POV-Ray : Newsgroups : povray.pov4.discussion.general : POV-Ray 4 SDL: Some concrete proposal Server Time
23 Mar 2026 15:16:28 EDT (-0400)
  POV-Ray 4 SDL: Some concrete proposal (Message 1 to 10 of 27)
Subject: POV-Ray 4 SDL: Some concrete proposal
Date: 13 Apr 2009 16:00:00
Message: <web.49e39942d93ad1dd2dae03a10@news.povray.org>
I'll try to describe what I have currently in mind. But first let me present to
you a kind of "hello world" scene written in that language:
include "colors.inc";
SphereCenter = <0,1,0>;
sphere {
  center: SphereCenter;
  radius: 1 as SphereRadius;
    pigment { color: #<1,0,0> }
} as MainSphere;
plane {
  normal: <1,1,0>;
  offset: SphereRadius;
  translate(SphereCenter);
    pigment { color: #<0,1,0> };
for I = 1 to 100 do
  sphere {
    radius: 0.1;
    center: y * SphereRadius;
    rotate((x * rand() as local R1 * 2 * pi), (y * rand() * 2 * pi));
      pigment { color: #<0,0,R1> };
end;
modify MainSphere {
  radius: 0.9;
MainSphere {
  center: .center + y*0.5;
debug(MainSphere.center);
debug(MainSphere["center"]);
Some things about the basic formalism:
- There is always a "current object"
- Expressions by themselves constitute a statement basically saying "apply this
to the current object in the manner making most sense" (the definition of which
is up to that object).
- "sphere{...}" is an expression returning a sphere. As a matter of fact, it is
an expression taking a "prototype" object (in this case *the* prototype sphere)
and a "modification block" describing how the desired object differs from that
prototype. (Similarly, "MainSphere{...}" takes MainSphere as a prototype to
build yet another one.) Within that modification block, the newly created
object is the current one.
- "rotate(...) and translate()" are functions both returning a transformation;
as an expression-only statement, these transformations are applied to the
current object (which hopefully knows what to do with them).
- "modify MainSphere{...}" is a statement taking a "modification block" as well,
in this case describing how the object itself is to be changed.
- adding "as <Name>" to an expression stores the value of that expression for
later use, serving as an "on-the-fly assignment"
- variables are global by default when assigned; in expressions, local variables
take precedence. Local variables are visible only in the code block in which
they are used (in case of the "R1" variable, this is the enclosing for loop)
- the current object's properties are assigned to using "<Name>: <Value>" to
avoid mixups with local and global variables
- the current object's properties can also be accessed using ".<Name>"; note
that this also allows for ".<Name> = <Value>", but using so makes the code ugly
as it optically disrupts indentation ;)
- "MainSphere["center"]" and "MainSphere.center" are equivalent notation. Only
works with strings conforming to identifier rules of course.
- the language will ultimately provide means to roll your own objects (thereby
allowing to create very powerful "macros")
Subject: Re: POV-Ray 4 SDL: Some concrete proposal
Date: 13 Apr 2009 16:23:21
Message: <49e39f38@news.povray.org>
> sphere {
>   texture {
> } as MainSphere;
  I find that rather inconsistent.
  First you use "name = value" to define a vector, but then you use
"value as name" to define an object.
  What's wrong with using "MainSphere = sphere { ... };"? That would make
it consistent and closer to the current SDL. You also save a useless
reserved keyword.
> modify MainSphere {
>   radius: 0.9;
  I'm not sure about that syntax, but IMO it should be at least in addition
to a syntax like:
MainSphere.radius = 0.9;
  The dot syntax is intuitive from many languages (including the current
SDL itself), and can be used as an lvalue and an rvalue, an example of the
latter being:
theRadius = MainSphere.radius;
Date: 13 Apr 2009 16:40:00
Message: <web.49e3a2023a7e550e2dae03a10@news.povray.org>
> > sphere {
> >   texture {
> > } as MainSphere;
> reserved keyword.
Nothing - I jsut wanted to show two different ways of doing things. Probably
dind't make it plain enough.
Both the following would be valid statements:
  sphere { ... } as MainSphere;
with the difference that the former would not automatically add it to the scene,
just create a prototype.
