POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 inbuilt complex functions. (povr R7 v0.6.1.0) Server Time
15 Oct 2026 00:36:18 EDT (-0400)
  Suggest v4.0 inbuilt complex functions. (povr R7 v0.6.1.0) (Message 1 to 11 of 11)
Subject: Suggest v4.0 inbuilt complex functions. (povr R7 v0.6.1.0)
Date: 9 Mar 2023 18:39:31
Message: <640a6e33$1@news.povray.org>
In the past few years Ingo, Tor Olav and others have played around with
include files supporting complex numbers for sound and images. Attached
is an image using a few of 30 plus inbuilt complex functions added to
the povr fork. Mostly just wrapping the complex functions coming with
C++11, but sometimes using function names more in line with the existing
complex includes and POV-Ray's function naming.
In povr, to work with the existing function vm, packing two 32 bit
floats into a double space as the complex value and all complex function
code runs at single float accuracy.
The render takes advantage of povr's big jitter and v3.8's ability to
write png files at a reduced bit depth; I used +fn4 to get the file size
down to something reasonable. Given the detail the image doesn't
compress well.
Bill P.
#include "functions.inc"
#include "cfunctions.inc"
#declare Fn00 = function { f_hash(y,Seed00,0.0005,0) }
#declare Pigm00 = pigment {
     function {
         Fn00(
             cf_real(cf_pow(cf_cmplx(abs(x),y),cf_cmplx(4.4,0))),
             cf_imag(cf_pow(cf_cmplx(abs(x),y),cf_cmplx(4.4,0))),
             z)
     color_map {
cf_abs, cf_acos, cf_acosh, cf_add, cf_asin, cf_asinh, cf_atan,
cf_atanh, cf_cmplx, cf_conj, cf_cos, cf_cosh, cf_div, cf_exp,
cf_imag, cf_inv, cf_ln, cf_log, cf_mul, cf_neg, cf_norm, cf_phase,
cf_polar, cf_pow, cf_proj, cf_real, cf_sin, cf_sinh, cf_sqr,
cf_sqrt, cf_sub, cf_tan, cf_tanh
Download 'kaboom.png' (230 KB)
Preview of image 'kaboom.png'
Subject: Re: Suggest v4.0 inbuilt complex functions. (povr R7 v0.6.1.0)
Date: 9 Mar 2023 20:55:00
Message: <web.640a8d241005ebef9b4924336e066e29@news.povray.org>
I like the image itself, it's a very artistic-looking render. Like a painting.
Date: 10 Mar 2023 05:08:23
Message: <640b0197@news.povray.org>
Thanks. :-)
I'll attach another I liked while playing. Same set up with complex
functions, but much lower power exponents. Plus adding in some spiral
action in the middle.
Another bit I stumbled across working with cf_pow() 'warping' is the
effective change in scaling from the origin outward makes it pretty easy
to set up images which change from a near constant color away from the
origin to something where the f_hash()-ing is clear.
In other words, when the changes in region due the f_hash(), and/or
higher cf_pow exponents, are happening at >>1 per pixel we end up with
kind of an aggregate color. As we move to the origin things spread out
and and we get a fade-in effect. FWIW, I guess, but neat. Hints at a
possible general technique with on top of f_hash() for fading in or out
of near constant colors.
Bill P.
Download 'kaboomkeep3.jpg' (498 KB)
Preview of image 'kaboomkeep3.jpg'
Date: 10 Mar 2023 07:11:35
Message: <640b1e77$1@news.povray.org>
Op 10-3-2023 om 11:08 schreef William F Pokorny:
>> painting.
> Thanks. :-)
> Bill P.
Ooh! This one is nice! Going to download it: could be useful for
something ;-)
Date: 11 Mar 2023 04:17:19
Message: <640c471f@news.povray.org>
> something 😉
:-) How about a POV-Ray, user ink blot test image?
