POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 text{} fixes / changes. (yuqk R19 v0.6.13.0) Server Time
31 Jul 2025 16:20:41 EDT (-0400)
  Suggest v4.0 text{} fixes / changes. (yuqk R19 v0.6.13.0) (Message 1 to 1 of 1)
Subject: Suggest v4.0 text{} fixes / changes. (yuqk R19 v0.6.13.0)
Date: 26 Mar 2025 10:42:41
Message: <67e41261$1@news.povray.org>
I'm attaching yuqk fork documentation for its updated text{} object
implementation (text.txt). Most subjects have been touched upon in other
posts.
One not mentioned, is that the text{} and sphere{} objects have some new
trial type checking in the debug compile of yuqk. I acted on the idea
because text{} creates union{} or merge{} objects of single character
text{} objects. Users cannot get at the underlying text{} objects. This
means using text{TextID} isn't really correct - though it will mostly
(always?) work.
Using the sphere{} as another example, it's possible today to code
something like:
     #declare Light00 = light_source{...}
     #local SphereShiftedUp = sphere {Light00 translate ...}
and the parser will act on the light source identifier without complaint
as a generic object.
The thinking is, perhaps, setting the parser up so users can use an
object{} wrap where they don't care about the 'object' type being acted
upon, but a sphere{} wrap when they want to be sure it's really a sphere
identifier. Perhaps this a method of extending type checking over what
is available with yuqk's setidtypes.inc and id_type(_id) capability.
(The internal method for this uses a dynamic_cast though - which is
slow. Why this feature trial is only active in the debug compile of yuqk
- which is already slower due the extra sanity checking it does.)
Sinking into the detail a bit more, the identifier definition and
reference mechanisms today in the parser are less consistent than they
should be.
We have cases where users can reference previously defined identifiers
and modify only certain aspects of them creating a new object, texture
or feature in an object oriented way; other cases where, for example,
sphere{ID} is effectively the same as writing object{ID ...object
modifiers...} - and cases like warp{}s where we'd like to be able to
define an identifier for later reference but we cannot.
Bill P.
Download 'text.txt' (49 KB)
