![](/i/fill.gif) |
I have a idea for a new object: density file object.
The basic idea is to take a df-file and render it. Where is a density,
there is a part of this
object. Regions without density will be not rendered. For a better
control of the density it will
be good if you can declare a threshold and all densities < threshold
will be ignored.
To become a homogenous object, it will be good, if you could
smooth/interpolate the densities.
a possible syntax for that object:
densityf
df new.df
threshold .5
smooth/interpolate
This is just a idea! I don't know, if this idea could be realized?
I think it's similar like the isosurface pov. There you can declare
functions, which will be
rendert. Here you can build the df-file with functions,handmade,etc and
then it will be rendered.
One Question :
It's possible to access every value in an df-file with the #read -
commando within povray?
When it's possible, then a pov-file can read the df-file and can replace
all densities with
other objects like spheres, blobs etc.
Could this be a other way to make df-file objects?
v
Zan
PS.: Sorry for my bad english!
![](/i/fill.gif) |
