POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggested v4.0 changes to reflection where perturbed normals. Server Time
7 May 2024 01:31:16 EDT (-0400)
  Suggested v4.0 changes to reflection where perturbed normals. (Message 1 to 1 of 1)
Subject: Suggested v4.0 changes to reflection where perturbed normals.
Date: 3 Feb 2022 08:44:34
Message: <61fbdc42$1@news.povray.org>
New keyword as in: reflection { ... inv_pnormal_cure 4 }
Regarding the reflected ray adjustments with any normal{} block
resulting in inverted reflected rays as compared to the raw surface
normals. These should be extended and brought out as a set of options.
It is confusing when such actions are done in silence. The associated
code can currently be found in Trace::ComputeReflection().
The povr branch is using a new keyword called inv_pnormal_cure which
takes a float argument. The integer portion chooses one of seven 'cures'
currently.  The fractional digits following the decimal point are used
only with cure 5 as the probability of the reflected ray being generated
in a direction opposed to the incoming perturbed normal direction.
If you have no normal{} block in the texture, only Fix0 runs and in
result it does nothing. In other words, there will be no modifications
to reflected rays by ComputeReflection unless a normal{} block is used.
Where normal{} and there are already near tangent ray surface
interactions (a sphere at the edges) the fixes start fixing on any
non-zero bump size.
------- povr's current cures
Fix0 - This is itself a fix of sorts and it predates the 1998 v3.1 Fix1.
All generated reflected rays are calculated as if no perturbed normals
invert with respect to the raw surface normal. We can still see through
the shape at large bump sizes and this what Fix1 and Fix3 were created
to address. However, these surface piercing rays are always inside the
negative half plane of the raw normal.
Fix1 - Since 1998 (added to v3.1). In total it is Fix0 above followed,
potentially, by Fix2 or Fix3. The break out between whether to apply
Fix2 or Fix3 is made by testing the Fix0 generated ray against the
Fix2 - New to povr. Runs Fix0 and then on seeing the reflected ray still
in an inverted relation to the raw surface normal it applies another
calculation which moves the generated reflected ray another step toward
the raw normal direction. The comments call this a double reflection,
and it might be for specific surface structure assumptions, but in
general, it's more of a heuristic fix.
Fix3 - New to povr. Runs Fix0 and then on seeing the reflected ray still
in an inverted relation to the raw surface, it dumps the current
reflected ray for a new one calculated with the raw surface normal.
These reflected rays, to the degree they appear in the total ray color
result, will appear as if no normal{} block was used. In other words, on
increasing bump sizes it can be this fix partly ignores the expected
normal{} effect.
Fix4 - New to povr. This result likely the one intuitively expected with
larger normal bump sizes. This fix, partly, modifies the Fix0 changes
such that where the perturbed normal is inverted with respect to the raw
surface normal the generated reflected ray respects the perturbed normal
direction. We start to see through the surface as might happen with a
mesh of wires or a cloth weave. The results here sometimes look quite
like Fix0 alone at a macro level, but the rays going into the shape here
are those with perturbed normals inverted with respect to the raw. The
reflection effect is at a macro level somewhat darker. How much Fix0
differs from this Fix4, depends on the scene set up.
Fix5 - New to povr. Applies Fix0 and then inverts a portion of the
reflected rays through the surface using a [0..1) probability specified
in the fractional part of the passed float value. Think of more porous
surfaces (being faked by solid ones) where rays can reflect past the
surface intersection.
Fix11 - This Fix1, but where the internal Fix2 and Fix3 are applied in
reverse of the long standing test. The result I think less physically
accurate, but it does tend to better delineate the edges / near tangent
regions. It's here for effects.
Background
While working on a micro normal pattern for the povr branch, larger bump
sizes were found to unexpected return non-blurred reflections mixed in
with extremely blurred ones. Detailed above, found that reflection
adjustments have been in play a long time.
One sphere with reflection within sky_sphere. Fix1 = Fix0->(Fix2 | Fix3)
Fix0 - Never treat the perturbed normal as inverted with respect to raw.
Fix2 - The double correction / reflection.
Fix3 - Glass marble look due dropping back to raw normal use.
Looking at what povr leaves available as Fix1 using the micro pattern
and differing bump sizes we see while Fix2 and Fix3 come into play at
even small bump sizes, but the effect is small until the bump sizes get
up around 0.5.  What happens will of course vary greatly with the
normal{} pattern and surface particulars.
Reflected rays
---------------------    Orig   Fix0   Fix2   Fix3
normal { micro 0.00 }  655360 655360      0      0 100%  0%  0%
normal { micro 0.01 }  655360 655317     10     33 100%  0%  0%
normal { micro 0.10 }  655360 651450    976   2934  99%  0%  0%
normal { micro 0.25 }  655360 631096   6162  18102  96%  1%  3%
normal { micro 0.50 }  655360 557621  24868  72871  85%  4% 11%
normal { micro 0.75 }  655360 444730  57817 152813  68%  9% 23%
normal { micro 1.00 }  655360 327379 106134 221847  50% 16% 34%
normal { micro 1.25 }  655360 275507 138012 241841  42% 21% 37%
normal { micro 1.50 }  655360 252949 153439 248972  39% 23% 38%
normal { micro 1.75 }  655360 241388 163163 250809  37% 25% 38%
normal { micro 2.00 }  655360 234691 170364 250305  36% 26% 38%
normal { micro 3.00 }  655360 224005 187031 244324  34% 29% 37%
normal { micro 4.00 }  655360 221058 195115 239187  34% 30% 36%
normal { micro 5.00 }  655360 219605 200161 235594  34% 31% 36%
normal { micro 9.00 }  655360 218117 208661 228582  33% 32% 35%
Attached is an image with povr's cure set 0-5,11 top to bottom.  The
bump size columns run 0, 0.05, 0.5 and 2.0 left to right. The entire
grid is repeated on the right with heavy AA showing more of the expected
normal micro pattern result.
Using two spheres, not hollow, with an orange-red emitting sphere just
inside each. The more yellow is the exterior texture and the blur the
interior_texture. The top row is the pre 1998 fix result and the red
shows what I take to have been "fixed." Namely, without that fix, and
with large bump sizes, you do see through the surface to the inner
sphere despite 'effectively' correcting the perturbed normals with
respect to the raw normals. Fix4 / Cure 4, looks similar with this set
up, but it uses the flipped to raw normal perturbed normals straight up
to create the reflected rays.
Bill P.
Download 'curestory.jpg' (686 KB)
Preview of image 'curestory.jpg'
