Hi!
Is there any technique implemented in POV-Ray (especially in version 3.1) that
makes use of coherence? If so, which kind of coherence (spatial, temporal) is used?
Thanks,
Andre Wesseling
Subject: Re: Does POV-Ray 3.1 exploit any coherence?
Date: 17 Jan 2002 07:48:40
Message: <3C46C815.95F78E09@gmx.de>
Andre Wesseling wrote:
> Hi!
I'm not sure what you mean with coherence, but in case you are talking
about quantum physics related effects ('coherent light'), raytracing in
general does not simulate such effects and photon mapping does not either
(although this could possibly be extended)
Christoph Hormann <chr### [at] gmx de>
Date: 17 Jan 2002 07:49:40
Message: <3c46c864@news.povray.org>
In article <1103_1011269679@news.povray.org> , Andre Wesseling
> used?
Well, POV-Ray uses a ray-model of light and the little I know about the
effects you are asking about suggests they are based on a wave model.
The better question to ask is what physical effects POV-Ray can simulate
because not all physical models are feasible for efficient (or possible)
implementation of a ray-tracer:
So, what particular effect are you looking for?
Thorsten
Andre Wesseling <wes### [at] math uni-muenster de> wrote:
: Is there any technique implemented in POV-Ray (especially in version 3.1) that
: makes use of coherence? If so, which kind of coherence (spatial, temporal) is used?
Or are you talking about the techniques sometimes used in scanline rendering?
For example temporal coherence in an animation means, IIRC, "render only those
parts of the image which changed with respect to the previous frame".
POV-Ray doesn't use any of these tricks.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
I meant coherence in the way Warp understood it. So I wanted to know:
- Does POV-Ray use any information of one frame to speed up calculation of
the next frame while rendering an animation?
- Is a form of ray coherence used to speed up calculation?
My question was not intended towards physical effects based on coherence,
because I know that most ray tracers --including POV-Ray-- are using the particle
model of light, not the wave model. So, this question was about the software
engineering part of POV-Ray =).
Thanks for that fast replies,
Andre Wesseling
In general, no, but of course you can #write variables calculated in one
frame and #read them for the next frame, if your goal is to avoid doing
complex calculations in each frame or if your calculation is inherently
iterative. Some include files out there (frex, smokegen) use this technique.
Some patterns do this. Uppermost in my mind is the crackle pattern, which
caches the centers for the most-recently-visited part of its perturbed
lattice in case the next ray happens to hit the same part of the lattice.
This is much faster than recalculating the centers for each ray.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
"Ron Parker" <ron### [at] povray org> wrote...
Also, shadow calculations utilize a at least one cache to keep a
recently-used object around for quick intersection tests.
-Nathan
Light buffers...
"Andre Wesseling" <wes### [at] math uni-muenster de> píše v diskusním príspevku
news:1103_1011269679@news.povray.org...
> Hi!
that
is used?
> Thanks,
> Andre Wesseling
