Subject: On new directive to stop after parsing. A near term trick.
Date: 14 Mar 2024 19:22:18
Message: <65f386aa$1@news.povray.org>
I often stop POV-Ray after parsing by adding an #error directive:
#error "Stopping after parse"
at the very bottom of some scene description language (SDL) code.
It works but, with the disadvantage of setting a non-zero return code;
something which makes testing the parser harder.
I've a few times talked about adding a new (SDL) directive like '#exit
<rc value>', perhaps.
Well, while continuing to work through the ini options and command line
flags, I stumbled across the following trick. We can effectively run
just the command line, ini file and scene file parsing with the command:
povray scene.pov -d -p +wt0
Setting the thread count to zero causes POV-Ray to bail before rendering
with a clean, 0 return code - so long as nothing is otherwise wrong with
the scene set up.
It means I've got a better way to run parsing test cases and, should
anyone want to do it, you can use SDL as a sort of scripting language to
do other stuff.
The trick works too in v3.8 beta 2 and likely all recent, official
versions.
Bill P.
>[...], 0 return code - [...]
Ah nice, I always used -d +w0 +h0 -F, but then you get a render failed.
ingo
hi,
v nice, and thank you. I now have a "cleaner" 'povparse' alias.
regards, jr.
What is a 'non-zero return code', and what testing problems(s) does it cause
when using #error? I confess to complete ignorance of it :-/
Subject: Re: On new directive to stop after parsing. A near term trick.
Date: 27 Mar 2024 07:51:10
Message: <6604082e$1@news.povray.org>
Hi.
Programs - like POV-Ray - running within typical compute environments,
return a final integer value called a return code indicating how
'things' went.
With POV-Ray it's mostly:
0 - All is well.
1 - Some lessor user-ish exit or abort.
2 - Some more serious problem.
But, you can see other non-zero codes too. This more true in yuqk -
especially the debug compile.
An #error directive will cause POV-Ray to always return (1). Any testing
looking for "0 - All is well" (or !0), will always see a problem (or
not) if looking at just the return code(*) where '#error' the technique
stopping POV-Ray at the parsing stage.
With yuqk, close the X11 preview window with 'q' while the render is in
progress and you see a return code of (2).
With yuqk, close the X11 preview window, once the render is finished and
paused, using the 'x' symbol to close and you see a return code of
(139). Yes, that's a minor bug.
(*) - You can still check how things ran, but without the return code
giving you the easy answer up front, it means looking at various outputs
in some detail and checking whether what you expect to be there is, or
isn't.
Bill P.
Date: 27 Mar 2024 13:36:29
Message: <6604591d$1@news.povray.org>
A zero return code is an universal way that a procedure use to indicate
that it finished successfully. Any non-zero value indicate that there
was some error occurring.
Thanks guys. I learned something new!
Just out of curiosity: Where do these codes show up? Are they 'accessible' to a
typical (i.e. naive!) computer user in Windows?
I would guess that they're completely internal to source.
And once the code exits - the program is terminated. So it's gone.
But that makes me think about the possibility of writing those values to a file,
or to some sort of shell environment variable.
Then you could parse a scene, exit without rendering, and do some post-parse
processing with a shell command....
Date: 28 Mar 2024 10:35:42
Message: <6605803e$1@news.povray.org>
Most any place a compute working environment / locale has called a
executable program, it's the normal to return, 'return codes'. In my
Ubuntu Linux environment, the calling, work locale is my terminal where
I type 'povray ...' to call the POV-Ray executable program.
I can look at the return code by looking at a special environment
variable '?' which holds the return code of the command / program called
/ run. The '$' prefix extracts the current integer value.
Supposing the file boom.pov contains a single line: #error "Boom",
yuqk boom.pov
echo $?
returns something like:
=== [Parsing...] ==================================================
File 'boom.pov' line 2:
Parse Error:
Parse halted by #error directive: Boom
Fatal error in parser: Cannot parse input.
Render failed
pokorny:tmp$ echo $?
1
I don't know the equivalent to 'echo $?' in a window's command terminal,
but I'm sure there is one.
In testing, I'm using the new +wt0 trick and the return code value to
create bash testing scripts like:
#!/bin/bash
# Herein running series of POV-Ray (yuqk) commands with good flag usage
# looking for any of them to fail.
export YUQK_PARSE_ONLY="yuqkA -d -p +wt0"
if $YUQK_PARSE_ONLY version_only.pov >/dev/null 2>&1; then
echo "Pass case: version_only.pov"
else
RC=$?
echo "Pass case: version_only.pov FAIL rc=$RC"
exit $RC
fi
... 179 more tests of good flag usage follow
Bill P.
I was curious so played some more... It gets convoluted, please feel
free to ignore the rest.
This also works in my yuqk fork, though I doubt whether it will work for
official POV-Ray releases. Pretending the following is all on one line:
yuqk boom.pov fatal_error_command="echo \"Scene: <%s>
fatal_error_command. RC: <$?>\""
It uses the fatal_error_command facility of POV-Ray itself. The output
looks like:
==== [Parsing...] ==================================================
Parse Error:
Scene: <boom> fatal_error_command. RC: <0>
Render failed
However! The return code (RC) reported by the 'fatal command' is not for
the current running POV-Ray executable, but for the command previously
run from the terminal, which is currently running the POV-Ray executable.
The following pile of a command shows how return code values exist in
two locale environments here. The initial terminal and a second one the
fatal error command sets up. Again imagine it all on one line:
ls;yuqk boom.pov fatal_error_command="yuqk boom.pov;RC=$?;echo \"boom 2
RC=$RC\";echo \"Scene: <%s> fatal_error_command. RC: <$RC> and <$?> for
initial 'ls'\"";
The output is:
Parse Error:
Render failed
boom 2 RC=1
Scene: <boom> fatal_error_command. RC: <1> and <0> for initial 'ls'
Render failed
Yepper. The fatal error command is running yuqk with boom.pov a second
time just to capture the eventual return code - which the first running
version of yuqk has not yet set itself... :-)
hi,
> looks like:
> Parse Error:
> Render failed
can you use BE's "to file" idea ? ie write the exit / status code as last line
when 'all_file=true', perhaps.
regards, jr.
