POV-Ray : Newsgroups : povray.pov4.discussion.general : Image changes. yuqk / v4. Options re-work status. Server Time
17 Sep 2025 03:08:01 EDT (-0400)
  Image changes. yuqk / v4. Options re-work status. (Message 1 to 1 of 1)
Subject: Image changes. yuqk / v4. Options re-work status.
Date: 11 Jun 2025 21:20:46
Message: <684a2b6e$1@news.povray.org>
The current output related option(s):
+-h  height                   integer  value only
+-w  width                    integer  value only
+-mi max_image_buffer_memory  integer  value only
become(s):
+-ih  image_height            integer  value only
+-iw  image_width             integer  value only
+-ibm image_buffer_max        integer  value only
Parsing code mostly there, nothing else.
Some ideas floating around about about fewer / different internal
storage formats which would likely drive new options in this
family/grouping.
One idea - mentioned a few places in the code by prior coders too - is
having r,g,b plus rt gt bt channels internally rather than only one
universal transmit (alpha channel) value as a result. It would likely
make easier limited compositing of individual features in a way which
would not fly well beyond the zero to one (represent-able) range. The
phong, specular features - for example - would use up each of the
individual transmit channels as they maxed out. (Yuqk has that
experimental 'intensity_max' finish feature which comes at the problem
in other ways).
An internal format which aligns more directly with our perceptual range
for intensities and/or display/print gamuts is attractive (on the
surface at least) too - especially when looking at some of the output
curves we might support with the avif image format for example.
Bill P.
