Mine isn't too difficult or anything really new, but here it is.
The addition of F-Stops into the camera focal blur. Instead of having
non-related aperture numbers, have them in two forms. 1) The numbers already
in pov. 2) F-Stop functions.
aperture = 24
or
aperture = f6.8
Just a simple little addition.
"Antonio Ferrari" <nomail@nomail> wrote:
> I've read that Povray 4.0 code, if I am not wrong, will be a porting of old
> 3.6 features into 3.7 architecture.
> So, why not to introduce some new features?
A couple ideas about cameras, both[I think] fairly trivial.
(1) Currently, if I understand correctly, if multiple cameras are included in a
scene file only one will be used. It would be useful to be able to include
multiple cameras and have each used in turn (like the familiar scene at a
tourist site when everybody hands their camera to the tour guide to take the
same shot of the group!) This would however need some way to disambiguate the
image name, perhaps an extra "camera_name" field in the camera definition.
(2) Currently there are cameras with parallel rays and cameras with diverging
pencils of rays. How about a keyword that would allow a camera to "shoot in
form infinity" along a converging pencil of rays? The result, if mapped onto a
sphere, would be something like a "Termesphere"(tm), or like the images used
by Poser and similar programs to store faces.
-Robert Dawson
This is, again, something which should not be a part of the core code,
but easily scriptable. IOW, if there isn't a suitable camera type, you
write one with SDL.
> write one with SDL.
> - Warp
Two things I'd be interested in:
1) System variables to return the resolution of an input image. This appears to
be already available in the source code, just not passed on to the SDL.
2) separate ior for fresnel reflection (in finish block) to allow for better
texture mapping. I use fresnel quite often, however if I want to map something
like chrome text on a glass block, I would have to model them separately as they
both don't use the same ior.
Just suggestions, however they would be adding to the key word pool. I've been
wanting to write a patch to do this myself regardless, just don't have the time
to look into how to compile it...
-tgq
> -Robert Dawson
This can be done right via #declaring a variable and using #if stuff. like
#declare FirstPerson = yes;
#ifndef(FirstPerson)
// Overview camera
#if (FirstPerson=no)
C:\pv3.6\scenes\animations\splinefollow\splinefollow.pov
If the tour guide can automatically frame the entire model (minus the infinite
planes) that would be good.
Just to add on, I think reparsing each frame for an animation render is too
wasteful.
tq tq 8)
What I would like to see is :
1) something like LightSys and CIE incorporated seemlessly into PovRay.
2) A planetary include file that has something similar to a procedural
version of Celestia - the universe with planets and galaxies and earth-like
planets with built in "SunPos" Systems and aTerraPov system.
3)Fixed up Glows.
4)Realtime preview.
-Nekar Xenos-
This would be good.
This is probably best kept as an include file, but could be included in the
standard distribution.
> 3)Fixed up Glows.
How? You can do some great glows with what's already there.
> 4)Realtime preview.
As long as POV lacks a GUI editor, this one remains problematic. OTOH, a button
next to the "Render" button that launches a Q5 render, or something like that,
could be useful.
In fact, along with such a button, the ability to query the current quality
level (+Q from the command line) would be useful for scenes. I already do all
kinds of LOD anyway; linking it to the current +Q option would make this
feature much more useful for me.
....Chambers
>> 4)Realtime preview.
> could be useful.
+Q0 is still slow for many scenes, and you can't do things like rotating
the camera around the scene with a good framerate.
My ideal POV-Ray GUI is: a text editor and a live GPU-rendered preview.
Probably with the ability to move the camera with mouse and/or keyboard.
But I definitely don't need to click on objects.
How is POV-Ray supposed to generate the preview if the objects are so
heavy to trace that even +Q0 is too slow?
GPU-rendered: Generate mesh once, rotate camera around it at 60fps.
Raytraced at +Q0: just as slow (maybe many seconds) for each frame.
