POV-Ray : Newsgroups : povray.programming : knowledge extraction from povray Server Time
13 Oct 2025 08:23:40 EDT (-0400)
  knowledge extraction from povray (Message 1 to 3 of 3)
Subject: knowledge extraction from povray
Date: 13 May 1999 19:37:48
Message: <373B5521.788D7BEF@sympatico.ca>
Hi
anyone has info about the above subject, related to architectural
visualization?
tia
Hassoun
Subject: Re: knowledge extraction from povray
Date: 14 May 1999 17:55:19
Message: <373C8D12.91168417@ida.utb.hb.se>
Not sure if I understood exactly what you meant, but there's an amazing
gallery with examples of POV used in architectural visualization here:
http://www.aust-anfertigungen.de/    (Click on the image to the right of
"3D-Visualisierung")
It's in german, but the images speak for themselves...
Mikael Carneholm
Dep. of Computer Science
http://www.studenter.hb.se/~arch
E-mail: sa9### [at] idautbhbse
Download 'us-ascii' (1 KB)
Date: 14 May 1999 23:26:51
Message: <373CDB1B.EB247763@sympatico.ca>
Dear Mikael
thanks for your interest in my question.
i will try to be precise in my explanation:
pov objects are created using descriptions of their shapes, position,
rotation and scale in space, and their surface properties. these
descriptions can be parametrized (if i can use the verb) in order to
make the object generic, and relate it to others thus have knowledge in
them:
e.g. the diameter of a greek doric column is equal to the tenth (1/10)
of its height.
thus the declaration of my column object in povray would be as follow:
#declare height=3
#declare diameter=(height)/10
#declare column=
cylinder{ <0,0,0,>, <0,height,0>, (diameter)/2}
so every time i change the height of my column, the diameter changes
accordingly. so both variables are related to each other in a very
specific way (knowledge), which constitutes an architectural type: the
doric order.
so every time i encounter a column that obeys to this type of relations,
i can confirm that it is a doric column. the principle can be applied to
other concepts like: symmetry, hierarchy, rhythm, study of proportions,
perception of forms, construction rules, etc... and lots of
architectural principles and concepts.
a povray file contains specifications of architectural objects, and
knowledge extraction (the approach i hope to develop) is to find a way
to extract all the knowledge (principles, concepts and rules) in this
file and synthesize it to produce clear definitions of the objects
contained within. (maybe using C or C++ algorithms, or LISP, or any
other suitable programming language)
i am not a programmer but i am working on it, that is why i need some
orientations.
feel free to reply
Hassoun
> Mikael Carneholm
