POV-Ray : Newsgroups : povray.pov4.discussion.general : Curly braces replaced by indentations but only as an option ? Server Time
21 Apr 2025 16:46:00 EDT (-0400)
  Curly braces replaced by indentations but only as an option ? (Message 51 to 51 of 51)
Subject: Re: Curly braces replaced by indentations but only as an option ?
Date: 6 Apr 2025 03:00:00
Message: <web.67f225ad7e3c5a9917bac71e8ffb8ce3@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> "ingo" <nomail@nomail> wrote:
> > a 4000x4000 image took 1 minute 7 seconds. Multi threaded works, the same image
> > takes 2 sec 968 ms.
> > Next, clean up and polish.
> had meant to comment on the image and the script, sorry for leaving it
> "hanging".  the app/library example certainly looks interesting, as does the
> result, and "no slouch" either :-).
While putting all the pieces together, the thing fell apart. The problem is that
the current set of macros in the nimscripter library does not allow to push
procs over the barrier (yet). When using a template it kind of works, but for
multi threading in the end it fails.
Regarding Nim, it's fun to use, sometimes fiddly and sometimes a bit rough
around the edges. It's under constant development by a very small team.
(just implemented https://paulbourke.net/fractals/bioblob/ in it, with export to
POV-Ray or JSON)
ingo
