The real time raytracing runs within the frame's context and is
therefore tangled with the animation mechanism.
The current animation related options:
+-k clock
+-ki initial_clock
+-kf final_clock
+-kfi initial_frame
+-kff final_frame
+-kc cyclic_animation
+-stp frame_step
+-sf subset_start_frame
+-ef subset_end_frame
pre_frame_command
pre_frame_return
post_frame_command
post_frame_return
become:
+-an animation boolean on|off NEW
+-anm_ animation_method string ValueOnly NEW
(default|clock_only|frame_only|camera_list)
+-ancv animation_clock_value float ValueOnly
+-anci animation_clock_initial float ValueOnly
+-ancf animation_clock_final float ValueOnly
+-anfv animation_frame_value integer ValueOnly
+-anfi animation_frame_initial integer ValueOnly
+-anff animation_frame_final integer ValueOnly
+-anl animation_loop boolean on|off
+-anfs animation_frame_step integer ValueOnly
+-ansfi animation_subset_frame_initial integer ValueOnly
+-ansff animation_subset_frame_final integer ValueOnly
+-anfprc_ animation_frame_pre_command string ValueOnly
+-anfprr_ animation_frame_pre_return string ValueOnly
+-anfpoc_ animation_frame_post_command string ValueOnly
+-anfpor_ animation_frame_post_return string ValueOnly
The current real time raytracing options:
+-rtr real_time_raytracing
+-kla clockless_animation
+-kc cyclic_animation (As used too by yuqk's rtr)
+-rtc real_time_capture
become:
+-ms movieshow bool On|Off
+-msm_ movieshow_method string valueonly
(camera_list, image file list, etc)
+-msl movieshow_loop bool On|Off
+-msfc movieshow_frame_capture bool On|Off
+-msfd movieshow_frame_delay float valueonly NEW
Here too just the options parsing part is coded.
We have this thing called real time raytracing - and to a degree it is.
Ours is purely camera list driven today. We are moving through a scene
by changing cameras within a fixed scene->frame(*). Or in yuqk, it can
be used to render and capture from say 6 different cameras within each
frame of a running animation. The kinda thing where in video editing
you'd finalize what camera views to paste together for a final video.
The camera list is created any time there are a list of camera{}s in a
scene. In non-animations or regular animations you'll get a multiple
cameras defined warning (and something about using the last one IIRC).
If you turn on 'clockless_animation' you can flip to the first in the
list an visa versa as a trick we can use today for command line
switching between two cameras.
Part of the idea in adding in these changes is to flesh out this
mechanism so that cameras from the list can be generally selected. And
this relates to the idea of allowing the definition of camera lists
prior to the parsing stage too.
Why 'movieshow'? Well the mechanism can, for example, be made to do flip
book animations from a list of image files. Or if rendering animation
frames, it could run a movieshow from the starting frame to the just
finished one to provide a preview animation without having to encode
anything as an animation. I'd like to create some sort of ms specific
clock value use-able with functions to enable more than just camera
movement. I think the mechanism can be more than it is currently.
Bill P.
Forgot the footnote...
(*) There is in the code the structure: scene->frame(->view). However,
the view related code looks to be more or less sitting there doing not
much. My guess is the view code was originally aimed at a camera list
like use too but was never fleshed out - but I'm guessing.
Bill P.