> > modify MainSphere {
> >   radius: 0.9;
> to a syntax like:
> latter being:
Um... where in the current SDL is that notation used? I mean, other than vector
(and color vector) components?
N.B. That syntax would also be available; however, the "modify" type of notation
would allow for a more concise tampering with multiple values of a single
object.
I'd find it inconsistent to be able to modify a freshly created object in such a
way, but not an existing one.
Date: 13 Apr 2009 17:40:40
Message: <49e3b158$1@news.povray.org>
Am Mon, 13 Apr 2009 15:57:54 -0400 schrieb clipka:
> fact, it is an expression taking a "prototype" object (in this case
> *the* prototype sphere) and a "modification block" describing how the
> desired object differs from that prototype. (Similarly,
> "MainSphere{...}" takes MainSphere as a prototype to build yet another
> one.) Within that modification block, the newly created object is the
> current one.
Prototyping is a great concept and I'd love to see it in POV 4.
> transformation; as an expression-only statement, these transformations
> are applied to the current object (which hopefully knows what to do with
> them).
I find this inconsistent. Why is rotate a function and sphere is not a
function? I think rotate and translate should be expressions returning a
transformation and use curly brackets as well. They could return identity
transformations as a default. Ultimately I dream of foing something like
this:
/*let's define the prototype of a rotation around a certain axis...*/
rotate_around_axis = rotate
  input axis = #<1, 0, 0>; /*default value*/
  input amount = 0; /*default value*/
  rotation_vector = /*whatever it takes to calculate this rotation*/;
/*let's use it!*/
sphere
  radius = 20;
  center = <100, 0, 0>;
  transformation *= rotate_around_axis
      axis = <.5, .5, .5>;
      amount = 30;
      /*the actual transformation is automagically performed according to
the calculations made in the definition of rotate_around_axis.*/
Which means: lazy evaluation of prototype definitions! I chose = instead
of : because of consistency and *= means composition of two
transformation and writing the result back to the lhs. Simply putting a
transformation inside a modification block does not work for me (it works
in POV 3 because it does not use object properties). There should be
something to signify that you are _applying_ this transformation.
> as well, in this case describing how the object itself is to be changed.
I'm pretty sure we don't need modify. Just use
MainSphere = MainSphere
  radius = NewRadiusForMainSphere
This should be the same. We're just using a variable as the prototype for
itself, clever, huh? ;)
> expression for later use, serving as an "on-the-fly assignment"
I agree with Warp here, a = would be more consistent.
> variables take precedence. Local variables are visible only in the code
> block in which they are used (in case of the "R1" variable, this is the
> enclosing for loop)
> <Value>" to avoid mixups with local and global variables
> note that this also allows for ".<Name> = <Value>", but using so makes
> the code ugly as it optically disrupts indentation ;)
You mean "<Name> : <Value>" is shorthand for ".<Name> = <Value>"? I'd
rather make "::<Name>" access a global variable and "<Name>" always
access the most local one, like in C++. So we'd get rid of all those
different notations for assigning variables.
So, here's my version of your example ;)
  center = SphereCenter;
  radius = 1;
  ::SphereRadius = radius; //if you _really_ want to create this global
variable
  texture = texture
    /*Local texture overrides global texture but that's no problem because
    the prototype already has a default texture.*/
    pigment { color = <1,0,0> }
scene += MainSphere; /*or whatever symbol is reserved for "append"*/
scene += plane {
  normal = <1,1,0>;
  offset = SphereRadius;
  transformation *= translate{offset = SphereCenter}; /*Probably too
verbose...*/
  texture = texture {
    pigment = pigment { color = <0,1,0> };
gen = random_generator
  seed = 12345;
/*I'm not sure whether I like this syntax or not...*/
for I = 1 to 100 do
  scene += sphere {
    radius = 0.1;
    center = y * SphereRadius;
    R1 = gen.rand();
    transformation *= rotate{ radians = x * R1 * 2 * pi; }
                    * rotate{ degrees = y * gen.rand() * 2 * 360;};
    texture = texture {
      pigment = pigment { color = <0,0,R1> };
end;
MainSphere = MainSphere {
  radius = 0.9;
/*Do we modify what was already added to the scene? Then we can't clone
objects this way! If we don't, we can't change objects that are already
in the scene! Note that the "modify" keyword is no solution to that
problem.*/
scene += MainSphere {
  center = center + y*0.5;
/*Here I think the intention here was to clone MainSphere.*/
Ah, sorry for taking your nice syntax apart and transforming it to
something completely different. I just couldn't resist. I think you're on
the right track, though!
