POV-Ray : Newsgroups : povray.pov4.discussion.general : New camera, or new camera docs illustrations. Server Time
24 Mar 2026 18:02:57 EDT (-0400)
  New camera, or new camera docs illustrations. (Message 14 to 23 of 73)
Subject: Re: New camera, or new camera docs illustrations.
Date: 28 May 2009 05:44:09
Message: <4a1e5ce9$1@news.povray.org>
>> camera{
>> hfov 90
> What's wrong with the "angle" keyword?
It isn't obvious from the keyword exactly what it sets, and there isn't a
vertical equivalent.
Date: 28 May 2009 13:07:36
Message: <4a1ec4d8@news.povray.org>
scott <sco### [at] scottcom> wrote:
> I think the point of the request is to make easier to choose from the above
> options without needing to resort to some carefully figured out statements.
  That might have been a minor, secondary point. The main point was that
the current default camera behavior should be changed. *That* is what I
disagreed with.
Date: 28 May 2009 23:22:19
Message: <4a1f54eb$1@news.povray.org>
> a vertical equivalent.
 From 3.3.1.1.3:
"The angle keyword followed by a float expression specifies the
(horizontal) viewing angle in degrees of the camera used."
Am I wrong to assume that someone can look up the documentation?
Aside from that, if you want to change the aspect ratio of the image, I
find POV's up and right vector usage quite easy to use.
But again, I'm one of those weirdos who actually knows how to read (the
docs).
Chambers
Date: 29 May 2009 03:46:03
Message: <4a1f92bb@news.povray.org>
> disagreed with.
The current default behaviour means that if you want to render someone elses
scene for your desktop wallpaper or to print out, you have to search through
their code for the right camera block and make some changes, I can't even
remember the number of times I have had to search through and put in some
"image_width/image_height" statement.  Is this really the best thing for the
default behaviour?  IMO the default behaviour should mean the least work for
what is most common, ie if you actually *want* non-square pixels you should
have to go and fiddle with the code.
Date: 29 May 2009 03:53:13
Message: <4a1f9469$1@news.povray.org>
> From 3.3.1.1.3:
Of course not, but using eg "hfov" instead of "angle" means you don't even
need to open the documentation to realise what it is setting.  It also then
means the corresponding vfov could be used, again, without having to lookup
in the documentation.  Once a language syntax gets more complex it's
actually really handy to work like this, where most things are "obvious"
without having to look up in the documentation each time.
> docs).
...and I'm one of those weirdos who doesn't like needless inefficiencies, no
matter how small :-)
Date: 29 May 2009 03:55:22
Message: <4a1f94e9@news.povray.org>
  If the author didn't put such a statement in their camera block, then
maybe the author didn't even intend for the image to be rendered in other
aspect ratios?
  And if you really want to censor part of the image so that it will fit
your screen, then how about rendering it with the intended aspect ratio
and the width of your screen, and then clip it with image editing software?
At least that way you have more control over what you are censoring.
Date: 29 May 2009 03:57:39
Message: <4a1f9573@news.povray.org>
  And exactly how would you even know about the "hfov" keyword without
reading the documentation?
Date: 29 May 2009 04:01:15
Message: <4a1f964b$1@news.povray.org>
scott wrote:
> I can't even remember the number of times I have had to search
> through and put in some "image_width/image_height" statement.
Then you're abusing other peoples' images.  Maybe you should accept the
fact that particular images are not going to fit your monitor
full-screen, but will instead have to be either cropped or letterboxed.
 From what you've been saying, it sounds like you'd prefer cropping.
Anyway, I firmly believe that input should be separate from output, and
that any image should be renderable at any resolution.
Chambers
Date: 29 May 2009 06:06:06
Message: <4a1fb38e@news.povray.org>
>> even
Because it comes in the default camera block? (Insert -> Camera -> ...) or
has been already written in a scene you are looking at?  The benefit then is
that you can be pretty sure what it means straight away without needing to
look it up in the documentation.  That's why we use meaningful keywords, so
you don't have to look up everything.  Otherwise we could just use random
sequences of letters!
Date: 29 May 2009 06:11:20
Message: <4a1fb4c8$1@news.povray.org>
> aspect ratios?
Or maybe they just used the default, couldn't be bothered, or didn't even
realise?  I still think if you want to enforce some fixed aspect ratio you
should have to add it specifically, as it is not the usual behaviour needed
when rendering.
> software?
So what, I have to search for the correct camera block, figure out what
aspect ratio is used, compare it to my monitor aspect ratio, work out the
dimensions so that it will fill my monitor (either width of height is the
same, the other dimension is calculated), render the image, then load it
into an image program and crop it to exactly the monitor dimensions?  Sure
it's possible, but a sensible default behaviour would make it easier...
