POV-Ray : Newsgroups : povray.programming : #ifdef(array[index]) Server Time
17 Apr 2026 01:34:37 EDT (-0400)
  #ifdef(array[index]) (Message 1 to 6 of 6)
Subject: #ifdef(array[index])
Date: 22 Oct 1998 10:16:13
Message: <362F2EA6.5AF2@ida.utb.hb.se>
#ifndef(array[index])
or, alternatively, some way to convert strings to identifiers, like
this:
#declare iteration=0;
#while(iteration<10)
   #ifdef(concat("variable_",str(iteration,0,0)))
   #declare iteration=iteration+1;
...which would allow me to see if variable_0, variable_1, variable_2
etc. has been declared.
- Mikael.
Subject: Re: #ifdef(array[index])
Date: 24 Oct 1998 20:15:30
Message: <36326070.7F3C@phoenix.net>
> #end
This would be nice. You could try a workaround. Initialize all
elements to a dummy value that you are sure will never be a
legitimate value for any element, say 0, or a negative number.
Compare the value of array[index] to the dummy value to see
if you've re-assigned it a legitimate value. Of course, this could
waste alot of memory in some cases, depending on the size
of the array and what type of data the elements hold.
You could also create an array of the same size as the one
containing the data, but the elements of the second array reflect
the status of corresponding elements in the data array. I could
see using a string to contain information like this as well
for a single dimension array of less than 255 elements, or you
could use arrays of strings for larger and more complex cases.
Desperation is the mother of invention!
> this:
Impossible.
>    #end
> #end
I'd stick with arrays...
Date: 25 Oct 1998 00:33:10
Message: <36329b58.25693363@news.povray.org>
On Sat, 24 Oct 1998 18:19:12 -0500, Wayne Gordon <way### [at] phoenixnet>
>> this:
>Impossible.
Not impossible.  Just not useful except as a workaround for the lack
of other data types.  For examples of languages that can do this (but
in which most people wisely choose not to) see Perl or Lisp and look
at the 'eval' function.
Date: 25 Oct 1998 07:23:15
Message: <36331919.1CF5@phoenix.net>
> >> this:
> >Impossible.
I meant that it was impossible to do in POV's scripting language
right now, not necessarily impossible in another language. POV can
convert the contents of a string to a numerical value and assign
that value to a variable, but it is not possible to convert a string
to an identifier as was asked.
Date: 25 Oct 1998 19:39:48
Message: <3633C497.75505AC5@flash.net>
It's quite possible.
Use file i/o to generate an .inc file, then include
it.
But it would get ugly....
Dan
> > >> this:
> > >Impossible.
http://www.flash.net/~djconnel/
Date: 26 Oct 1998 16:27:47
Message: <3634EA47.4804@phoenix.net>
> it.
Ahhh, yes. I dind't think of this, obviously. I stand corrected.
Indeed.
> Dan
> > > >> this:
> > > >Impossible.
