POV-Ray : Newsgroups : povray.pov4.discussion.general : Next Generation SDL Brainstorming Server Time
14 Mar 2026 03:27:46 EDT (-0400)
  Next Generation SDL Brainstorming (Message 61 to 70 of 92)
Subject: Re: Next Generation SDL Brainstorming
Date: 1 Apr 2009 22:20:00
Message: <web.49d41fbcad594047f50167bc0@news.povray.org>
"clipka" <nomail@nomail> wrote:
> "moppel" <mop### [at] tutututututude> wrote:
> > I only would have one feature request regarding animations: Please add a
> > "DoNotRenderAgain"-Option or so such that frames are only rendered when the
> > output file doesn't already exist. Otherwise, you always have to adjust the
> > Subset_Start_Frame and Subset_End_Frame values in the .ini file when you quit
> > Povray and restart again, which is inconvenient. It would also make it a lot
> > easier to run several Povray instances to render one animation.
> .... which I'd actually consieder a feature request that could apply to POV 3.7
> just as well. And a good one, I guess.
I agree! Seems I'm always overwriting animation files when I don't mean to. (Of
course, you *could* say that's due to operator error...)
KW
Date: 2 Apr 2009 01:31:17
Message: <49d44da5@news.povray.org>
  +C already does something like that. It will parse the scene for each
frame, but it won't render the frame if the image has already been fully
rendered.
Date: 2 Apr 2009 03:09:49
Message: <49d464bd$1@news.povray.org>
> rendered.
I thought of that response too, but then realized that if you're passing
frames to different instances of POV then you might have a case of
instance #1 opening a file for output, instance #2 seeing the file isn't
finished, and both instances trying to write to it.
Checking, instead, if the file exists before rendering seems a much
better solution (especially combined with +C, which makes it darn near
elegant).
...Chambers
www.pacificwebguy.com
Date: 2 Apr 2009 03:35:01
Message: <49d46aa5@news.povray.org>
> > rendered.
  You are talking about a mutual exclusion problem here.
> better solution
  Checking if a file exists and then making a decision about that does not
in itself solve the mutual exclusion problem. What happens if the other
instance gets the turn in between the check and the creation of the file
of the first instance?
Date: 2 Apr 2009 04:25:00
Message: <web.49d474a3ad5940478b1036940@news.povray.org>
> elegant).
Actually, I had it happening that two instances were rendering the same frame.
But that doesn't cause errors (on my system). Both instances just render the
same frame, and the instance which finishes last overwrites the file.
The DOS-batch file that I use for rendering first checks if the frame is
present. If not, it creates it (as an empty file), and then it starts Povray.
By instantly creating the frame in the batch file instead of letting Povray
create it, chances are lowered that another DOS-batch file finds that frame
non-existant and starts another Povray instance to render the frame.
This works fine when using just a few instances (eg. 4 instances on a quadcore
system). If each frame takes 1 minute or more to render, it's rare that two
instances are looking for non-existant frame at the same time.
Of course, when using a render farm with hundreds and thousands of instances,
this approach wouldn't be sufficient. Then a platform independant solution
would be to have one process, the master, tell the other povray instances to
render certain frames. A free instance would just tell the master that it's
ready to render, and the master, who keeps track of the frames rendered so far,
would tell the instance which frame to render. Communication could be done by
writing/reading information to/from specific files.
But at the moment, for me it would be really enough just to have an option such
that Povray doesn't rerender existing frames.
Cheers,
Burkhard
Date: 6 Apr 2009 13:20:01
Message: <web.49da38aead5940478f162dfb0@news.povray.org>
Programmable animation.
Currently each frame needs to be completely parsed.  I read somewhere that
support for multiple cameras is available in 3.7, making each camera a frame
with no need to parse the scene again.  But, still this allows no changes, so
perhaps if some OO model could exist for POV-Ray objects, and an event could be
called for each frame, allowing modifications to objects without the need to
reparse the entire scene.  This could especially speed up rendering of
animations that have hi-resolution meshes.
