The current render related options:
+-rp render_pattern
+-rs render_block_step
+-bs render_block_size
+-c continue_trace
+-cc create_continue_trace_log
+-ec end_column (pct and integer specs)
+-er end_row (pct and integer specs)
+-sc start_column (pct and integer specs)
+-sr start_row (pct and integer specs)
(Single, hard coded color conversion to gry)
become:
+-r render on|off NEW
+-rp render_pattern integer value only
+-rbstp render_block_step integer value only
+-rbsz render_block_size integer value only
+-rc render_continue on|off
+-rcl render_continue_log on|off
+-rec render_end_column integer on|off plus value
+-rer render_end_row integer on|off plus value
+-rsc render_start_column integer on|off plus value
+-rsr render_start_row integer on|off plus value
+-rgm_ render_gry_method string value only NEW
(ci111,ci240,ci601,ci709,ci2020)
Aims / thinking :
- Mostly renaming.
- Adding flag indicating whether or not to run the render stage/module.
- Removing the percentage specifications for the start/end/col/row
options. I "think" the yuqk fork fixed the last of the bugs due trying
to accommodate the percentages and numbers on the same flag, but the
code remains ugly. If it's decided later this feature essential, another
set of flags which specifically supports it should be added.
- Biggest planned change is making the render/tracing color conversions
to grey select-able at render time. Including here perhaps a development
mode hard coding a dummy value - or, maybe, using the green channel
directly. Maybe look too, at something better than our current grey
weighted 'conserve_energy', for example.
- Off on the horizon is perhaps moving away from / extending or changing
the render block mechanism. Thinking about optimizations for the
'locality of references' and maybe a mode which skips blocks if they
exceeds some multiple of all the average time used to render blocks thus
far. I have in mind too multiple camera driven over-sampling methods
which won't work with the current render blocks mechanism. Dreaming...
Code wise, the parsing code itself for these is only partly done.
Bill P.
On 6/8/25 10:43, William F Pokorny wrote:
> +-r render
on|off NEW
Ugh. That line should have read:
+-render render on|off NEW
I think for the moment, I'll stop my status updates here. I'm now on the
edge of the work I have implemented, parsing code, wise.
Bill P.
