying to make the console app, I
figure the slaves dont need a GUI.
You can probably safely leave unix.c out of the mix. The other thing you'll
have to do is edit config.h to not have any Unix-specific stuff in it - it's
best to start with the "unix" target rather than the "svga" or "xwin" targets
in this pursuit, as it should already be fairly generic.
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
I do not want to burst your bubble, but: within the last 8 months I got
about 4 mails from different people, which told that they would do the
win32-port of PVMPOV. After all there wasn't anybody, successfully
porting PVMPOV to win32.
I'd look forward to your PVMPOV port to win32, Chris
- Jakob Flierl
Yay! I got it to work! Except...
It doesnt read povray.ini
it doesnt use a "precision timer" (whatever that is)
it doesnt read environment vars
but at least it compiles and traces!
And I got rid of 607 warnings with a simple #define float double
Still trying with pvm.
Chris Jeppesen <chr### [at] digiquill com> wrote in message
news:3820055d@news.povray.org...
console
I
In article <3820f651@news.povray.org> , "Chris Jeppesen"
I presume you are using Visual C? Just tell it to ignore the possible loss
of "data" warning. Basically the warning is nonsense (it is a _wanted_
lowering of _precision_) and by forcing float to be double you just make
rendering slower. If you dig in the online help you will find where the
option to manually deactivate single warnings is (I don't remember the
option right now, sorry).
Thorsten
>of "data" warning.
To do this, add one or more of the lines below to the appropriate place
in config.h.
/* disable truncation warning */
#pragma warning(disable: 4305)
/* disable precision warning */
#pragma warning(disable: 4244)
/* disable signed/unsigned warning */
#pragma warning(disable: 4018)
> >of "data" warning.
> in config.h.
Just note that this will hide the problem, but is not a really good solution
engineering-wise. Especially 4018.
But, there's not a simple fix, since most of those come up due to the use of
macros. It might take a lot of engineering effort to correct all those in a
manner that is cross-platform and also "correct". In POV_Ray, most of the
precision and truncation warnings are due to known conversions that are
desired, thus the warnings are less important (just remember that I said "most"
and not "all possible"). Of course, any new code writen will be nice and clean
and not have any of this, right? :-)
Go ahead and put on the band-aid, but remember that it is such.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Oh, absolutely. And I don't actually disable any of them in my own
code, either, but fixing them is fairly impractical.
> and by forcing float to be double you just make rendering slower.
That's not true. By amazing coincidence, the FPU (at least for intel arch)
is the same size as a Visual C++ double. So if your code is using floats,
they have to be converted to doubles before stuffing in the FPU (and
converted back to float on the way out of the FPU). So you lose precision
and take a performance hit by using floats.
No comment on the #define float double solution though. ;)
It's also interesting that since the '486, FPU mul/div is faster than
integer mul/div.
_,--"
dik `-._ ________-_______ "----
_----'--'--------------------------------'--'----_
//_| | \ dic### [at] buckosoft com / | |_\\
(_____|_|__= Guilford CT +1.203.458.0389 =__|_|_____)
_\_____=___ http://www.buckosoft.com ___=_____/_
\/-(o)-~~-(o)-~~-(o)-`------'-(o)-~~-(o)-~~-(o)-\/
Early Net Poetry:
Wustl, Wustl, ERR RIP MIT BOOT, BIND Wustl
Not really. FLD with a 32-bit real operand is 20 clocks, as opposed to the
64-bit version at 25 clocks. FST is 44 vs. 45 clocks. FMUL is 27-35 clocks
for a float, or 32-57 for a double. FDIV is 89 or 94. So floats are faster,
under ideal conditions, but not by any significant amount. (This data is for
the 386. Other processors vary, of course. Intel no longer seems to publish
this data, for the obvious reason that pipelining and other optimizations
make it useless.)
In article <383ADE3C.61F2BC9E@buckosoft.com> , Dick Balaska
That is wrong! There is no time for conversion required, as it is a trivial
to "cut off" the exponent (reduce it from 11 to 8 bit) and the significant
(reducing it from 52 to 23 bit) when loading/storing them.
As a matter of fact, internally all current processors store floating-point
numbers as if they were doubles (or whatever other most precise internal
format they support). When performing the calculation as single-precision,
the other bits are just not taken into account.
Thorsten
Ron Parker wrote:
Comments a little bit from back top front:
>(This data is for
And as such it is of no value. Who has a 386?
I know something like FMUL taking (if the pipelines are full) arount
1/3 clock. Double floating points are indeed a lot faster than integers.
Markus
Der deutsche Schlager ist aus dem Klofenster gesprungen....
