POV-Ray : Newsgroups : povray.pov4.discussion.general : On new directive to stop after parsing. A near term trick. Server Time
2 Apr 2026 16:31:40 EDT (-0400)
  On new directive to stop after parsing. A near term trick. (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: On new directive to stop after parsing. A near term trick.
Date: 27 Mar 2024 13:36:29
Message: <6604591d$1@news.povray.org>
Le 2024-03-26 à 13:39, Kenneth a écrit :
> William F Pokorny <ano### [at] anonymousorg> wrote:
>> I often stop POV-Ray after parsing by adding an #error directive:
>> #error "Stopping after parse"
>> at the very bottom of some scene description language (SDL) code.
>> It works but, with the disadvantage of setting a non-zero return code;
>> something which makes testing the parser harder.
> What is a 'non-zero return code', and what testing problems(s) does it cause
> when using #error? I confess to complete ignorance of it :-/
A zero return code is an universal way that a procedure use to indicate
that it finished successfully. Any non-zero value indicate that there
was some error occurring.
Date: 27 Mar 2024 19:30:00
Message: <web.6604ab8dca6c83fa9b4924336e066e29@news.povray.org>
Thanks guys. I learned something new!
Just out of curiosity: Where do these codes show up? Are they 'accessible' to a
typical (i.e. naive!) computer user in Windows?
Date: 28 Mar 2024 06:55:00
Message: <web.66054c28ca6c83fa1f9dae3025979125@news.povray.org>
I would guess that they're completely internal to source.
And once the code exits - the program is terminated.  So it's gone.
But that makes me think about the possibility of writing those values to a file,
or to some sort of shell environment variable.
Then you could parse a scene, exit without rendering, and do some post-parse
processing with a shell command....
Date: 28 Mar 2024 10:35:42
Message: <6605803e$1@news.povray.org>
Most any place a compute working environment / locale has called a
executable program, it's the normal to return, 'return codes'. In my
Ubuntu Linux environment, the calling, work locale is my terminal where
I type 'povray ...' to call the POV-Ray executable program.
I can look at the return code by looking at a special environment
variable '?' which holds the return code of the command / program called
/ run. The '$' prefix extracts the current integer value.
Supposing the file boom.pov contains a single line: #error "Boom",
	yuqk boom.pov
	echo $?
returns something like:
=== [Parsing...] ==================================================
File 'boom.pov' line 2:
Parse Error:
Parse halted by #error directive: Boom
Fatal error in parser: Cannot parse input.
Render failed
pokorny:tmp$ echo $?
1
I don't know the equivalent to 'echo $?' in a window's command terminal,
but I'm sure there is one.
In testing, I'm using the new +wt0 trick and the return code value to
create bash testing scripts like:
#!/bin/bash
# Herein running series of POV-Ray (yuqk) commands with good flag usage
# looking for any of them to fail.
export YUQK_PARSE_ONLY="yuqkA -d -p +wt0"
if $YUQK_PARSE_ONLY version_only.pov >/dev/null 2>&1; then
     echo "Pass case: version_only.pov"
else
     RC=$?
     echo "Pass case: version_only.pov   FAIL  rc=$RC"
     exit $RC
fi
... 179 more tests of good flag usage follow
Bill P.
I was curious so played some more... It gets convoluted, please feel
free to ignore the rest.
This also works in my yuqk fork, though I doubt whether it will work for
official POV-Ray releases. Pretending the following is all on one line:
yuqk boom.pov fatal_error_command="echo \"Scene: <%s>
fatal_error_command. RC: <$?>\""
It uses the fatal_error_command facility of POV-Ray itself. The output
looks like:
==== [Parsing...] ==================================================
Parse Error:
Scene: <boom> fatal_error_command. RC: <0>
Render failed
However! The return code (RC) reported by the 'fatal command' is not for
the current running POV-Ray executable, but for the command previously
run from the terminal, which is currently running the POV-Ray executable.
The following pile of a command shows how return code values exist in
two locale environments here. The initial terminal and a second one the
fatal error command sets up. Again imagine it all on one line:
ls;yuqk boom.pov fatal_error_command="yuqk boom.pov;RC=$?;echo \"boom 2
RC=$RC\";echo \"Scene: <%s> fatal_error_command. RC: <$RC> and <$?> for
initial 'ls'\"";
The output is:
Parse Error:
Render failed
boom 2 RC=1
Scene: <boom> fatal_error_command. RC: <1> and <0> for initial 'ls'
Render failed
Yepper. The fatal error command is running yuqk with boom.pov a second
time just to capture the eventual return code - which the first running
version of yuqk has not yet set itself... :-)
Date: 29 Mar 2024 13:10:00
Message: <web.6606f514ca6c83fa1686e436cde94f1@news.povray.org>
hi,
> looks like:
> Parse Error:
> Render failed
can you use BE's "to file" idea ?  ie write the exit / status code as last line
when 'all_file=true', perhaps.
regards, jr.
