POV-Ray : Newsgroups : povray.programming : Y2K Server Time
10 Oct 2026 13:46:45 EDT (-0400)
  Y2K (Message 1 to 28 of 28)
Subject: Y2K
Date: 19 Jun 1999 02:39:42
Message: <376b3b2e@news.povray.org>
Is POV-Ray Y2K compliant?  For example, if, using POV-Ray for Windows, I
start a rendering on New Year's Eve, will it be successfully rendered if
rendering continues past midnight?
Mark
Subject: Re: Y2K
Date: 19 Jun 1999 05:13:29
Message: <376B5D8B.61FC3D9E@aol.com>
Hmm, why not set your clock to 11:55 PM Dec 31, 1999 and start rendering.
In 5 minutes you'll know.
My guess is POV-Ray doesn't give a rats ass about the date, but I could be
wrong.
-Mike
Subject: Re: Y2K
Date: 19 Jun 1999 11:26:37
Message: <376bb6ad@news.povray.org>
Mark Wagner <mar### [at] gtenet> wrote:
: Is POV-Ray Y2K compliant?  For example, if, using POV-Ray for Windows, I
: start a rendering on New Year's Eve, will it be successfully rendered if
: rendering continues past midnight?
  I'll answer with another question:
  Can you tell me any reason why it shouldn't?
  AFAIK, there's no "if (date(now) < date(before)) StopRendering();" line in
povray.
Subject: Re: Y2K
Date: 19 Jun 1999 18:58:50
Message: <376c20aa@news.povray.org>
Actually, what will happen is that it will cause a huge failure at your
local sewage plant.  You will wind up with 2,000,000 gallons of raw sewage
in your yard (only if you live in Los Angeles ...)  :<)
Jim
Check out my web site  http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights that boggle the mind!
Mark Wagner <mar### [at] gtenet> wrote in message
news:376b3b2e@news.povray.org...
> Mark
Subject: Re: Y2K
Date: 19 Jun 1999 20:55:48
Message: <376C392B.13110C5D@pacbell.net>
> Jim
You forgot to mention this will only occur if the moon is 1/4 full otherwise
it happens in New York City.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Y2K
Date: 20 Jun 1999 00:31:18
Message: <376C6F2F.6D8D@aol.com>
Mark wrote:
> Is POV-Ray Y2K compliant?  For example, if, using POV-Ray for Windows, > Istart a
> if rendering continues past midnight?
Sort of a silly question, actually. What you really should be asking is
whether the OS will freak out (an instant crash simply won't happen no
matter what), or the power will go out (unlikely at this point).
But for a program to be "Y2K-compliant", there first has to be some
reason why it wouldn't be. Anything that works with a date could perhaps
be suspect; but POV is simply a number cruncher, so it doesn't fall into
that category. And typically, date-related programs couldn't crash
either--they'd just cause some screwy result to happen.
This is sort of like asking if a program that adds 2+2 will crash if
your printer suddenly stops working--unless it's using the printer, the
program doesn't care.
Lummox JR
Subject: Re: Y2K
Date: 20 Jun 1999 04:08:42
Message: <376ca18a@news.povray.org>
Lummox JR wrote in message <376### [at] aolcom>...
So POV-Ray might report that the rendering took -36524d 23h 17m 23s to
render.
Mark
Subject: Re: Y2K
Date: 20 Jun 1999 04:27:04
Message: <376ca5d8@news.povray.org>
: So POV-Ray might report that the rendering took -36524d 23h 17m 23s to
: render.
  If povray uses the standard C library function time() it shouldn't.
  From the man page:
DESCRIPTION
  The time() function returns the time in seconds since the Epoch. The Epoch
  is referenced to 00:00:00 CUT (Coordinated Universal Time) 1 Jan 1970.
  As you can see, there's no reference to the current year here.
  Since this counter is usually a 32-bit number, the real problem comes
in 2106 when the counter overflows.
  I think I will not live that long.
Subject: Re: Y2K
Date: 20 Jun 1999 08:02:28
Message: <wnaqnavryffbasnyhaznvygryvnpbz.fdl6kb0.pminews@news.povray.org>
I doubt that the rendering code will be affected. However, the stats may look
funny.
