POV-Ray : Newsgroups : povray.pov4.discussion.general : User changes. yuqk / v4. Options re-work status. Server Time
17 Sep 2025 03:06:47 EDT (-0400)
  User changes. yuqk / v4. Options re-work status. (Message 1 to 6 of 6)
Subject: User changes. yuqk / v4. Options re-work status.
Date: 11 Jun 2025 23:21:27
Message: <684a47b7$1@news.povray.org>
The current output related option(s):
declare=<name>= <float or string> value only
become(s):
+-ub_   user_bool_filename=    string value only
+-ui_   user_int_filename=     string value only
+-uf_   user_flt_filename=     string value only
+-us_   user_str_filename=     string value only
+-uv2f_ user_vec2d_filename=   string value only
+-uv3f_ user_vec3d_filename=   string value only
+-uv4f_ user_vec4d_filename=   string value only
+-uv5f_ user_vec5d_filename=   string value only
+-um_   user_matrix_filename=  string value only
Add set of standard user boolean switch names.
  +-uof_00  user_on_off_00=   on|off
+-ux_    user_execute_filename= string value only
          (Thought is to let users create user input files
           with whatever scripting, programming language
           they wish during options parsing)
Only the rough outline above. No integrated code. (I have a couple
standalone test file parsing programs running)
I'll mention here, one of the aims of these option updates is to make
nearly all (all?) option settings available via new inbuilt functions in
the parser(*). An option name string being passed as the query key. In
limited testing this works, but I've not implemented / tried the vectors
or matrix stuff above. Those will need more code to truly be integrated
during parsing.
The overall thinking is to implement something more powerful than
'declare=...'.
The filenames used would be space delimited and use ascii-string(fast)
(or maybe std::string utf8) keys. The same inbuilt functions used as
option settings at parse time would be used to access these values by
key(**), while new inbuilt functions would be required to support vector
/ matrix input (or direct use?).
Aside: Values set with these user files would be guaranteed, top level,
read only, 'globals'. There are outstanding issues with the v3.8 global
dictionary implementation that I've never gotten sorted. (I believe the
local dictionary implementation in V3.8 is OK / clean.)
Bill P.
(*) - The declare feature identifiers, image_width, image_height and
maybe a half dozen more 'apparent keywords' are, internally, unprotected
identifiers. This is an opening for difficult SDL bugs. This said, I
don't plan to delete these 'apparent keywords' any time soon. I do plan
to remove the declare option.
(**) - Yes, need sanity checking to be sure users don't try to set
'option strings' via any of these user input files...
Subject: Re: User changes. yuqk / v4. Options re-work status.
Date: 13 Jun 2025 07:38:57
Message: <684c0dd1@news.povray.org>
There is a good reason these are identifiers and not keywords (any
more). The architecture had a lot of separation issues in POV-Ray 3.6,
MegaPOV and before that kept getting worse, and prohibited a lot of
features that are useful.
The most notable is that the scene and the rendering can be separated.
That is, you do not need to re-parse a potentially complex scene for
hours just the render it in a higher resolution. There isn't even a
reason to not move the camera after parsing (as the real-time
ray-tracing feature shows).
The main problem has always been that a GUI was never developed for
these features. So the question you probably want to ask yourself it if
it really makes sense to throw all this overboard for an extremely
complex command-line interface...?
Date: 13 Jun 2025 16:34:07
Message: <684c8b3f$1@news.povray.org>
> reason to not move the camera after parsing (as the real-time ray-
As always thank you for the background. I think I followed most of what
you wrote. I expect my inability to write clearly has led to some
confusion too. I'm sure too, I don't see all the obstacles I might
encounter or introduce as I try and complete this re-work...
It's also true my ideas for the user command-lind / ini 'options' in
this thread are some of the least developed / refined of my re-work effort.
As you know, the only method which doesn't require near-complete
re-parsing of scenes for each frame today is the rtr camera list one. It
might be the view internal code aspect is further along that my quick
read-overs have led me to think, but it's not something working today
for users beyond setting up an initial 'view' / camera view.
