POV-Ray : Newsgroups : povray.programming : C vs. C++ Server Time
10 Oct 2026 13:45:57 EDT (-0400)
  C vs. C++ (Message 1 to 6 of 6)
Subject: C vs. C++
Date: 29 Jun 1999 16:28:52
Message: <37792C41.D71285EF@pacbell.net>
I know that the windows version of 3.1 has been compiled using
msvc6 a C++ compiler. Pov has traditionaly been written in C. Has
the code all been changed to C++ or does the current windows version
only have the distinction of being a program written in C and compiled
with a C++ compiler ?
Does any of that make any sense ?
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: C vs. C++
Date: 29 Jun 1999 17:45:15
Message: <37793e6b@news.povray.org>
It's still written in C.  VC6, like most C++ compilers, is quite capable
of falling back on a C grammar when confronted with C source, and that is
exactly what it does.  So what you have is a C program compiled with a
C compiler.
Date: 30 Jun 1999 03:59:37
Message: <3779CE4A.3DB929C8@buckosoft.com>
> C compiler.
Actually, they are different compilers.  If you have a file foo.c, it will
use the C compiler. foo.cpp (or foo.cxx) uses the c++ compiler.
The M$ C compiler has been stable for several years and generates descent
code.  The C++ compiler is fairly buggy.  You can get different bugs
by tweaking the optimizations.  Neither devstudio/VC++6 service pack
addressed a single compiler/code generation bug. (Mostly dll tweaks so
you can play on the same machine as Office2000/IE5)
dik
Date: 30 Jun 1999 06:30:06
Message: <3779f1ae@news.povray.org>
This is true. Moreover, if you want to call a C-function from C++-code,
you have to declare the function as: extern "C" foo bar(); (because the
internal naming convention is different for C and C++).
  Btw, how do I call a C++ function from C?
Date: 30 Jun 1999 10:26:36
Message: <377a291c@news.povray.org>
>> C compiler.
They're the same executable.  Go to a command prompt and type cl /? and
you'll get, among other things, this:
/Tc<source file> compile file as .c
/Tp<source file> compile file as .cpp
/TC compile all files as .c
/TP compile all files as .cpp
The C compiler has only been stable for "several years" if your definition
of the term allows for the interpretation "a little over a year."  Everyone
here remembers how VC5 (without the service packs) couldn't compile
lighting.c with global optimizations turned on because cl would get stuck
in an infinite loop.
Reading the readme that comes with VC6 SP3 tells me the following issues
that were fixed and were compiler/optimizer/linker bugs:
Q187280  Q192539  Q194615  Q195376  Q199736  Q205681  Q216181  Q216720
Q216727  Q216715  Q216716  Q216718  Q216722  Q216731  Q216747  Q216854
Q217033  Q195377  Q217171  Q217168  Q217164  Q217755  Q218611  Q218613
And that's just the bugs fixed between SP2 and SP3.  There are similar
lists for the other service packs, but I no longer have them at hand.
Date: 30 Jun 1999 10:36:37
Message: <377a2b75@news.povray.org>
Assuming you mean a global or static method that doesn't take reference
or class parameters, which is to say one that you can actually call from C,
just mark the prototypes as extern "C":
#ifdef __cplusplus
  extern "C" {
#endif
    int myfunc1( int, char );
#ifdef __cplusplus
#endif
You may have to write stubs to call static methods.
If you can't change the C++ code, you're still okay.  You can write a C++
wrapper that consists entirely of stub "C" functions that call the name-
mangled C++ versions.
