POV-Ray : Newsgroups : povray.pov4.discussion.general : Thoughts on 'keyword_status()' functionality for v4.0. Server Time
14 Jun 2026 07:20:10 EDT (-0400)
  Thoughts on 'keyword_status()' functionality for v4.0. (Message 1 to 7 of 7)
Subject: Thoughts on 'keyword_status()' functionality for v4.0.
Date: 26 Mar 2023 01:58:10
Message: <641fdef2$1@news.povray.org>
In working recently with the povr fork to restore v3.7, v3.6 and prior,
ID only checking behavior with the #ifdef(), #ifndef() and defined()
keywords, the subject of keyword status checking in SDL came up again.
I've looked at the reserved word warning code in v3.8 and on.
Plus I've been thinking about the bigger picture of actual keywords,
possible keywords, stand in internal keywords used for other purposes
and functions. We have too the ini keywords and flags.
As an initial proposal thinking about a new 'keyword_status()' function
passed strings like "tau". It would return the following values for the
status of various strings in answer to what meanings are relative to the
version of code being run.
-5 ==> ini keyword (cmd line flag ?) setting removed.
-4 ==> lower case, shipped function looking like something inbuilt.
-3 ==> deleted inbuilt function formerly defined in functions.inc.
-2 ==> pseudo / hidden keyword removed.
-1 ==> formerly visible and usable keyword removed.
  0 ==> not now and never a keyword. Good to go.
+1 ==> active SDL keyword.
+2 ==> pseudo / hidden keywords active or potentially active on config.
+3 ==> inbuilt function declared in functions.inc or cfunctions.inc.
+4 ==> (povr never fakes inbuilt, lower case keywords with functions)
+5 ==> current ini keyword (cmd line flag?) setting.
(+-5 checking would be case insensitive)
Actual keyword support in SDL is more complex because the meaning of
keywords changes over time as functionality is added, removed or
changed. Not thinking to try and document any of that drift in usage
detail over time with keyword_status().
The central aim is giving users a greater ability to check whether using
any particular 'word' / 'keyword' in a scene has the potential to cause
trouble or confusion.
Thoughts?
Bill P.
Subject: Re: Thoughts on 'keyword_status()' functionality for v4.0.
Date: 26 Mar 2023 15:25:00
Message: <web.64209b8eb21c98d01f9dae3025979125@news.povray.org>
> Thoughts?
I don't quite know what a few of those mean, but let me add some ideas here.
> The central aim is giving users a greater ability to check whether using any
 has the potential to cause trouble or confusion.
Yes.   And to that end, I would suggest a sort of stratifying - much like one
might do with memory, line-numbered code, or any other hierarchical structure.
So I don't really get why  -5 is where it is.
I would probably use it (often) if I could run a simple
#if (keyword_status() > Threshold) check.
So one thing to think about would be to space the values out a bit, so that you
can fill in other things that come up as time goes on.
-BW
Date: 27 Mar 2023 07:15:00
Message: <web.64217a68b21c98d04301edef6cde94f1@news.povray.org>
> Thoughts?
like BE I'm a little bewildered by the .. variety :-)  I think that this whole
issue needs to be tied in with the (proposed) 'versions.inc' and id type
checking/testing; all aspects of the same goal, imo.
regards, jr.
Date: 27 Mar 2023 16:16:29
Message: <6421f99d$1@news.povray.org>
I'm now leaning toward the function name 'word_is()' because it leaves
open the possibility for similarly named extensions.
I should perhaps have left the return value detail for later -
especially given I'm still sorting it out.
Most day to day usage would be simple:
#declare MyStr = "lockandkey"
#if (word_is(MyStr)=0)
    #debug concat("No usage conflicts for '",MyStr,"'.\n")
//--- or
#if (word_is(MyStr)!=0)
    #debug concat("Usage conflicts exist for '",MyStr,"'.\n")
//--- or
#if (word_is(MyStr)>0)
    #debug concat("'",MyStr,"' is a part of this POV-Ray version.\n")
Bill P.
