POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggested v4.0 patch for openexr read where large floats Server Time
27 Jul 2024 14:36:47 EDT (-0400)
  Suggested v4.0 patch for openexr read where large floats (Message 1 to 2 of 2)
Subject: Suggested v4.0 patch for openexr read where large floats
Date: 23 Jan 2022 18:57:41
Message: <61edeb75$1@news.povray.org>
(Just posting my povr branch commit message here so the exr image issue
is recorded somewhere)
Found where incoming exr files are at floats and the file has channel
values larger than about 2^16 we end up with +inf color channel values
internally.
This causes unavoidable speckling whenever one of these files is used
with a sky_sphere and a ray hits a location with a +inf internal channel
value - even if as part of a larger set of AA rays. In other words AA
cannot fix this kind of speckling bug.
The kind of speckling changes depending upon the -ffast-math options
being used or not. Note! The bad internal values are not correct in any
case, nor universally clamped. Further, other problems than sky_sphere
use might present themselves.
The hack of a fix the povr branch is adopting is two fold.
First, the addition of pre-scan code in the openexr.cpp file controlled
by EXR_PRESCAN_PATCH. Here the +inf channel values are replaced by the
largest valid channel values otherwise seen for each channel. This
better than what -fno-fast-math trips some of the color space template
code to do. But, yes it's a hack.
On adoption of the newer 3.0 OpenEXR, the right full float read support
should be implemented so these larger values in exr HDRIs don't cause
trouble. Aside better both read and write for full floats - in addition
to half floats.
Second, The addition of some limit checking controlled by
POV_PIGMENT_DEBUG was added to Compute_Pigment in pigment.cpp which
looks for +-inf in debug builds.  This checking would catch the exr
large value issue herein, but the thinking is we could get such values
by other means such as bad user defined pigments or too large user
defined color channel values.
Bill P.
Subject: Re: Suggested v4.0 patch for openexr read where large floats
Date: 24 Jan 2022 06:54:10
Message: <61ee9362$1@news.povray.org>
> internally.
I forgot to mention, should you run into one of these exr files with
values too large for POV-Ray's current exr reader, you can use
converters to get to an hdr file.
I was able to use: 'iconvert sunflowers_4k.exr sunflowers_4k.hdr'
The openimageio-tools based tooling is able to handle the >2^16 channel
values and appears to correctly convert to 'workable' hdr files(a)(b).
Bill P.
(a) - An attempt to use incovert from full float encoding to half float
ran and looks OK external to POV-Ray in that the values are reduced to
what fits in a half float. However, on attempting to use the half float
form HDRI, I still had the speckling problem - though the signature of
the speckles was somewhat different. Not sure what's happening there.
(b) - The hdr format supports less precision and dynamic range than exr
files, so, it's a non-ideal work around.
