POV-Ray : Newsgroups : povray.pov4.discussion.general : Addressing the secrete rotation in text{} object Server Time
24 Jun 2026 11:43:49 EDT (-0400)
  Addressing the secrete rotation in text{} object (Message 1 to 6 of 6)
Subject: Addressing the secrete rotation in text{} object
Date: 13 Mar 2025 14:05:31
Message: <67d31e6b$1@news.povray.org>
In an offline email exchange with jr, I drifted off into a discussion
(OK, it was more of a monologue) about how the text{} object has a
secrete rotation to avoid axis aligned numerical issues. The rotation is
the equivalent of a user specifying - always - 'rotate
<0.001,0.001,0.001>' on text{} objects.
It's something that was added to the parse code at some point. It's
there in v3.7 - probably earlier versions too. The v3.8 source added a
TODO note about trying to find some better approach.
For the next release of the yuqk fork (R19) I've currently reduced the
rotation to: 'rotate <0.0001,0.0001,0.0001>' as a longer trial, but I'm
having second thoughts (*).
After setting up some more formal test code, I'm left unsure of the best
way to proceed - in no small part because I don't know what really
caused the issues for which the patch was applied. If anyone remembers
anything, please pass it along.
I'm starting to think pulling the patch altogether might be a better
long trial. A user can always add the rotation. In fact, likely a
cleaner, more minimal rotation about just the z axis) when artefacts
show up.
Attached is an image and a yuqk scene file where I've set the thickness
of the text objects at 1e-6; Artifacts show up even at a thickness of
1.0. The rotation is effectively another issue that can bite or not
depending on many things. Centering the text{} object about the origin
lessons the chance the secret rotation will cause a problem.
The left render shows the result for the current secrete rotation of
<0.001,0.001,0.001>.
In the middle no secrete rotation is applied.
On the right, the current R19 rotation of <0.0001,0.0001,0.0001>. It
helps, but I think not in a way that really addresses the issue and, who
knows, maybe it's not large enough for the situation for which the patch
was added.
Bill P.
(*) - Another thing I played with was to add a counter / inverse
rotation in SDL to the secrete one in an attempt to get back to no
rotation. While it sometimes works, there is too much numerical noise in
rotating and un-rotating (on combining the two opposing matrices). The
overall results were less stable.
Download 'textsecreterotation.jpg' (22 KB) Download 'textsecreterotation.pov.txt' (2 KB)
Preview of image 'textsecreterotation.jpg'
Subject: Re: Addressing the secrete rotation in text{} object
Date: 13 Mar 2025 15:45:00
Message: <web.67d3358fa0286e0ad2a18eff25979125@news.povray.org>
I've certainly learned that you're not spelling that correctly.
It must be a small glandular thing.
Thanks for uncovering this and pointing it out.
It explains something that I've noticed and ignored, when messing up text via
the coincident surface phenomenon.  There's always been half of the text visible
in this sort of diagonal partition.  Since the text is actually rotated, albeit
by a small amount, this makes perfect sense.
- BW
Date: 13 Mar 2025 21:21:36
Message: <67d384a0@news.povray.org>
Oh my... I laughed out loud. +11  :-)
Bill P.
Date: 19 Mar 2025 00:38:57
Message: <67da4a61$1@news.povray.org>
> show up.
For the record.
After some testing where I did not see any axis aligned seams /
artefacts, I've decided to pull the text{} rotation patch from the
parser. This no-patch trial will start with release R19 of my yuqk
playpen fork rather than just making the rotation smaller.
Question.
Has anyone successfully used a true type collection (.ttc file) with
recent (V3.7/V3.8) official POV-Ray versions?
These always crash with the .ttc files I have easy access to. Namely,
large CJK collections. These are also not capturing multiple styles, but
region specific glyph differences - maybe that is somehow an issue for
the current code.
The support for .ttc files was always limited to the first packaged .ttf
font found in the collection. We have no ability to pick which font in a
collection gets used. I'm considering dropping support for reading true
type collection files near term in the yuqk fork, but if it is working
for others, maybe I leave it as is.
Bill P.
Date: 19 Mar 2025 03:55:00
Message: <web.67da77aaa0286e0ac342f2ec6cde94f1@news.povray.org>
hi,
> Question.
> the current code.
'msgothic.ttc' (eg) works for me (alpha.9945627, beta.2) while 'NotoSansCJK.ttc'
crashes, yuqk reports 'Invalid TT font headers...'.  looks like it all depends
on the people putting together the TTF/TTC file(s).
regards, jr.
Date: 19 Mar 2025 13:17:24
Message: <67dafc24$1@news.povray.org>
In an offline discussion, jr helped me work through my own confusion
with the .ttc support in POV-Ray.
I tried the 'CJK' .ttc fonts blindly on seeing the .ttc suffix.
Well, it turns out OpenType fonts also use the .ttc suffix and POV-Ray
doesn't support them. I didn't know. My Ubuntu distribution puts the
OpenType fonts in another directory:
/usr/share/fonts/opentype/noto/NotoSansCJK-Regular.ttc
rather than:
/usr/share/fonts/truetype/
but I didn't notice...
If you are on linux and have the .ttc collection in a personal directory
you can use the 'file' command:
file NotoSansCJK-Regular.ttc
and it will kick out text about the file. Part of which will includes
detail on the internal font types stored. For example:
NotoSansCJK-Regular.ttc: OpenType font collection data, 1.0, 10 fonts,
at 0x34 OpenType Font data, 16 tables, 1st "BASE"
or 'file LiberationMono-Regular.ttf' :
LiberationMono-Regular.ttf: TrueType Font data, 18 tables, 1st "FFTM",
30 names, Macintosh
So, I'm leaving the .ttc support in place with yuqk and I'll add yuqk
documentation that the POV-Ray support for .ttc files is only for
TrueType collections.
Bill P.
