I'm sure more expert people in various languages will be able to teach me
something important from what is probably a naive question : What if in POV 4
we had the possibility to use spaces or tabs as a synonym to what curly braces
currently do, but we could still use those braces themselves ?
That way new comers would feel at first glance that the language is as easy to
learn as Python, and would rapidly understand as they do in Python, that what
matters is that they do know what scope they're in.
and eventually, depending on *whichever* option gets to become the most popular
among core developers and power users, it can become a maintenance cost
reduction to drop one or the other?
Inspiration for this idea? of course, python... I love how it has grown able to
do type annotations, switch cases, etc. and while across versions leverage many
advanced concepts teaching them to me as it went, and now they are there, I love
how a new comer could still pick it up exactly the way I did, with a human
readable almost fiction-book like syntax, and still produce scripts that do
work, syntactic-sugar-free. BUT I know there must be a reason why those curly
braces are still there isn't there? so I trust people to tell me... maybe so
that POV acts as a launching pad to learn C-like languages in which it is itself
developed?
Subject: Re: Curly braces replaced by indentations but only as an option ?
Date: 18 Mar 2025 05:00:33
Message: <67d93631$1@news.povray.org>
...and those newcomers will quickly find themselves producing mixed
syntaxis, then trying to understand what the heck is this.
And, frankly, I don't see anything good about Python identation. To me
it only takes more screen space than necessary, produce weird linewraps
on display, and so on. I believe everything one need to control brackets
and braces of all kinds it syntax highlight, and, ideally, a linter.
Well, we already have a POV extension for VSCode, it's not perfect but I
think it's a way to go, it would be definitely better than spending time
for creating new POV editor. So we may get syntax highlight and stuff
this way. What as to linter and stuff like that, that's a different
story and more complicated one.
Ilyich the Toad
https://dnyarri.github.io/
Was anyone aware that in the ini directory, there is a file named
"user-keywords.txt" ?
# user-defined keywords may be placed in this file
# these keywords do not affect parsing or SDL; they are only used by the editor
# for syntax highlighting and keyword completion (i.e. ctl-space or tab)
# the syntax is one keyword per line. spaces are not permitted within keywords
# (leading or trailing spaces are allowed but will be stripped). any line
containing
# more than one token will be ignored, as well any line starting with a '#'.
:O
(I haven't tried it yet)
As I use Nim, I agree with this aspect very much. I chose Nim because it looks
like Python, but it is nothing like it. It takes a while to forget Python, but
then it's all fine.
For the rest of it, a well designed language should need "no" tooling. Imagine
that all books where printed colour coded, verbs in green etc. And then users
start to nag that it should be printed in dark mode .... Colour does not matter
for me as I mostly have set Windows to greyscale, Ctrl+win+C.
What Python has shown is that readability counts and that there is very little
need for line noise, arrows, squiggles and what not. In some aspects Nim takes
it even further. And the they broke it with the @ and type stuff in python and
{.pragmas.} in Nim.
POV-Ray has a lot of '#', I never liked that, nor the constant need to
#declare/#local. In Nim and probably others too, that is solved in an elegant
way :
var
chicken ...
swan ...
duck ...
hi,
I'd be interested to learn what (tangible) gain(s) you see in that.
right, and Icelanders and Germans could simply switch to English :-).
> developed?
I'd like to see you post a bit of "mocked up" scene code to illustrate the
benefits; I guess you'd like something like 'union box 0 1 sphere 0 .5 ' ?
fwiw, even _if_ I thought Python a good language I'd endorse Ilya's view:
"...and those newcomers will quickly find themselves producing mixed syntaxis,
then trying to understand what the heck is this."
regards, jr.
Date: 18 Mar 2025 13:07:27
Message: <67d9a84f@news.povray.org>
____
.__ /_ |
__| |___ | |
/__ __/ | |
|__| |___|
Nothing good about pyhton.
Definitely bad language.
After that, of course, everyone has their own preferences and affinities.
kurtz le pirate
compagnie de la banquise
Date: 18 Mar 2025 14:22:15
Message: <67d9b9d7$1@news.povray.org>
That would be a pretty BAD idea. It'll make the code uselessly hard to
understand, introduce a LOT of ambiguity. That can only lead to code
that is nearly to totally impossible to debug.
clipka once proposed a YAML like structure. I didn't like that at all, fun
thing, many macro generated DSL's made in Nim use that kind of syntax.
ingo
Date: 18 Mar 2025 15:33:06
Message: <67d9ca72$1@news.povray.org>
And it should look like obscene Russian, for my convenience. That means
it must be flexible and extendable beyond any recognition.
Ilyich the Toad
Date: 18 Mar 2025 15:43:00
Message: <67d9ccc4$1@news.povray.org>
Well, I'm not considering it especially bad, and even use it for my
POV-Ray scene creating stuff. But I'm not considering it extremely good
and easy either, and all this indentation stuff is definitely not what I
like, specifically. After all, if you take a look at my Python-based
img2mesh POV export stuff, you'll see something like:
resultfile.write(f'\n triangle {{<{x_out(x, 0)}, {y_out(y, 0)},
map({v1})> <{x_out(x, 1)}, {y_out(y, 0)}, map({v2})> <{x_out(x, 0.5)},
{y_out(y, 0.5)}, map({v0})>}}')
and don't tell me it is low on braces ;-)
Ilyich the Toad
