POV-Ray : Newsgroups : povray.pov4.discussion.general : floating point precision Server Time
30 Mar 2026 12:28:41 EDT (-0400)
  floating point precision (Message 1 to 3 of 3)
Subject: floating point precision
Date: 12 Oct 2009 19:20:00
Message: <web.4ad3b95a1e85221ac41e4df50@news.povray.org>
A few weeks ago I was doing a
#while(inc<=1)
#local inc=inc+some_small_increment
loop for an animation in which I was making loops from 0 to 1.0. where 1 is
evenly divisible by some_small_increment divide
I spent about two hours trying to figure out why my loop was coming up one item
short.
I realize now that it was coming up short since inc never actually equals 1, but
somethine closer to 0.9999999999.
I eventually solved my probelem by scaling everything by 1,000 and changin the
#while(inc<=1)
to
#while(inc<=1000)
#local inc=inc+some_other_larger_increment
I'm assuming there is a perfectly legit reason as to why this was happening
(having to do whith floating point precision) but Is there anyway to get around
this?
If this does not seem legit please let me know, and I will upload source into
someother forum for explanation or bug-fixing purposes.
-Jeff
Subject: Re: floating point precision
Date: 12 Oct 2009 21:19:50
Message: <4ad3d5b6@news.povray.org>
> this?
The underlying problem is the same as if you'd try to compute 1/3 + 1/3
+ 1/3 + ... using decimal numbers with a certain limit in precision; as
you can't exactly represent 1/3 this way, you'd get e.g.:
   0.33 + 0.33 = 0.66
   0.66 + 0.33 = 0.99
   0.99 + 0.33 = 1.32
In practice, if you have a fixed value to add, you can usually
"re-normalize" the whole problem to use integers for your loop variable;
e.g. instead of:
   #local Foo = 0.0;
   #while (Foo <= 1.0)
     #local Foo = Foo + MySmallValue
you can use:
   #local Bar = 0.0;
   #while (Bar * MySmallValue <= 1.0)
     #local Foo = Bar * MySmallValue;
     #local Bar = Bar + 1.0;
Somewhat more generally, any integer divided by any power of 2 is safe
to add (unless it's extremely small compared to the "target value").
Date: 28 Mar 2011 16:29:03
Message: <4d90ef8f@news.povray.org>
you sipmly use a bad way to increment especially if your incrementation is
regular
cause your add each time a precision error, to a precession error of your
inc
instead of using addition, use multiplication
in fact your code acts like this:
inc(1) = inc(0) + (e + de)            (de is error precision)
inc(2) = inc(1) + (e + de) = inc(0) + 2*e + 2*de (you error precision is 2
times higher that normal at maximum)
etc
your way to calculate your inc, is what we call an arithmetique serie
hence this can be simplified by
inc(n) = inc(n0) + some_small_increment (n-n0), where n is the total number
of frame, n0 the first frame, inc(n0) the first value of inc
web.4ad3b95a1e85221ac41e4df50@news.povray.org...
> #while(inc<=1)
> #end
> is
> item
> short.
> 1, but
> the
> #while(inc<=1)
> to
> #while(inc<=1000)
> #end
> happening
> around
> this?
> into
> -Jeff