Date: 13 Apr 2009 19:00:00
Message: <web.49e3c2da3a7e550e2dae03a10@news.povray.org>
Yes, I think it's a powerful thing. It doesn't allow for as good a type checking
as class or interface based concepts, but it has the tremendous advantage of
coming at very low overhead and very high flexibility.
> > them).
Well, both approaches would be ok in this language framework; it would be a
matter of definition.
I think however that the function-based approach is better, because it would
define transformations as basically property-less. So nobody tries to do things
like:
  sphere {
    rotate { axis: <1,0,0>; angle: 30 deg; } as myRotate;
    translate { vector: <1,2,3>; };
  myRotate.angle = 60 deg;
Otherwise, POV-Ray would need to keep track of a stack of transformations
applied to the object (and similarly all the texture patterns and such as
well), just in case someone would want to modify one of the steps later.
> Ultimately I dream of foing something like this:
> /*let's use it!*/
> sphere
>   radius = 20;
>       amount = 30;
This is definitely something we would want - but isn't lazy evaluation the
domain of functions?
Maybe we could get a consensus by allowing for named parameters in functions.
There should be, however, *some* distinction between the two in syntax (not only
in defining them, but also in using them), so it is clear to the user that it
makes no sense to try to manipulate the parameters of the function.
> I chose = instead
In the language concept I have in mind, it would simply be (taking the freedom
to make this a function again, albeit with named parameters):
sphere
  radius = 20;
  rotate_around_axis
    amount = 30;
because, as already mentioned in the original post, expressions by themselves
(whether they be from prototype-cloning or function-calling) are always
*applied*. Note that a sphere would "know what to do" with a transformation
being applied to it. Most importantly, it would know that it would have to
update its children accordingly, too. Which a simple tampering with the spere's
*own* transformation matrix wouldn't do.
(Granted, we'd probably want a way to allow for getter/setter methods anyway...)
Duh. I've just started laying out the basics of the language, and people already
start exploiting its details :P
Note however that this might be slower on a non-optimizing interpreter: It would
have to copy the object first, then discard the original one.
It would also make a difference in case of:
MySphere = sphere {...};
MySphereAlias = MySphere; // no prototype instantiation here, just an alias!
modify MySphere {...};
(Then again, disallowing "modify" would prevent any misconception about how this
case would work out.)
So how would you express such an "on-the-fly assignment" then?
The thing is, I don't like those interpunctuation prefixes: When you start lots
of statements with these, it messes up the indentation, optically speaking.
>   radius = 1;
> variable
>   texture = texture
I'd prefer to avoid this "scene +=" - I think it's unnecessary bulk. Similarly
with the "texture = texture" above.
You mean the "for" loop? I find nothing wrong with it.
The remainder of the syntax, that's what you came up with yourself :P
>   radius = 0.9;
> objects this way!
Hm, yeah - you're making the point why I originally added the "modify" statement
in the first place, but I forgot about it :}
> problem.*/
Why isn't it? If the POV-Ray internals can cope with an object being modified,
then this shouldn't be an issue.
Yeah, basically. I'm quite sure about the underlying idea. I'm still struggling
with the details, like how to get a syntax that is both perfectly consistent
*and* looks good. Mostly the "center:..." vs. alternatives like "center=...",
".center=..." or some such doesn't yet satisfy me.
That, and your and Warp's objection against the "as" statement. I actually like
it, but your complaint regarding inconsistency has some justification, too.
