POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 updates to 'crackle ip_solid'. (yuqk R15 v0.6.9.0) Server Time
17 Sep 2025 03:28:16 EDT (-0400)
  Suggest v4.0 updates to 'crackle ip_solid'. (yuqk R15 v0.6.9.0) (Message 1 to 1 of 1)
Subject: Suggest v4.0 updates to 'crackle ip_solid'. (yuqk R15 v0.6.9.0)
Date: 15 Jun 2024 08:52:19
Message: <666d8e83$1@news.povray.org>
Attached scene and image files demonstrating suggested new features(*)
using crackle's solid mode.
The offset / 'ip_offset' in yuqk is fixed / changed so it is applied
just prior to the return of the pattern's value. This means unlike
official POV-Ray it works with the solid mode.
The yuqk fork has added 'ip_strength' and 'ip_raw_return' features.
The top row of the image shows the three noise generator options (1,2,3).
The middle row shows the three noise generator options (1,2,3), but now
using 'ip_strength <0,0,0> so that the cube centers running from -4,-4,0
to 4,4,0 (**) are used as seeds for Noise(). It shows especially the
weakness of the original perlin noise implementation(***) - middle, right.
The bottom row uses the default noise generator 2 always and:
   Left: ip_strength <0.5,0,0>
   Middle: ip_strength <0,2,0>  // can cheat >1 with solid mode
   Right: ip_repeat <2,2,0> ip_strength <0,0,0.7>
Bill P.
(*) - Additional features likely still to come, but work is stalled due
cache issue.
(**) - There are optimizations which make this statement a bit of a lie.
(***) - We are landing on the grid boundaries - the Noise() value range
only 0.459921 - 0.524583. An improved perlin noise implementation
exists, but it is not available in POV-Ray.
Download 'crkl_solid.pov.txt' (6 KB) Download 'crkl_solid_story.jpg' (270 KB)
Preview of image 'crkl_solid_story.jpg'
