POV-Ray : Newsgroups : povray.pov4.discussion.general : Conditional Directives within the inifile Server Time
31 Mar 2026 19:12:16 EDT (-0400)
  Conditional Directives within the inifile (Message 1 to 3 of 3)
Subject: Conditional Directives within the inifile
Date: 2 Jun 2011 20:35:01
Message: <web.4de82b4da1aea573a3bfeb720@news.povray.org>
I've done some animation for the election-day on my little island, using PovRay.
To set-up the project was a little to complex for the ini-files.
It would be a very cool thing, heaving conditional directives within the
ini-files, like:
Antialias=Off
Input_File_Name=election.pov
Initial_Frame=1
Final_Frame=23
Display_Gamma=2.0
Width=1440
Height=115
Declare=FileToImport=2
#switch (FileToImport)
  #case (1)
   Output_File_Name=Canditates-01-a
   Declare=GlobalDivider=20
   Declare=FramesAtTheEnd=250
  #break
  #case (2)
   Output_File_Name=;02 = Canditates-01-b
   Declare=GlobalDivider=25
  #break
In this case, I would only need to edit the "Declare=FileToImport=..." entry and
everything else is done automatically.
I had more then 17 different files to import and all with different conditions
ahead...
The result can be watched here:
http://www.youtube.com/watch?v=SQcsNXEpTRQ
After rendering, I've used Avisynth for the quick-compositing. The rendering
took just a view seconds, it was "almost realtime" ;) but the fiddling with the
inifile took unnecessary long time.
Best rgds,
Holger
Subject: Re: Conditional Directives within the inifile
Date: 3 Jun 2011 04:20:58
Message: <4de8996a$1@news.povray.org>
Am 03.06.2011 02:31, schrieb H. Karsten:
> Antialias=Off
> Initial_Frame=1
> Final_Frame=23
> Display_Gamma=2.0
> Width=1440
> Height=115
>    #case (1)
>    #break
>    #case (2)
>    #break
>   #end
Why wait for POV-Ray 4.0 when you can nest ini files /now/?
     --------------------------------foo.ini
     Antialias=Off
     Initial_Frame=1
     Final_Frame=23
     Display_Gamma=2.0
     Width=1440
     Height=115
     candidates.ini[2]
     --------------------------------candidates.ini
     [1]
     [2]
     Output_File_Name=Canditates-01-b
You can also move the "candidates.ini[2]" line on the command line
instead, for the benefit of not having to edit the ini file over and
over again before rendering.
Date: 3 Jun 2011 16:00:00
Message: <web.4de93c52de65399ba3bfeb720@news.povray.org>
That sounds very good :)