Date: 14 Apr 2009 08:19:02
Message: <49e47f36@news.povray.org>
Am Mon, 13 Apr 2009 18:55:22 -0400 schrieb clipka:
> would define transformations as basically property-less. So nobody tries
> to do things like:
>   sphere {
>     rotate { axis: <1,0,0>; angle: 30 deg; } as myRotate; translate {
>     vector: <1,2,3>; };
> transformations applied to the object (and similarly all the texture
> patterns and such as well), just in case someone would want to modify
Well, I think the point here is: Do we store references in variables or
actual copies of the data? If we store references, then yes, POV-Ray
would need to keep track of them in its internal state. If we don't then
"myRotate.angle = 60 deg" would do nothing until we use myRotate in an
object modification block. Thats the same problem as cloning vs.
modifying objects in the scene.
> the domain of functions?
> functions.
Yeah, I thought of blurring the distinction between functions and
prototypes. Sometimes named parametres are useful, sometimes they are not
needed. We could allow both, we just need a syntax for it.
Let's sum up the classic differences between a function and an object:
A function has the type of its return value as soon as parametres are
bound to it. As long as no parameters are bound to it it has a type
determined by the number (and type) of its arguments. An object always
has the type it was given when it was created.
A function has parameters which are distinguished by their order. An
object has members or properties with names.
If we add input properties which delay calculation of other properties to
our language then functions and prototypes can perform the same task with
a different syntax. I'm not to happy with that, _one_ way to do things
should be enough.
> (not only in defining them, but also in using them), so it is clear to
> the user that it makes no sense to try to manipulate the parameters of
> the function.
>> I chose = instead
>> works in POV 3 because it does not use object properties). There should
>> be something to signify that you are _applying_ this transformation.
> freedom to make this a function again, albeit with named parameters):
> sphere
>   radius = 20;
>   rotate_around_axis
>     amount = 30;
> themselves (whether they be from prototype-cloning or function-calling)
> are always *applied*. Note that a sphere would "know what to do" with a
> transformation being applied to it. Most importantly, it would know that
> it would have to update its children accordingly, too. Which a simple
> tampering with the spere's *own* transformation matrix wouldn't do.
> anyway...)
Hm, now I'm getting a understanding of what you are aiming for. Then an
operator meaning "apply" would also be nice, wouldn't it?
perhaps
MyTransformedSphere = MySphere ~ MyTransform;
> already start exploiting its details :P
Exploitation of details makes a programming language powerful ;)
Unfortunately that means paying attention to details when designing a
language is very important.
> It would have to copy the object first, then discard the original one.
It should be trivial to recognize a pattern like
<something> = <somthing>
  /*something*/
> alias! modify MySphere {...};
> how this case would work out.)
Again, reference vs copy.
I don't. If I want to I assign first and then reuse the assigned variable.
> start lots of statements with these, it messes up the indentation,
> optically speaking.
I'm not sure what you mean with "messing up the indentation", but people
are used to such prefixes. Just think of directory structures:
. is the current working directory
.. is the parent directory
/ is the top level directory
and so on.
> Similarly with the "texture = texture" above.
I see what you mean. So objects apply themselves to the global object
which is the scene itself?
> You mean the "for" loop? I find nothing wrong with it. The remainder of
I mean for ... end. I always find using words to open and close blocks
hard to read.
> statement in the first place, but I forgot about it :}
>> If we don't, we can't change objects that are already in the scene!
>> Note that the "modify" keyword is no solution to that problem.*/
> modified, then this shouldn't be an issue.
Then "as" creates a reference, "modify" modifies the target of a
reference, "=" creates a copy, and what does "modify" do if the variable
it should modify is not a reference...
> struggling with the details, like how to get a syntax that is both
> perfectly consistent *and* looks good. Mostly the "center:..." vs.
> alternatives like "center=...", ".center=..." or some such doesn't yet
> satisfy me.
> actually like it, but your complaint regarding inconsistency has some
> justification, too.
I just want to prevent SDL 4 becoming cluttered with keywords like "as"
and "modify" when there is a way to express the same thing in a concise
manner without them. This may seem pedantic but SDL 3 is such a mess with
keywords. When I started writing #macros I just wanted to call a variable
"x"... guess what happened ;)
Date: 14 Apr 2009 08:55:00
Message: <web.49e486f13a7e550eaddfbead0@news.povray.org>
> > to do things like:
> >   sphere {
> >     vector: <1,2,3>; };
You'd want a transformation for each container, which doesn't prevent references
being used. Those that seem to be a list of transformations interleaved with
effects would be processed into a nested structure, each having the
transformations and effects before the container is closed.
