POV-Ray : Newsgroups : povray.programming : Calculating a mesh from a blob Server Time
10 Oct 2026 17:22:08 EDT (-0400)
  Calculating a mesh from a blob (Message 1 to 5 of 5)
Subject: Calculating a mesh from a blob
Date: 31 Dec 1998 17:52:20
Message: <368c0024.0@news.povray.org>
Hi!
  I'm making a blob modeller and there is only one problem with it:
  For the preview I need to calculate a mesh from the blob data, just like
blob sculptor does (but possibly much more accurately). Any ideas how can
I do this?
  I will post info about the modeller when it gets usable...
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Subject: Re: Calculating a mesh from a blob
Date: 1 Jan 1999 03:38:59
Message: <368C8A12.2FAC2F1D@mindspring.com>
I would surround the blob in a box grid.
shoot rays from the the grid intersections.
Find all intersections of the blob on the ray
	(record the normal too)
and make a mesh from the intersection points.
and when normal of adjacent points vary too much maybe
create extra points.
Don't know how efficient this would be. (I've been toying
with doing this in pov for iso_surface in making a mesh object
with a save for later to speed things up. Though I may just
do it to the object declaration which would probably be better)
Nieminen Mika wrote:
>   Hi!
> I do this?
Date: 1 Jan 1999 11:25:17
Message: <368cf6ed.0@news.povray.org>
Matthew Corey Brown - XenoArch <xen### [at] mindspringcom> wrote:
: I would surround the blob in a box grid.
: shoot rays from the the grid intersections.
: Find all intersections of the blob on the ray
: 	(record the normal too)
: and make a mesh from the intersection points.
  I don't know how to calculate the intersection of a ray and a blob.
  And I forgot to mention that I want fully transformable (translate,
non-uniform scale, rotate) blob components (both spherical and cylindrical),
just as in povray. I want to make a _good_ blob modeller :)
Date: 3 Jan 1999 21:39:06
Message: <36902A2B.1D17080C@mindspring.com>
look at the pov source as long as you don't copy the code just the
algorithm, it should help you in the right direction. In general the
algorithm isn't copyrighted just the code itself. Though the blob speed
ups probably are. (Though those are so confusing to me) If your going to
do this for windows you may want to look at the gui extensions legal
ease to see if you can comply to that and then just use povrays own
functions. Not sure if it would be allowed though.
Date: 4 Jan 1999 14:29:25
Message: <36911695.0@news.povray.org>
On Sun, 03 Jan 1999 18:40:43 -0800,
GUI extensions are forbidden to access POV-Ray through any but the
documented interfaces.  Access to object intersection functions is
not part of that interface.
There is an equation for blobs; they could be treated as isosurfaces,
following the general algorithm on R. Suzuki's web page.  Or, you can
use something like Marching Cubes to find the interior surfaces as a
triangle mesh; see the comp.graphics.algorithms FAQ parts 5.10 and 5.11
for more info, references, and links, including patent restrictions:
(I've had to separate this URL onto two lines to keep it under 80
characters as my posting software requires; the clever reader will know
how to fix it.)
http://www.cis.ohio-state.edu/hypertext/faq/usenet/
graphics/algorithms-faq/faq.html
