POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 allow negative phong / spectral values. (yuqk) Server Time
24 Jun 2026 11:43:50 EDT (-0400)
  Suggest v4.0 allow negative phong / spectral values. (yuqk) (Message 1 to 3 of 3)
Subject: Suggest v4.0 allow negative phong / spectral values. (yuqk)
Date: 14 Feb 2026 09:21:06
Message: <699084d2@news.povray.org>
An old (~2021) yuqk change for which I could not find a prior newsgroup
post 'description', allows negative phong and spectral values.
We have always been able to use the finish{} block phong and specular
features together for effects in an additive-color way. The yuqk fork
allows negative phong/spectral values too. For example:
     #declare PirateGold = srgb <0.72941,0.49804,0.01176>;
     #declare Fin01 = finish {
         brilliance 2.2
         diffuse    0.6
         metallic   1.0
         phong     -3.3 phong_size 47    // <---
         specular   3.3 roughness  1/20
         intensity_max 1.0
     #declare Txtr00 = texture {
         pigment { PirateGold }
         normal { granite bump_size 0.5 scale 1/2.5 }
         finish { Fin01 }
This capability, along with the previously discussed, new to yuqk
feature, intensity_max, allows for highlights which end in white while
staying within zero to one rgb channel value ranges(*).
In the attached image matrix the columns left to right show: phong only,
spectral only and finally combined phong and spectral use on the right.
The top row shows conventional double use of phong and spectral features
where, especially together, the output result is clipped to a strong
yellow (the hue is shifting(**)). If the light source were much
stronger, that strong yellow would eventually go white in the most
intense phong/specular regions(**).
The bottom row uses new yuqk finish features as shown in the code above.
  The differences being the intensity_max option better maintains the
phong/spectral metallic hue throughout. Coupled with a tighter phong
highlight and use of a negative phong value, this results in overall
highlights which gradually move from PirateGold to white within a zero
to one rgb channel value range (lower right).
Bill P.
(*) - Zero to one rgb channel ranges work better / more cleanly with
antialiasing (AA) - and many other POV-Ray features.
(**) - Where the output image channel ranges are clipped by the image
format and/or the display monitor's capabilities.
Download 'negphongspec_vals_with_intensitymax.png' (327 KB)
Preview of image 'negphongspec_vals_with_intensitymax.png'
Subject: Re: Suggest v4.0 allow negative phong / spectral values. (yuqk)
Date: 14 Feb 2026 13:45:00
Message: <web.6990c19f5168fad560e0cc3d949c357d@news.povray.org>
> [snip]
I'm confused.  By "spectral," do you mean "specular"?
Date: 14 Feb 2026 15:58:42
Message: <6990e202$1@news.povray.org>
>> [snip]
I do. Thank you. Every day, I'm a step closer day to talking endlessly
about turnips... :-(
Bill P.