I think we can use the usual (simple) language constructs to create references,
and new declarations for copies.
Generally, we could go for partial OO implementation for the scene objects,
which means that we don't carry per-instance methods, but instead just have the
instances (with a single pointer) locate the methods for the class, along with
the enumerated properties. The parser would be version-matched to the engine,
which removes any opaque enumeration from the SDL source scripts.
Date: 14 Apr 2009 10:40:00
Message: <web.49e49f1f3a7e550ef06ce2830@news.povray.org>
I think we'll want to store references: Animation scripting might greatly
benefit of that I guess. Instead of individually describing individual frames,
an animation script could set up all its objects and then just push them around
the scene as the animation progresses.
> > functions.
How about:
MyFunction = function(positional x, y; named a, b, c) { ... }
// shorthand: function(x, y; named a, b, c) { ... }
Foo = MyFunction(2,3; b:42; a:11);
So far I can follow you... I think. Note however that with a dynamically typed
language, even when parameters are bound to it, it has "the type of its return
value" no earlier than it is actually executed and the actual return value
determined.
> An object always
I'd say that the parameter naming / ordering thing is rather independent of
objects vs. functions: It's just a common convention of most programming
languages that function parameters are passed by position instead of by name.
> should be enough.
I agree with that. But I guess the concept of individual properties delaying the
calculation of a whole entity would be hard to grasp for the average user, or
even for the average programmer (it is for me, at any rate ;)).
> perhaps
Hm... there is something to this indeed.
However, some things need to be clarified:
Using bare expressions within a curly brace doesn't strictly create a copy, but
modifies the copy of the prototype. Would the tilde operator force creation of
a new copy?
In that case, it would be equivalent to:
MyTransformedSphere = MySphere { MyTransform };
which is just about as easy to type. It would also then raise the question
whether the following would be possible, too:
MyColoredSphere = MySphere ~ color: #<1,0,0>;
In that sense, the tilde operator would actually be the single-statement
equivalent for curly braces (which would happen to nicely fit with the shapes
of the symbols :))
So are you saying that the concept I've presented is powerful? Thanks ;)
Yup. Sure thing.
Hm... occasionally I do statements like:
    FooBar( This + Is(A * rand() - 0.4) / Stupid + Example );
only to find that I want to base something else on that very same random number
- or some other sub-statement, for that matter. So sometimes I'd like to be
able to write:
    FooBar( This + Is(A * rand() as MyRand - 0.4) / Stupid + Example );
    Fnord = <1,2,3> * MyRand;
This is partially a thing of "how can that rand() dare to require me to give it
a line of its own?!", partially "duh, now I have to cut and paste that
sub-expression to its own line" laziness, and partially avoiding to type one
instance of the variable name, as in:
    MyRand = rand();
    FooBar( This + Is(A * MyRand - 0.4) / Stupid + Example );
Of course there are cases where using a full-fledged assignment statement is
much cleaner. But sometimes, to me a value has the quality of no more than a
"spin-off" of some other computation. So I'd love to have a statement saying
"oh, by the way, just remember this one for later".
Or, think of debugging a large formula. With this "on-the-fly assignment", it is
a piece of cake; no need stripping it down to individual terms (and risking to
break it again as soon as you re-assemble it because you don't want 20 lines of
assignments where a two-liner would do).
> > optically speaking.
Think of this syntax I had pondered:
sphere {
  .center = <0,0,0>;
  .radius = 1;
  temp = rand();
    test = temp + 1;
    .answer = 42;
  .foo = bar;
I think this syntax would make it perfectly plain to most developers accustomed
to the "foo.bar" field/member notation that .center is a property of the
sphere, while for instance temp is not, and texture is defined in some other
scope as well.
Alas, it really "uglifies" the indentation!
