POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 enable enhanced onion pattern. (yuqk R17 v0.6.11.0) Server Time
17 Sep 2025 03:07:04 EDT (-0400)
  Suggest v4.0 enable enhanced onion pattern. (yuqk R17 v0.6.11.0) (Message 1 to 1 of 1)
Subject: Suggest v4.0 enable enhanced onion pattern. (yuqk R17 v0.6.11.0)
Date: 15 Nov 2024 21:43:47
Message: <673806e3@news.povray.org>
Adding 'ip_form', 'ip_offset' and 'ip_raw_return' as options for the for
the scalar value 'onion' pattern. When no options are used the behavior
is unchanged.
The heart of the onion pattern is a distance from origin / center
function wrapped in an fmod(value,1) call. The fmod() call itself
creates a slight inconsistency due the general value modifier code using
a version too. One which has historically and, though revised in yuqk,
still skirts to 1+'numerical epsilon' in the fmod() call so '1' doesn't
disappear from the 0 to 1 value range returned.
Enabling 'ip_raw_return on' suppresses the internal fmod() call making
behavior more consistent with other patterns near the 1.0 multiples,
snapping back to 0.0 values - 99.99% of the time it will look the same.
The three internal pattern (ip_) functions together allow the internal
distance function to be used more generally and flexibly should folks
want to do it.
See attached images. The upper left being the traditional onion
translated +1 in z applied to a plane.
Bill P.
Download 'onionrewrtstory.jpg' (364 KB)
Preview of image 'onionrewrtstory.jpg'
