On 9/15/23 07:10, And wrote:
> I haven't used povr yet.
> I found that your image (top row) are similar to the deform of the IsoWood
> include files of Christoph Hormann.
> The bottom row is interesting, too.
I played a little with the IsoWood macros a 'long' time ago and have a
copy somewhere, but I don't recall what pattern / functions were used
for the wood patterning - thanks for the info on the look of it in
comparison.
I've been following your 'wood work' programming effort. I confess to
more or less thrashing around, pushing here and there, on what can be
done and only sometimes with 'wood' grain specifically in mind.
Yes, the approach in the bottom row is to start with an internal
turbulence scaled small to make the rings just a little bit noisy as
they go around - and then on top of that to layer one or more additional
warp turbulences at larger scales to get a more complete wood pattern look.
This turbulence layering approach is difficult with the old style 'wood'
because it has those fixed, positional harmonics. It's too easy to push
the 'favorable' portion of the pattern off of the surface being textured.
I'm starting to look now at pushing into the warp{} mechanisms with
thoughts toward a re-work of the underlying functionality of that code.
In the povr fork, I have quite a few fixes and additions hacked into
that code over what is in official POV-Ray releases, but it's all
'hacked in'. I'd like to refined what's there into something better.
Anyhow... I'll attach another image using the povr updated 'wood' as the
base pattern - not really aimed to be anything in particular. It's a
test image for other features as much as the changed 'wood', but I think
it looks interesting.
Using it_* turbulence and warp{it_* ...} turbulence with emitting,
media{density{density_map{...}...}}.
Oh, the containing shape is an isosurface based upon povr's inbuilt
f_toupie() function. Here with options forming a shape somewhat like a
spinning top. It's thicker in the middle, thinning as it moves out from
the center before thickening into an outer torus at the edges.
Bill P.
Download 'woodturbtest.png' (472 KB)
Preview of image 'woodturbtest.png'
> comparison.
Ha... I explored the concept (deform, growth rates, knots, etc) separately. I
would like integrate them. But I don't have enough ability on developing a
program. I just learn it by DIY.
Thank you. I feel encouraged.
I cannot understand it very well.
> Bill P.
I noticed that povr is running on Linux. I don't have much ability on
C/C++,(additional I'm learning another thing) so I'm not trying it. I will try
it in the future or waiting the integration with official POV-Ray version.
Are you have facebook? I have searched(a little) people on this newsgroup. I
have found you. I think that I ought to add people on facebook, otherwise I
cannot imagine any character about people here.
https://www.cs.cornell.edu/~srm/publications/SG05-wood-lr.pdf
https://www.cs.cornell.edu/~srm/publications/SG05-wood.html
has a link to a tar/gz archive with code. :)
* woodreflectance.sl -- wood (anisotropic)
* DESCRIPTION:
* Simple wood shader, driven by four textures:
* RGB diffuse color
* RGB fiber (anisotropic highlight) color
* x,y,z of unit vector giving local fiber orientation in local
* coordinates
* beta, a "roughness" parameter to control width of highlight.
* If any of these files is not specified, we fall back on a
* uniform parameter. So far, every map has had uniform beta.
* PARAMETERS:
* diffuse_texture: name of file containing 3-channel texture
* modulating color across the patch.
* fiber_texture: name of file containing 3-channel texture
* modulating fiberColor across the patch. This map is divided by
* 20 because it generally contains values greater than 1, which
* would be clamped in an integer pixel format.
* axis_texture: name of file containing 3-channel texture
* modulating fiberAxis across the patch. Values are mapped
* [0:max] -> [-1:1] for each component, since most image file
* formats are unsigned.
* beta_texture: name of file containing 1-channel texture
* modulating beta across the patch.
* eta: Index of refraction of surface finish. Used to modulate
* highlight and subsurface with varying angle. eta=0 used to
* signal absence of overcoat.
* color, fiberColor: fallback diffuse and directional colors if
* texture is missing
* fiberAxis: fallback fiber direction if texture is missing
* beta: width of subsurface highlight if texture is missing
* roughness: width of surface (white) highlight
* Ka, Kd, Ks: normal Renderman coefficients. Ka and Kd modulate the
* diffuse component (parameter "color"), and Ks is a fudge factor
* on the surface (white) highlight.
* ANTIALIASING: provided by texture lookup
* REFERENCE: Stephen R. Marschner, Stephen H. Westin,
* Adam Arbree, and Jonathan T. Moon,
* "Measuring and Modeling the Appearance of
* Finished Wood", SIGGRAPH 2005
* AUTHOR: written by Stephen H. Westin,
* Cornell University Program of
* Computer Graphics
* last modified by $Author: westin $
* VERSION: $Revision: 1.2 $
* HISTORY:
* $Log: woodreflectance.sl,v $
* Revision 1.2 2005/05/10 20:02:15 westin
* Modified to use 4 TIFF texture maps rather than a single
* 10-channel map.
