POV-Ray : Newsgroups : povray.pov4.discussion.general : Request: collapsible code blocks Server Time
20 Oct 2025 17:50:14 EDT (-0400)
  Request: collapsible code blocks (Message 1 to 7 of 7)
Subject: Request: collapsible code blocks
Date: 10 Jul 2008 03:50:01
Message: <web.4875bee77b0b3828b319b3150@news.povray.org>
I was considering the possibility of adding a collapsible code block feature to
POV, but came to the conclusion that the SDL is too irregular or "loose" for
this to work. Has this been considered before? What was the conclusion that was
come to?
Here's an example of what I mean, from Notepad++:
http://img146.imageshack.us/my.php?image=npplusuy1.jpg
-Mike
Subject: Re: Request: collapsible code blocks
Date: 10 Jul 2008 04:20:00
Message: <web.4875c535a7b34a59b319b3150@news.povray.org>
> come to?
> -Mike
Maybe the ability to *manually* set collapse points, similar to setting
bookmarks, would be a suitable arrangement.
-Mike
Date: 10 Jul 2008 12:45:01
Message: <web.48763b98a7b34a59840c749b0@news.povray.org>
> > come to?
> > -Mike
> -Mike
Out of curiosity, what do you mean by loose or irregular?  Most blocks of SDL
are surrounded by curly braces, and in theory, one could have a collapse
threshold, where any block surrounded by curly braces that has more lines than
the threshold could be collapsible (allowing nested collapsing, etc).  The user
selecting many lines and selecting a hide or collapse menu option could also
work.  This might be a more platform specific thing, though.
-Reactor
Date: 10 Jul 2008 15:45:00
Message: <web.487665b2a7b34a59e116e5c40@news.povray.org>
> -Reactor
In POV SDL you can overlap or intersect blocks. For instance something like the
following code would be valid:
pigment
  #if (true)
    color rgb x
  #else
    color rgb y
Date: 11 Jul 2008 02:15:00
Message: <web.4876f960a7b34a59840c749b0@news.povray.org>
> pigment
>   #if (true)
>     color rgb x
>   #else
>     color rgb y
>   #end
What about collapsibility for conditional directives?  For instance, the if
could be collapsed and show below the pigment, but if the pigment were
collapsed, it would hide the conditional portion.  Maybe...
-Reactor
Date: 11 Jul 2008 09:30:00
Message: <web.48775f8ea7b34a59c59235590@news.povray.org>
> pigment
>   #if (true)
>     color rgb x
>   #else
>     color rgb y
>   #end
Valid, yes... but collapsible code blocks might actually encourage better coding
behavior.  In your example, the preferred alternative is obvious:
pigment
  #if (true)
    color rgb x
  #else
    color rgb y
I can't really think of a valid circumstance where the 'looser' form is
necessary (or advantageous)...
Date: 11 Jul 2008 21:30:00
Message: <web.487808b8a7b34a5991b9f7880@news.povray.org>
I have sometimes wished that POV SDL were more regular or strict in its language
conventions. I.e., objects would be defined like objects in other programming
languages (or even as hash arrays, my favorite). But, POV might become more
difficult for new users or suffer in other ways as a result. Source code would
definitely become more voluminous. Consequently, I do not strongly support such
a major overhaul of the SDL, and suggest the manual method of code
collapsability I outlined earlier.
-Mike
