POV-Ray : Newsgroups : povray.pov4.discussion.general : New camera, or new camera docs illustrations. Server Time
22 Mar 2026 12:10:05 EDT (-0400)
  New camera, or new camera docs illustrations. (Message 24 to 33 of 73)
Subject: Re: New camera, or new camera docs illustrations.
Date: 29 May 2009 06:49:52
Message: <4a1fbdd0@news.povray.org>
scott <sco### [at] scottcom> wrote:
> Sure
> it's possible, but a sensible default behaviour would make it easier...
  And what, in your opinion, should the "sensible default behavior" be
if the author wanted, for example, for his image to be rendered in a very
widescreen format like, let's say, 2.4:1 (typical movie aspect ratio), and
this because he composed his image so that it will work the best with that
aspect ratio?
  I somehow get the feeling that you are making the assumption that all
scenes are designed for a 4:3 aspect ratio because that's the default,
and that you are arguing what happens when you want to render it for a
16:9 (or sometimes 16:10) monitor.
  However, often when an author uses a very different aspect ratio, eg.
a very widescreen one, or perhaps the other extreme, a square one (or
even one which is taller than wide, for artistic composition purposes)
it's because he really intends for the image to be rendered with that
aspect ratio. Imagine that someone composes a scene which has an aspect
ratio of 1:2 (twice as tall as wide), eg. for a postcard. He *definitely*
composed the scene for that precise aspect ratio, not anything else.
  So what would be, in your opinion, the "sensible default behavior"
when you then try to render that 1:2 image into a 16:9 one? Maybe render
a 16:9 part in the middle of the original 1:2 image?
  I'm sorry, but I just disagree with you. The original image composition
should be preferred over anything else, unless the author *specifically*
allows other aspect ratios to be used (which he can in the current POV-Ray).
Date: 29 May 2009 06:51:25
Message: <4a1fbe2d@news.povray.org>
> >  And exactly how would you even know about the "hfov" keyword without
> > reading the documentation?
> Because it comes in the default camera block? (Insert -> Camera -> ...)
  You assume everyone uses winpov, and the insert menu?
> or has been already written in a scene you are looking at?
  So you are simply delegating reading the documentation to someone else?
And how's that different from someone else having read the documentation
about the 'angle' keyword and explaining it to you?
Date: 29 May 2009 07:45:45
Message: <4a1fcae9@news.povray.org>
Yes, that is my assumption for the default behaviour, that the author just
uses the default aspect ratio without a second thought for anyone else who
might want to render it.  This is quite typical of the images you see posted
on this server, which often then people then want to render as a desktop
wallpaper.
> aspect ratio.
Sure, and in that case the author should have to force the aspect ratio in
his scene file - but it shouldn't be the default behaviour.
> POV-Ray).
I see what you're saying, but my point is that in most cases (just look at
the last 20 or images from p.b.i) the author has not set any specifc aspect
ratio or any particular scene geometry that wouldn't work with a different
aspect ratio.  I see it that your example is the exception to the norm, the
author chooses some carefully calculated aspect ratio and designs his scene
specifically only to work with that exact aspect ratio.  In which case I see
that as a silly choice for the default behaviour.
Date: 29 May 2009 07:54:03
Message: <4a1fccdb$1@news.povray.org>
No, but it's a jolly useful time saver, I recommend it.
That is a silly argument, the "someone else" would need to read the
documentation anyway, so what's the disadvantage of using more meaningful
keywords.  No wonder POV is so slow to develop if you have to debate whether
using more meaningful keywords is a good thing or not :-(  Oh well.
Date: 29 May 2009 07:55:00
Message: <web.4a1fcbf41369cabf34d207310@news.povray.org>
I think that there's a fundamental problem that a 4:3 aspect ratio is built-in
to the current camera.  It's not just about taking other's code and abusing it
(albeit how many really *want* to wreck non 4:3 viewing). It's not about trying
to make something full screen-- there is the concept of making one's own "art"
for print with povray, and I've got one non-4:3 monitor anyway. And what about
making square avatars?!
Stepping back a moment, there is a problem with the docs, notably the diagram,
in that the aspect ratio is NOT part of the visual equation the reader is
invited to make.  The docs have all the truth in them, in that anyone who
complains can be pointed to a phrase where they didn't RTFM, but the doesn't
*teach*. The diagram also doesn't sufficiently tell the relation between angle
and distance. If you already know how it works, the diagram doesn't lie, but it
doesn't tell you how povray uses them or handles the hierarchy of the
potentially redundant variables.
Scott sums up my views with:
<< The current default behaviour means that if you want to render someone elses
scene for your desktop wallpaper or to print out, you have to search through
their code for the right camera block and make some changes, I can't even
remember the number of times I have had to search through and put in some
"image_width/image_height" statement.  Is this really the best thing for the
default behaviour?  IMO the default behaviour should mean the least work for
what is most common, ie if you actually *want* non-square pixels you should
have to go and fiddle with the code.>>
IMHO, the current camera object is something that a smart person *can* figure
out with some work. But with so many things in programming, eventually the
exercise in pure logic ends, and the question of "How did this person decide to
put it together?" starts.  It's not logical.
Date: 29 May 2009 08:15:00
Message: <web.4a1fd09b1369cabf34d207310@news.povray.org>
Piling on:
How about making a one-pass anaglyph, doing image processing, or setting up a
captioning system for animation, submitting to an animation contest that wants
non-4:3 entries?  For doing "great things" in povray (as opposed to "petty
things" in povray like taking someone's code to make full-screen wallpaper),
you might have to know exactly where an object will be relative to the camera.
I submit that if you gave a bunch of intelligent people the docs, most of them
wouldn't be able to straight-up code a box that exactly fills the screen. You
could probably dig up phrases buried somewhere in the doc to embarrass them
however. That's a problem.
Date: 29 May 2009 09:08:25
Message: <4a1fde49@news.povray.org>
> In which case I see
  I asked what should, in your opinion, be the default behavior. You didn't
answer that question.
Date: 29 May 2009 09:09:48
Message: <4a1fde9c@news.povray.org>
  Have you ever thought that adding new keywords can potentially break
existing scenes? The SDL namespace is already heavily cluttered as it is.
Date: 29 May 2009 09:13:18
Message: <4a1fdf6e@news.povray.org>
  If you have a 4:3 photograph and you want to fill your 16:9 screen with it,
what do you do?
  Why can't the same answer be applied to a 4:3 povray-generated image?
Date: 29 May 2009 09:48:41
Message: <4a1fe7b9@news.povray.org>
>> In which case I see
I did already in an earlier post - no time to repeat sorry, go find it if
you're interested.