I'd be more worried about Windows.
 /j
Subject: Re: Y2K
Date: 20 Jun 1999 10:33:08
Message: <376CFB88.DA5F0BE8@mailbag.com>
Unless it's storing it as a signed integer, in which case it conks out
in 2038.  I've heard plenty of references to the 2038 problem, which I
may very well live to see.  Then again, I also expect to have migrated
to 64-bit architectures by that time.
Mark Gordon
mtg### [at] povrayorg
Subject: Re: Y2K
Date: 20 Jun 1999 14:45:29
Message: <376D36D3.F3B55ACA@geocities.com>
Or... unless you are running on some older Microsoft stuff. I've seen their calls
documented as working only up to 2035. (Trying to remember if it was in DOS or
Win31 calls). Anyway, I had seen it at some point when the first rumblings of Y2K
were being noticed by people and I was looking into the 2038 problem.
So
2038 = problems for most of the world.
2035 = problems for older MS OS users.
Subject: Re: Y2K
Date: 21 Jun 1999 03:01:02
Message: <376de32e@news.povray.org>
Mark Gordon <mtg### [at] mailbagcom> wrote:
: Then again, I also expect to have migrated
: to 64-bit architectures by that time.
  It took almost 10 years to microsoft to "migrate" to 32 bits and thus to
the majority of users. I seriously think that microsoft will be late again.
  Of course there are alternatives... Hopefully linux will be more popular
than windows at that time.
Subject: Re: Y2K
Date: 22 Jun 1999 19:06:46
Message: <377017A3.7FB4@aol.com>
Well, I doubt we'll have to worry about 2038 for a while.  :)
By then, it's doubtful Windows will exist at all, but rather some
superior successor, probably not made by Microsoft. The whole industry
will be incredibly different, really, so worrying about 2038 right now
isn't a big deal.
Of course, this is analogous to a programmer in 1961 not worrying about
2000, and look where that got us, but the real problem comes from the
1981 and 1991 programmers not worrying about it either. We've got a
little while to put it off, as long as people begin taking care of the
problem before 2020 or so.
In 2038, as in many cases now, it's doubtful anything will be affected
beyond a few mainframes with ancient code.
Kind of ironic, actually; one of my favorite books, David Brin's
"Earth", is set in 2038. If you want a glimpse at what the Web could
become over the course of time, there's the place to look.
Lummox JR
Subject: Re: Y2K
Date: 22 Jun 1999 20:10:23
Message: <377026EB.AF064916@compuserve.com>
The earliest Macintosh models can handle dates up to 2040, and the newer
ones can handle dates up to year 28000 or so. That is a VERY long time.
The Y28K bug. <g>
Subject: Re: Y2K
Date: 22 Jun 1999 22:15:59
Message: <3770435f@news.povray.org>
While I expect 32 bit, UNIX type system clocks to reset seven seconds after
3:14a.m. on Janurary 19th, 2038 - it should be a different story for 64 bit
clocks (which are being implimented as we speak) which should last beyond
the year 290,000,000,000.  I don't think the phrase 'Y290g bug' will take
off though.
Subject: Re: Y2K
Date: 22 Jun 1999 23:21:52
Message: <377051C4.328B469A@pacbell.net>
"Edward C." wrote:
  I don't think the phrase 'Y290g bug' will take off though.
Thank God !!!
Ken Tyler
Subject: Re: Y2K
Date: 23 Jun 1999 00:25:06
Message: <377061a2@news.povray.org>
Edward C. wrote in message <3770435f@news.povray.org>...
>off though.
Just wait!  And wait, and wait, and wait....
Mark
Subject: Re: Y2K
Date: 23 Jun 1999 02:10:33
Message: <376D61D6.BCCBE8F0@bigfoot.com>
Not quite. Just the unix world really. Which is far from being the whole lot.
The following page used to be a pretty good resource in the matter :
http://www.merlyn.demon.co.uk/critdate.htm but it is such a long time since I looked
at it that I'm not sure the link is up to date.