Date: 27 Mar 2023 16:23:46
Message: <6421fb52$1@news.povray.org>
On 3/27/23 07:13, jr wrote:
> like BE I'm a little bewildered by the .. variety 😄  I think that this whole
At code bottom there is a lot of detail, but I hope day to day users can
ignore most of it. :-)
My aim is for this new functionality to be in usable alongside / along
with the version.inc and setidtypes.inc proposals.
Bill P.
Date: 27 Mar 2023 17:35:00
Message: <web.64220b78b21c98d01f9dae3025979125@news.povray.org>
I can imagine it will take a bit of sorting.
Speaking of sorting, I'm thinking that it would be a handy thing for devs,
example scenes, documentation, and the kind of oddball experiments that people
like me conduct - to have all the keywords numbered, just like the internal
functions.
That would allow easily iterating through them all to check them by number, and
not be as subject to human error of, "I forgot that one."  I can envision that
depending on the kind of code one is writing, it would be a lot easier and more
compact to simply switch the argument of a master keyword directive that takes
an argument, like keyword (1).  If you had keyword_name (), then you could just
run a loop and do
word_is(keyword_name(keyword(index))).
Date: 30 Mar 2023 16:13:38
Message: <6425ed72@news.povray.org>
> functions.
Given the code base, we currently need to avoid fixed number to keyword
associations. While the number to inbuilt function name associations are
more stable than the number to keyword ones, as a soft rule, none of the
associations are fixed until the code's compile and link is complete.
We can create indirect 'type' to number associations at parse time in
the form of a dictionary for a particular executable. We do this in povr
within the shipped setidtypes.inc file.
You and jr have both suggested, being able to work with a keyword
'index' of some kind as a way to, say, maintain documentation in a
database. A good idea. Today the database keys need to be strings(a).
The next release of povr (R7 v0.6.1) implements two new SDL functions in
word_is() and word_get(). These access and make use of 18 internal
arrays of token information relative to the active version of
POV-Ray(povr). The 18 arrays break down into three categories.
Previous tokens (back to through v3.6) which are out (o prefix); Tokens
included in the current code (i prefix); Lastly, tokens which are new (n
prefix) compared to the prior major release (v3.8 beta 2). See the,
initial, attached text documentation for more detail.
The aim, for me as much as anyone, is to create methods for the
POV-Ray(povr) executable to provide initial hooks / 'string indexes' for
creating and maintaining documentation; Methods for doing parse time
checks for active keywords, directives, functions, etc.
Aside: In doing this work, I turned up that, at povr's v3.8 branch
point, there was a new keyword called cmap related to ttf text objects.
On the parser back up for the v3.8 release, 'cmap' got dropped. I need
to sort out what to do with 'cmap' for povr as it's something new that I
didn't know was in my povr fork! (It's probably still in the v4.0 code
base too, but I did not check)
Bill P.
(a) - Even string / token indexing comes with complications.
Directives, for example, still, mostly, come in two forms as with
'version' and '#version'. Some like #default are not really SDL
directives and should be coded as default{}.
A new to v3.8 feature like global and local dictionaries, made use of
the the token 'global' which had been used with photons in earlier
POV-Ray versions - depending upon compile time options. Knowing there is
a 'global' token is a good start, but, then there is the detail. We all
know, quite a few keywords have multiple uses / applications.
Back to v3.6 at least there were functions coded up in various shipped
include files that, by name, look like lower case inbuilt keywords or
functions. I've either replaced these with true inbuilt forms - so
behavior is not dependent on included files - or I've deleted the lower
case function code and created versions with upper case characters so it
is clear the functionality is NOT inbuilt, but is being declared
somewhere. For example, a function 'even()' was long defined in
math.inc. With povr it is now F_even() and defined in munctions.inc
calling M_even() if need be. M_even() being a shipped, 'munction', a
macro defining & compiling a global function, once, on need.
It's simple except where it's complicated. :-)
Download 'word_is__word_get.txt' (5 KB)