In other words, I'm not aware of any 'working method' to implement your
example of rendering a scene again at a higher resolution without
re-running the entire render - including too the cli/ini options parsing(*).
(*) You can distort each animation's frame images by twiddling with the
image_height and image_width identifier values if, for example, these
'pretend keywords' have been used to defined the camera. But, this
capability also touches on the exposure carried with the current
implementation.
What I'm re-working in these last couple months is setting more things
up in the options parsing which runs prior to the virtual front end
(vfe) starting. The 10 or 12 'pretend keywords' / identifiers like
image_width are set as vfe starts today. Nothing with respect to that
will change any time soon due the re-worked options.
In aiming to move the global_settings{} block stuff into the 'options'
cli/ini parsing code, for example, I am pushing more 'keywords' out of
the parser and into the options parsing as flags / ini-options where
they'll get digested once rather than for each frame as our code stands
today.
With respect to this thread in particular and the cli/ini declare=<id>=
option, I'm talking about changing / extending what today might be done
in an ini file with a set of lines like:
declare=Int00=111
declare=Int01=222
declare=Int02=333.456
and parsed during the options setting phase with, say,
'include_ini=MyInts.ini'.
With the planned approach in this thread it would become instead a file
with the lines:
Int00 111
Int01 222
Int02 333.456
and
+-ui_"MyInts.ini"
Except I can now type check the input values and they become something
read only accessible as global integers inside the parser (via parser
functions). There is, of course, some effective 'look up the value'
process whether done via a function call or parser identifier access.
Aside: Though I don't plan to go this way at present, a hybrid approach
is possible - whether declare=.=. or as this new alternate +-ui_ method
- nothing stops us from setting identifiers Int00, Int01 and Int02 to
integer values before the parser runs in addition to enabling the parser
function accessible method or even in place of it.
Lastly, I've only ever really used POV-Ray on linux/unix/aix systems.
I'm not familiar with the windows (or osx) POV-Ray GUIs and expect I'm
largely ignorant of most GUI support implications in general.
A reminder the yuqk fork is a linux/unix only v4 playpen - though
hopefully mac/osx compiles work too.
Bill P.
Date: 18 Jun 2025 14:46:36
Message: <6853098c$1@news.povray.org>
vfe is just a layer over the actual interface needed primarily for
Windows. The actual main in povmain.cpp contains a minimal viable
version of what is actually needed based on RenderFrontend, which does
have all the states needed:
SceneId CreateScene(...) // create as many as you like
   StartParser(SceneId, ...) // run as many as you like
   ViewId CreateView(SceneId, ...) // create as many as you like
     StartRender(ViewId, ...) // run as many as you like
You can run multiple parsers and multiple renders all at the same time.
Chris Cason implemented vfe originally based on my SimpleFrontend, which
provides a single scene, single render backward-compatible interface
because at the time we didn't have time to adapt the legacy GUIs.
Thorsten
Date: 19 Jun 2025 07:29:45
Message: <6853f4a9$1@news.povray.org>
Thank you Thorsten!
I'd worked out the SimpleFrontend was mostly not used while working on
the yuqk fork. However, given ALTMAIN, I took it as a, long ago,
intended, fall-back build from the platform dependent vfe
implementations(*).
Aside: The yuqk fork's simplefrontend.h is mostly commented today, but a
couple parts are necessary for vfe and the unix/linux build.
Bill P.
(*) - I've never gotten around to trying to get a build without vfe -->
unix & ALTMAIN going. Having a single threaded and minimal,
text-only(**) build would be useful / good to have.
(**) - 'text' is an option of unix/linux builds, but as the preview display.
Date: 19 Jun 2025 12:14:20
Message: <6854375c$1@news.povray.org>
It exists for a simple reason: That is what I used for a lot of early
development of 3.7, testing on a iBook (MacOS with PowerPC) and Windows
at the same time (but Chris did most of the Windows work).
Thorsten