"That Looks like an ink blot test," is what I thought on getting the
result - and I'm never letting you all know I see in there! ;-)
Here again a complex function 'warp' acting on a small portion of a
photograph; where I also used those undocumented / hidden, image_map,
repeat and offset options.
Bill P.
Download 'povrayinkblottest.jpg' (409 KB)
Preview of image 'povrayinkblottest.jpg'
Date: 11 Mar 2023 07:15:41
Message: <640c70ed$1@news.povray.org>
Op 11-3-2023 om 10:17 schreef William F Pokorny:
>> something 😉
LOL! I wont either! ;-)
Fascinating stuff indeed.
Date: 15 Mar 2023 12:10:00
Message: <web.6411eda81005ebef9b4924336e066e29@news.povray.org>
That is really interesting and fabulous! I can imagine all sorts of
different-looking and visually unexpected results from using this technique.
One possible use would be for texturing the walls in a room-- like wall paper.
Or for creating designs for floor rugs and carpets.
Date: 28 Apr 2023 04:10:08
Message: <644b7f60$1@news.povray.org>
Sorry to re-open this old discussion. I didn't know this pov4 group exist :(
Anyway, i too have worked a lot in the world of complex numbers. I
started to write a macro library that implements complex functions using
povray "function".
And so: is "cfunctions.inc" just an encapsulation of C functions ?
Does v4 include a new data type like c = <re,im> with the possibility to
access c.re and c.im ?
I'm attaching my "complex_functions.inc" just in case ... I continue to
develop it or I wait for v4 ?
last thing : where can I find "cfunctions.inc" ?
Kurtz le pirate
Compagnie de la Banquise
Download 'complex_functions.inc.txt' (34 KB)
Date: 28 Apr 2023 10:15:00
Message: <web.644bd3b81005ebef58c093306cde94f1@news.povray.org>
hi,
installs as part of 'povr' branch (published in p.b.programming)
regards, jr.
Date: 29 Apr 2023 02:28:40
Message: <644cb918$1@news.povray.org>
On 28/04/2023 16:10, jr wrote:
> hi,
> regards, jr.
Find. Thank jr
But as I suspected, the functions are just calls to internal functions.
so I will continue my work
Kurtz le pirate
Date: 29 Apr 2023 04:20:13
Message: <644cd33d$1@news.povray.org>
On 4/29/23 02:28, kurtz le pirate wrote:
>> hi,
>> regards, jr.
> Find. Thank jr
Glad you found your path forward (jr, thanks for providing the pointer
to the include file).
Thanks for posting your complex function include!
I'd looked at Tor Olav's and Ingo's include file efforts in this
direction as I coded up the C++11 complex function wrappers, but I
didn't have yours in hand. I've stored a copy as a reference in my work
directory so I have it should I come back for more play.
Bill P.
--- Thinking aloud
One of the povr ideas / v4.0 suggestions I'm carrying around in my head
is to drop the inbuilt fractal stuff - the julia shape and perhaps the
julia, mandel and magnet patterns - as inbuilt code.
The julia shape is interesting, but aside from the pulled taffy shape
most everyone seems to try, I don't see a common use for a julia shape
in a ray tracer. I've taken shots at rendering some of the other
julia-shape (sub-shapes) but I've not had luck finding anything I think
useful to the mainstream. Plus, I've found the julia shape to be quite
slow and glitchy.
The fractal patterns are more useful I think, but wish we'd not ended up
with so many explicit versions (internally) for differing powers. I've
not done any performance comparisons to the generic forms though...
I also don't know what I'm really doing in this area of POV-Ray - or
with fractals in fact! Been holding off pulling it all from povr. This
partly due finding recursive algorithm's - with which I'd had some luck
back in the 2000s - to be pretty unstable today when I went to try some
things recently...
I have in my head that I'd read somewhere there are fractal forms which
are continuous? If so, these 'kinds' might make for more useful shapes /
isosurfaces / patterns. But, yep! I'm just yapping. I don't know what
I'm doing with respect to fractals...
Bill P.
