The current display related options:
+-d display
+-th dither (Same settings used for file output)
dither_method (strings as below)
display_gamma (srgb|bt709|bt2020|value)
-y, --preview
+-p pause_when_done
+-ep preview_end_size
+-sp preview_start_size
become:
+-d display =on|off
+-da display_alpha =on|off NEW
+-dbpc display_bits_per_channel integer value only NEW
+-dd display_dither on|off NEW
+-ddm_ display_dither_method string value only NEW
(b2|b3|b4|bn|bnx|at|bk|d1|d2|fs|jn|s2|s3|st)
+-dgc_ display_gamma_curve string value only NEW
(srgb|bt709|bt2020|linear|power)
+-dgv display_gamma_value float value only NEW
+-dgm_ display_gry_method string value only NEW
(ci111,ci240,ci601,ci709,ci2020)
+-dgs display_gry_scale on|off NEW
+-dm_ display_method string value only NEW
(x11,sdl,text)
+-dp display_pause on|off NEW
+-dpes display_preview_end_size integer on|off Value NEW
+-dpss display_preview_start_size integer on|off Value NEW
+-ds display_stdout on|off NEW PLAY
Initially I'll be mapping the above options back to existing
functionality. Setting up here for the longer term.
Aims / thinking :
- The alpha setting should show in the preview window too, but it's not
happening today. (Change here likely tangled in how partial image
renders are handled too with respect to image parts outside the partial)
- Setting up for a much more independent preview display module.
- Align the 'module' options reasonably well with an output (punch)
module option set.
- The gamma / dither options are relatively costly, especially, where
the frame renders are quick.
- Dithering for a preview display might well be different than that used
for file output headed to a printer.
- Setting up more generally for other additional correction curves (wide
gamut) with more value inputs.
- The preview display module/work could more easily use available gpus.
Other open source software is doing this.
- We have stdout (pipe out) capability today with the overloaded +o-
syntax, but thinking an implementation less tangled is better.
- The preview start and end stuff is really used only by the radiosity
code today. With modern computers there isn't much need for this sort of
mosaic preview. Capturing mosaic previews, however, is probably useful.
No options for this are defined as yet - though I have some ideas.
- The different grey conversions are configurable as build options today
in the yuqk code base. Plus, yuqk in using rgb channel intensities from
bt709 as the default configuration differs from the channel intensities
used by official POV-Ray which are near CCIR Recommendation 601-1, but
different. There are too wide gamut flavors out there, but not yet in
any POV-Ray version of which I'm aware.
- Thinking some about options for setting initial preview sizes
differing from the image size. Maybe window positioning too. Early
versions of POV-Ray had support for these as X11 based options.
- Thinking about a -into <window id> X11 capability. (About multiple
intos from multiple cameras truth be told... Using POV-Ray for cheap and
easy GUIs, but dreaming or having nightmares - not sure)
Code wise the parsing is mostly there, but nothing is wired up.
Bill P.