Date: 29 Mar 2024 18:03:52
Message: <66073ac8$1@news.povray.org>
I think not reliably from within POV-Ray itself(a).
Some events, like segmentation faults, are being generated by libraries
in use by POV-Ray and they are, more or less, crashing the program in a
way the operating system ends up handling.
(a) - The 0, 1, 2 return codes are ones handled by POV-Ray itself and
these could be written to stderr / cerr prior to exit, but not to one of
the output streams as defined and handled by POV-Ray.
In Unix environments we can today do this:
yuqk boom.pov;echo "yuqk return code is: $?";
or
povray boom.pov;echo "povray return code is: $?";
or
povray boom.pov;export POVRAY_RC=$?;
'yuqk' is really a wrapper script around the yuqk fork's 'povray'
executable where the last line is 'exit $?' to pass the return code back
to the calling process. That wrapper could be modified to output to
always write out a status line with the return code to the terminal - or
to a file.
The yuqk fork has a getenv() function so you could run another SDL .pov
file which does something with a YUQK_RC environment variable.
unset YUQK_RC;yuqk boom.pov;export YUQK_RC=$?;yuqk getenv.pov -d -p;
Where getenv.pov contains:
#debug concat("The return code is: ",getenv("YUQK_RC"),"\n")
and then the second yuqk will print: "The return code is: 1".
Rather than a #debug statement, that could be a #write I guess doing
more stuff based on the value.
I don't know how to handle self generated return codes with only one
call to the 'povray' executable.
Bill P.
Date: 31 Mar 2024 07:35:00
Message: <web.660949d0ca6c83fa1686e436cde94f1@news.povray.org>
hi,
was / am thinking documentation.  it would have been handy to read (at the end
of 'alltext.out') whether there were warnings and or (non-library) errors.
> The yuqk fork has a getenv() function ...
interesting.  what use case do you have in mind ?  (un)set in-scene "flags" ?
not sure I understand, the "(a)" above would do though, aiui.
regards, jr.
Date: 31 Mar 2024 08:57:39
Message: <66095dc3$1@news.povray.org>
Short on time this morning. First, remember alltext.out (all_file) is
just echoing the five other actual console streams to a single file.
The set up was >5 output streams, down to five today. In those five
there is a warning stream and a fatal / error stream. Those latter two
do capture all the warnings and errors to files if you set up your run
that way. Those two files will be empty if all is well and otherwise
have all the warnings and errors captured by POV-Ray.
We don't count warnings today which is an interesting idea.
Nothing too specific. One thought was to enable POV-Ray to query the
process environment from which it was called. USER, USERNAME, LANG,
HOME, ...
I think you are suggesting SDL capability to set and unset environment
variables too?  If so, I thought about. It is, though, a capability
which could cause quite a bit of trouble.
I can look at doing (a). What I do not know at the moment is where
stdout / stderr are go as compared to where +o- image output goes. I
suspect, the optional image output is using stdout so I could use stderr
for the 0, 1 or 2 return codes. If so, zero return code result messages
would end up on stderr which is a little off.
Anyhow, got to run.
Bill P.
Date: 15 Apr 2024 13:30:00
Message: <web.661d6361ca6c83fa1dbe6626f712fc00@news.povray.org>
>   povray scene.pov -d -p +wt0
> Setting the thread count to zero causes POV-Ray to bail before rendering
> with a clean, 0 return code - so long as nothing is otherwise wrong with
> the scene set up.
> It means I've got a better way to run parsing test cases and, should
> anyone want to do it, you can use SDL as a sort of scripting language to
> do other stuff.
> The trick works too in v3.8 beta 2 and likely all recent, official
> versions.
> Bill P.
-d -p +wt0 works on my win3.7 version just put it in the command box and run
Great Trick!
Date: 15 Apr 2024 22:50:01
Message: <661de759$1@news.povray.org>
On 4/15/24 13:26, Leroy wrote:
> Great Trick!
Hi Leroy,
I'm glad I stumbled across it. Now that I've got this easier way to test
ini files and command line flags, I'm finding quite a bit of stuff in
need of fixing!
Bill P.