Cheers,
Al.
ANTI SPAM / ANTI ARROSAGE COMMERCIAL :
Pour me répondre, veuillez enlever le Z de mon adresse.
To answer me, please take out the Z from my address.
Subject: Re: Y2K
Date: 23 Jun 1999 19:38:54
Message: <3771700e@news.povray.org>
Oh yeah?  So the moon was 1/4 full a few weeks ago in LA when their Y2K test
resulted in all that raw sewage being strewn about?
Jim
Ken <tyl### [at] pacbellnet> wrote in message
news:376C392B.13110C5D@pacbell.net...
sewage
> > Jim
otherwise
> Ken Tyler
Subject: Re: Y2K
Date: 28 Jun 1999 17:38:16
Message: <3772C0F5.A4D19738@bigfoot.com>
> >off though.
> Mark
Well, given that the expected life span of our solar system is just about 5gig
years and that our whole univers is estimated to be approximately 15 gig years
old, I think we don't have to worry much about the 290gig boundary. Maybe this
should be a good opportunity to change the clock systems in computers and rather
than deal with useless stuff like 290 gig years, let the max be somewhat smaller
(say 20gig) and have a finer grain, dive further into the subdivisions of
seconds and milliseconds.
Cheers,
Al.
Subject: Re: Y2K
Date: 4 Jul 1999 17:09:09
Message: <377FCD92.9D56B83A@giwersworld.org>
	Not compliant. It constantly verifies the scene files. When it
flips to 00 it erases all POV files including itself. Then the
RAM rises up and attacks the CPU.
	The things some people worry about.
<blink>-------please--don't-----------------</blink>
http://www.giwersworld.org/artii/
http://www.giwersworld.org/artiii/
Finally up on 99/06/22 updated 06/30
Download 'us-ascii' (1 KB)
Subject: Re: Y2K
Date: 6 Jul 1999 00:53:27
Message: <37818bc7@news.povray.org>
Matt Giwer wrote in message <377FCD92.9D56B83A@giwersworld.org>...
Oh no!  Whatever can we do to prevent this?  :-)
Mark
Subject: Re: Y2K
Date: 2 Aug 1999 18:28:11
Message: <37a61b7b@news.povray.org>
I would try soaking your CPU in vinegar for the few days leading up to the
new year.  Also, make sure the exp. date on the vinegar is later than Jan 1,
2000.
(Mark, sorry about the personal reply)
news:37818bc7@news.povray.org...
I
if
> Mark
Subject: Re: Y2K
Date: 19 Mar 2000 06:21:25
Message: <38d4b835$1@news.povray.org>
Edward C. <edw### [at] hotmailcom> wrote in message
news:3770435f@news.povray.org...
Hah, think about this.  Unless we do more exploration in space, we're either
going to kill oueselves on earth by screwing with the environment too much,
fry when our sun explodes in what scientists think will be in about five
billion years, or maybe not even be here by the time Y290g rolls around :)
In essence, after we switch to 64-bit, screw any Ywhatever bug ;)
This message brought to you by:
-=< Ian (the### [at] hotmailcom >=-
Please visit my site at http://spectere2000.cjb.net! :)
Subject: Re: Y2K
Date: 20 Mar 2000 00:41:34
Message: <38d5ba0e@news.povray.org>
Ian Burgmyer wrote in message <38d4b835$1@news.povray.org>...
Y not?
Mark
Subject: Re: Y2K
Date: 22 Mar 2000 00:03:49
Message: <38d85435$1@news.povray.org>
news:38d5ba0e@news.povray.org...
> Y not?
Subject: Re: Another never-dying post.
Date: 14 Jun 2000 01:39:02
Message: <39471a76@news.povray.org>
Gotta love em ;-)
Please visit my site at http://www.spectere.com! :-)
"Mark Wagner" <mar### [at] gtenet> wrote in message
> Mark
Date: 15 Jun 2000 00:42:08
Message: <39485ea0@news.povray.org>
Ian Burgmyer wrote in message <39471a76@news.povray.org>...
>Gotta love em ;-)
Don't worry, this one only has another year to go.
Mark