It is a little more curious still. You can force an Intel FPU to work
in several precision modes (32, 64, 80). There are differences in the
total # of clocks from beginning to end based on how much data needs to
be pushed onto the FPU stack and the precision you run the FPU.
A secondary consideration is that with the tiny on chip cache of the
Intel chips, using larger data sizes (8 byte doubles) will cause misses
more often than using 4 byte singles. When this happens you get a huge
performance hit.
Understanding and programming around these types of things is very
important to games programmers and real time sim packages. It is also
quite platform dependent.
Xander
On Wed, 24 Nov 1999 10:20:47 +0100, Markus Becker wrote:
>>(This data is for
But try getting any information on instruction timings from Intel these
days. I checked both the PII and PIII reference manuals and they've dropped
that sort of information.
> Markus
I just wonder when some nongerman will ask you about your sig
<bg>
Marc
Marc Schimmler
the
clocks
faster,
for
publish
> make it useless.)
But if you want to look anyway, I think Ralf Brown's Interrupt List
(http://www.pobox.com/~ralf) has the data.
I'm hoping for it. We had some good laughs already in our institute....
> <bg>
<veg>
BTW, this is not my courtesy, I found it on the last page of the
"SPIEGEL"
(Hohlspiegel), originally it was a headline in the "Zeit".
Markus
You can download the developer pack from Intel (is it still free?) and
especially VTune, which will clear show you how much cycles your machine
instructions take and how the pipelines will be filled.
And you can alway try to time it for yourself.
Markus
> > <bg>
> <veg>
> "SPIEGEL"
As subscribed reader of the SPIEGEL I certainly know that one! :-)
Now cm'on people ask! <vbg>
Marc
Marc Schimmler
Well ?
Ken Tyler - 1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Ron Parker <ron### [at] povray org> wrote:
: Not really. FLD with a 32-bit real operand is 20 clocks, as opposed to the
: 64-bit version at 25 clocks. FST is 44 vs. 45 clocks. FMUL is 27-35 clocks
: for a float, or 32-57 for a double. FDIV is 89 or 94. So floats are faster,
: under ideal conditions, but not by any significant amount. (This data is for
: the 386. Other processors vary, of course. Intel no longer seems to publish
: this data, for the obvious reason that pipelining and other optimizations
: make it useless.)
As someone already said, this is not true anymore for pentium-class
processors.
In a plain pentium (if I remember right) the fld takes about 6 clocks
and fst about 3 (for both float and double) and fmul takes 1 clock (amazingly)
in most cases.
In a P-II it's even faster.
On the other hand, all values are internally converted to 80 bits floating
numbers by the FPU (this is usually the long double type in C compilers for
PC). However, it's not faster to use the long double type. Double is faster.
>: make it useless.)
>processors.
>in most cases.
Y'all seem to be missing the point. My point was that it is not true that
there is a conversion penalty for using 32-bit floats on Intel x86 processors,
and that that has been true since at least the 387. Whether later processors
made the difference smaller or nonexistent is irrelevant: even when there was a
penalty, it favored using floats over doubles rather than the other way around
as stated, and even then it was really small (5 clocks on a 33-MHz 387 is 150ns.
It takes millions of FLDs - even on a 387 - before that even comes close to
taking measurably more or less time.)
In article <383BD96F.47668841@mitre.org> , Alexander Enzmann
Well, that is true up to the 486 (and maybe Pentium). As all current x86
processors translate instructions internally, there is bottleneck between
the FPU and its registers.
> performance hit.
Yes, this will happen when using old code or compilers that don't support
proper alignment. Usually cache row sizes are 16 or 32 bytes and a processor
will always fetch a complete row anyway.
Of course you will see a performance hit if your data really takes up large
parts of the caches.
However, I have tried to define DBL as float on a Mac (PowerPC) and could
not find any significant speed increase for large scenes, for example Anton
Raves' Lego scene heli_3.pov takes 79 s with DBL as double and 76 s with DBL
as float (using radiosity and anti-aliasing). That makes only four percent
speed increase, other scenes I tried didn't even show that much at all.
So I guess POV-Ray does not suffer that much from "DBL size". Its memory
access bottlenecks are probably somewhere else.
Yes, and then those four percent would matter!
Thorsten
e-mail: tho### [at] trf de
> Well ?
Hmm, well, not easy to translate, but I'll try. A little bit of
background.
German songs that go well in germany are called "Schlager", you could
translate it as "hit". One of our most beloved "Schlager"-singers,
called
Rex Gildo, commited suicide one of the last weeks. He jumped out of the
toilet window while some reporters where waiting in another room.
Literally it would mean: "The german hit has jumped out of the toilet
window".
You didn't laugh? I knew it!
Markus
I guess I would have had to be there :)