Some way of identifying items would be needed, and the event function.  I don't
know much about the internals to know if #declare could work for this.
circle
  <0, 0, 0>, 1
  #declare the_color_map = color_map
    [0 color rgb 0]
    [1 color rgb 1]
  ... // texture, pigment, etc
  color_map { the_color_map }
preframe_script
// execute after INI preframe command, and after the scene is parsed
// An object model with methods over function calls
#declare c = the_color_map.getitem(0)
the_color_map._setitem(0, c + <0.1, 0.1, 0.1, 0.0, 0.0>)
// or better yet
#declare the_color_map.entries[0].value += <0.1, 0.1, 0.1, 0, 0>
// full control over all aspects of all objects
the_circle.pos
the_circle.radius
the_circle.transforms
the_circle.textures
the_circle.interior
// full control even over the document
#declare new_item = document.create_circle()
#declare new_item.pos = ..
#declare new_item.radius = ...
Any object that uses 'the_color_map' would get updated.  If an object wants to
use a map without recreating it, it could get a unique copy, maybe something
like:
cirlce
  <0, 2, 0>, 1
  #declare another_map = color_map { clone(the_color_map) }
  color_map { another_map }
  // During preframe/postframe scripts, changing the_color_map will
  // change all objects that use it, but another_map is a clone of
  // the map and this circles color will not get changed unless
  // another_map is changed
One problem is this requires you to first #declare the item to give it a name,
the to use it.  There could exist a way to #declare it with a given name and
use it at the same time.
Date: 8 Apr 2009 22:55:00
Message: <web.49dd6357ad594047addfbead0@news.povray.org>
re. DOM, features, parsing.
There are a number of scenarios where I've wished for scenario testing, e.g. to
see if an object fits in a space, one could do ray-tracing in the SDL on the
scene as it is being built, but what we can't do NOW is put an object in, do
some processing, then remove the object from the scene if we don't want it.
I think this type of 'spatial awareness', along with some functions to compute
overlapping (whether directly, or via bounds of computed intersections), would
go a long way for people who generate scenes procedurally.
Date: 8 Apr 2009 23:15:01
Message: <49dd6835$1@news.povray.org>
Like the MechSim patch in MegaPOV, but with the ability to alter or
remove objects.
...Chambers
Date: 8 Apr 2009 23:20:01
Message: <web.49dd68eaad594047a08de100@news.povray.org>
What good would that do? I mean, stuff that trace() and inside() cannot do for
you yet?
An example of what sort of processing you have in mind would be helpful.
POV simply cannot really compute overlapping, for reasons of its very basic
design. No way. It cannot even really compute the bounds of "computed
intersections" (whatever that would be in POV internals terms). All it can do
is compute the intersection of computed bounds. Which some nice macros can do
just as well using with min_extent(), max_extent() and the min()/max()
functions.
Really, everything POV can do with geometry is based on trace() and inside() -
plus the bounding boxes. This is really all POV has to offer in terms of
"spatial awareness". No hidden secrets. You have it *all* at your disposal in
SDL.
It's probably more a question of how *fast* it can be done.
Date: 9 Apr 2009 00:45:00
Message: <web.49dd7c73ad594047addfbead0@news.povray.org>
> you yet?
The problem is that you can't do trace() or inside() on an object that has not
yet been placed, but when it has been placed, it is a permanent placement.
Conversely, if you place an object, and then as a result of trace(), decide you
don't want that object to be placed, you can't then remove it. OO would solve
this, in that the object would be referencable after placement, and deleted (or
modified).
Currently, I suppose there's always the option of creating Clear objects, which
trace() would pick up, but they'd slow the final render down. Another
alternative would be to use animation frames, starting with a new frame if an
object needs removing.
Most of my existing 'smart object placement' has used arrays to store existing
object positions, and then subsequent items are placed only where they're
sufficiently distant from all existing objects. Spheres are trivial to place
among other spheres, but once the objects become complicated, or are oriented,
this approach becomes near-impossible.
Some typical examples might be: trees in a forest canopy (or other organic
space-fillers), chains, interlocking toys, sprawling architecture, placement of
objects at rest.
> design.
I knew it was difficult, if not impossible on complicated objects (without some
serious mesh work) so I was throwing this hat in the ring to challenge the
existing design. Fair enough, I don't mind it being squashed if it's a no-goer.
I guess that's the nature of brainstorming. :o)
