POV-Ray : Newsgroups : povray.pov4.discussion.general : New camera, or new camera docs illustrations. Server Time
4 Jul 2025 07:25:40 EDT (-0400)
  New camera, or new camera docs illustrations. (Message 64 to 73 of 73)
Subject: Re: New camera, or new camera docs illustrations.
Date: 28 Jun 2009 03:27:18
Message: <4a471b56$1@news.povray.org>
scott wrote:
>> If YOU specify a resolution with non-square pixels,
> Sure, but at the moment you don't, POV just assumes you want non-square
> pixels, which IMO is wrong most of the time.
How can you possibly mean that you don't specify the ratio?
Just about everyone specifies the exact image dimensions to use.
Additionally, every scene has a specific aspect ratio (either explicit
or implied).  If the ratio doesn't match, the only rational response by
POV is to assume that the user input is correct, and that non-square
pixels are desired.
Chambers
Date: 29 Jun 2009 06:11:36
Message: <4a489358@news.povray.org>
I specify an image aspect ratio, nowhere have I specifically said I want
non-square pixels.  IMO you should specifically have to say you want
non-square pixels, because it's not a common requirement.
Agreed.
> Additionally, every scene has a specific aspect ratio (either explicit or
SO you still expect me to trawl through all the scene files, looking for the
camera block that is actually the active one, then calculate what image
dimensions I should tell POV I want, just to get an image with square
pixels?  That doesn't sound too ideal to me, *especially* when most of the
time you do want square pixels.
Date: 30 Jun 2009 03:15:57
Message: <4a49bbad$1@news.povray.org>
> the camera block that is actually the active one, then calculate what
> image dimensions I should tell POV I want, just to get an image with
> square pixels?  That doesn't sound too ideal to me, *especially* when
> most of the time you do want square pixels.
So you're saying that your major objection is that you don't want to
look through the source code, right?
Chambers
Date: 30 Jun 2009 05:46:34
Message: <4a49defa@news.povray.org>
> So you're saying that your major objection is that you don't want to look
And then do a calculation to figure out what to tell POV, yes.  I've used
enough 2D and 3D programs, and none works like this, it's completely
counter-intuitive.  All programs I've seen automatically assume you are
working with square pixels unless you specifically check or uncheck a
certain option, IMO it should be the same for POV.
Date: 30 Jun 2009 21:52:01
Message: <4a4ac141$1@news.povray.org>
Fair enough.
Arguing that POV should be like other programs doesn't really convince
me of anything, though, since POV distinctly *isn't* like other programs.
Anyway, back to the subject at hand.
POV has two sets of input: the scene itself (the scene file and any
include files) in SDL, and INI options (given either in actual .ini
files or on the command line).
Currently, the idea is that everything concerning the picture be
contained within the scene, whereas everything concerning the output
image be contained within the INI options.  The picture, including
objects, textures, and even the camera, can not be modified from the INI
options.
Currently, POV views the camera as part of the scene.  That's just how
it works.
Now, what do you want to accomplish?
If you want to resize the image without changing the aspect ratio, then
we have several options.
1) When the user specifies only one dimension, let POV compute the other
assuming square pixels.
2) When POV parses the final camera block, display the image aspect
ratio as part of the text output.
3) If the image aspect ratio does not match the camera aspect ratio,
give a warning (but continue in case non-square pixels are desired).
If, on the other hand, you want to resize the image, and *change* the
aspect ratio, I'd recommend that you actually read the scene files
(because you need to know about the scene, what is present, and where it
is placed).
Chambers
Date: 1 Jul 2009 05:49:09
Message: <4a4b3115@news.povray.org>
> is placed).
I don't know about you, but I find it really hard to visualise what a scene
will look like by just reading the scene files!  It's much easier to just
look at a rendered version (either pre-rendered or I will render a quick
preview myself).
Why not just have a flag/setting:
What should POV do if the requested image aspect does not match the scene
aspect ratio?
[ ] Adjust image dimensions for letterbox result
[ ] Adjust image dimensions for zoomed/cropped result
[ ] Adjust camera horizontal FOV to match
[ ] Adjust camera vertical FOV to match
[ ] Render non-square pixels
Date: 1 Jul 2009 23:18:57
Message: <4a4c2721@news.povray.org>
> scene aspect ratio?
Actually, that's a pretty good idea.
Chambers
Date: 10 Aug 2009 17:04:15
Message: <4a808b4f@news.povray.org>
gregjohn wrote:
> It took me 13 years of povving to understand the camera. That is, to come up
> with the code for a box which exactly fills the screen, regardless of camera
> angle/ distance and image aspect ratio.
I don't see what the difficulty is. It's as simple as this:
camera
	location	<0,0,-4>
	direction	<0,0,+4>	// reciprocal of location
	up		y
	right		x*image_width/image_height
// polygon centered on the origin with sides of length 1
polygon
	4, <-1/2,-1/2>, <-1/2,+1/2>, <+1/2,+1/2>, <+1/2,-1/2>
	pigment {color Red}
The trick here is to not use the angle and look_at keywords. In this
case, they're more trouble than they're worth. Also, if you omit the
image_width/image_height stuff, then it fills the viewport *exactly*,
regardless of the aspect ratio.
-Mike
Date: 10 Aug 2009 22:33:18
Message: <4a80d86e$1@news.povray.org>
SharkD schrieb:
>> come up
>> camera
What you're doing is designing camera parameters so that a certain
"friendly" box fills the entire screen.
The OP's challenge, however, was quite different: From a given arbitrary
(potentially "unfriendly") camera perspective, compute parameters for a
box to fill the screen (possibly to overlay a border, signature or
whatever onto the image).
Date: 11 Aug 2009 04:29:22
Message: <4a812be2$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4a80d86e$1@news.povray.org...
> SharkD schrieb:
>>> come up
>>> camera
isn't that exactly why screen.inc was made?
cu!