* Revision 1.1 2005/05/09 21:10:18 westin
* Working version of shader; used for animation on Proceedings DVD-ROM.
surface
woodreflectance ( float Ka = 1.0,
Kd = 1.0,
Ks = 1.0;
float eta = 1.5;
vector fiberAxis = ( 1, 0, 0 );
float beta = .1745; /* 10 degrees -> radians */
color fiberColor = color ( 1, .6, .4 );
string diffuse_texture = "",
fiber_texture = "",
axis_texture = "",
beta_texture = "";
float minU = 0, maxU = 1,
minV = 0, maxV = 1,
roughness = 0.2; )
uniform float sqrt2pi = 2.5066283;
vector local_z; /* Surface normal in "world" space */
vector local_x, local_y; /* Unit vector in "u" and "v" directions */
normal Nf = faceforward (normalize(N), I); /* Forward-facing normal */
vector V = normalize(I); /* Normalized eye vector */
color diffuseColor, highlight;
vector axis;
float tx_beta;
vector ssInDir, ssOutDir; /* Light and eye vector, possibly refracted */
float thInPrime, thOutPrime;
float halfAngle, diffAngle;
float fiberFactor, geometryFactor;
float Kr, Kt; /* for output of fresnel() */
float ssAtten; /* Attenuation from going through the smooth interface twice */
/* Get local coordinate system in terms of native
parameters (u,v). We should really use (s,t). */
local_z = Nf;
/* Get unit vector in "u" parameter direction */
local_x = normalize ( dPdu );
/* Get final local basis vector y perpendicular to x and z. */
local_y = local_z^local_x;
/* If there is a clear overcoat, calculate refraction direction and
attenuation. */
if ( eta != 1.0 ) {
vector Rdir; /* Dummy */
fresnel ( V, Nf, 1.0/eta, Kr, Kt, Rdir, ssOutDir );
ssOutDir = -ssOutDir;
// Use (1-Kr) rather than Kt, because we are dealing with power,
// not radiance.
ssAtten = 1 - Kr;
} else {
ssOutDir = -V;
ssAtten = 1.0;
normalize(ssOutDir);
color axisTemp;
float ourS = minU + u * (maxU - minU),
ourT = minV + v * (maxV - minV);
// Get parameters locally from texture maps, if available
if ( diffuse_texture != "" )
diffuseColor = color texture ( diffuse_texture, ourS, ourT );
else
diffuseColor = Cs;
if ( fiber_texture != "" )
highlight = color texture ( fiber_texture, ourS, ourT ) * 20;
else
highlight = fiberColor;
if ( axis_texture != "" ) {
axisTemp = color texture ( axis_texture, ourS, ourT )
*2 - 1.0;
/* Transform to local coordinate system */
axis = comp ( axisTemp, 0 ) * local_x
- comp ( axisTemp, 1 ) * local_y
+ comp ( axisTemp, 2 ) * local_z;
else
axis = comp ( fiberAxis, 0 ) * local_x
+ comp ( fiberAxis, 1 ) * local_y
+ comp ( fiberAxis, 2 ) * local_z;
normalize(axis);
if ( beta_texture != "" )
tx_beta = float texture ( beta_texture, ourS, ourT );
else
tx_beta = beta;
thOutPrime = asin ( ssOutDir.axis );
/* Calculate anisotropic highlight for each light */
Ci = 0;
illuminance ( P, Nf, PI/2 /* Hemisphere */ ) {
float dummy, ssAttenOut;
vector Ln = normalize ( L );
/* Refract at smooth surface */
if ( eta != 1.0 ) {
vector Rdir; /* dummy */
fresnel ( -Ln, local_z, 1.0/eta, Kr, Kt, Rdir, ssInDir );
// not radiance.
ssAttenOut = 1 - Kr;
} else {
ssInDir = -Ln;
ssAttenOut = 1.0;
float ssFactor = max ( 0, -ssInDir.local_z ) * ssAtten*ssAttenOut;
thInPrime = asin ( -ssInDir.axis );
halfAngle = thOutPrime + thInPrime;
diffAngle = thOutPrime - thInPrime;
// Compute value of Gaussian at this angle
fiberFactor = tx_beta * exp ( -pow(halfAngle/tx_beta,2)/2 )
/ sqrt2pi;
float cosIncline = cos(diffAngle / 2);
geometryFactor = 1 / pow ( cosIncline, 2 );
fiberFactor *= geometryFactor;
// Add in diffuse term, attenuated by surface term.
Ci += Cl * Kd * diffuseColor * ssFactor;
// Add in fiber highlight, also attenuated.
Ci += Cl * fiberFactor * highlight * ssFactor;
/* Second Fresnel call is for strength of surface highlight */
vector H = normalize ( -V + Ln );
fresnel ( V, H, 1.0/eta, Kr, Kt );
// Blinn/Phong highlight with Fresnel attenuation
Ci += Cl * Ks * Kr
* pow ( max ( 0, H.local_z ), 1/roughness );
Ci += Ka * diffuseColor * ambient();