> but people
No problem with the prefixes, but I want the code to have a certain "beauty" as
well - because with code, somehow beauty is almost always related to
readability (unless of course you're going for the "exotic" beauty of some
artificial languages like whitespace, c00l or such :P).
Yep. Well, *anything* that is a standalone expression theoretically does. But
only for some types of values the concept of "applying it to the scene" makes
sense.
> hard to read.
That's where indentation was invented for. (There are even languages that
actually use indentation levels to open and close blocks.)
And in a language such as this, I think there should be a clear distinction
between the "modification blocks" - which open up a new context for "applying"
things to - and control blocks.
No - it's not "=" that creates a copy: This is just an alternative way of
creating a reference.
The thing that causes creation of a copy is the curly-braces modifier block,
unless explicitly used with "modify":
    MySphere = sphere;
actually creates a reference to the very basic "prototype of prototypes" sphere.
And why not? There's no reason to create a copy if you're not applying any
modifications to it anyway.
To create a copy of that prototype, one would have to write:
    MySphere = sphere {};
Note that this concept also allows creating an anonymous modified object "on the
fly", as in:
    (MyIntersect,MyNormal) = trace( MySphere { translate <2,3,4> } );
Yeah, that's a hassle indeed.
One simple way out of this, however, is to develop a habit of always starting
your variable names with uppercase letters. (I must confess I don't have such a
habit myself ;))
Also note that the whole smash like "blob", "sphere", "triangle", "sqr" (yeah!
my personal friend in POV 3.x!) would be made available at least for local
variables if desired.
If variable names should really be deemed an issue, how about carrying over
POV-Ray 3.x convention for control keywords to start with "#"?
So we'd have:
#for i = 1 #to 21 #step 2 #do
though I wouldn't consider this pretty. Or using all uppercase, which seems to
be more seldom used for variable names (possibly because it requires one more
key to be pressed):
FOR i = 1 TO 21 STEP 2 DO
  sphere { center = <i,0,0>; radius = 1; }
END
Looks a bit antiquated, but that doesn't necessarily make it a bad idea.
Date: 14 Apr 2009 11:05:00
Message: <web.49e4a5663a7e550ef06ce2830@news.povray.org>
I'd even go as far as to move the whole scene object handling into a separate
layer, with the SDL code only checking whether the object is *any* type of
scene object, and then deferring the handling to that "scene object wrapper"
layer.
That one could in turn be comprised of nothing more than a dynamic table with
objects and their respective actual types (with the core SDL implementation
handling only indices into that table; could be pointers though of course), and
a hard-coded lookup table for each type, mapping keywords to
pointers-to-members. Plus some wrap/unwrap code for some data types, if needs
be.
Thus, a statement like
    MySphere.translate(<2,3,4>)
would be resolved to (roughly):
    value = LookupName("MySphere");
    if (value->type == SCENE_OBJECT)
      SceneObjectLayer->Invoke(value->handle, "translate", Vector3d(2,3,4));
while SceneObjectLayer::Invoke(handle, name, param) would be implemented as
something like:
    obj = (SceneObject*)handle;
    objClass = obj->class();
    member = LookupMember(objClass, name);
    obj->member(Unwrap(param));
which would ultimately resolve to - in this case - a call to
Sphere::Translate(Vector3d v).
Date: 16 Apr 2009 06:08:32
Message: <49e703a0@news.povray.org>
Am Tue, 14 Apr 2009 10:35:11 -0400 schrieb clipka:
> greatly benefit of that I guess. Instead of individually describing
> individual frames, an animation script could set up all its objects and
> then just push them around the scene as the animation progresses.
Right. Then frames are just modification blocks of the scene object.
> How about:
> MyFunction = function(positional x, y; named a, b, c) { ... } //
Or even:
MySphereProducingFunction = function(named pos)
{ sphere { midpoint = pos; /*...*/ } };
Any object applied to a function block would be its return value.
> typed language, even when parameters are bound to it, it has "the type
> of its return value" no earlier than it is actually executed and the
> actual return value determined.
Yes, from the syntactical point of view "func(/*...*/)" and "func" have
different types in most languages. I don't like this, because what type
has func(some_parameter /*but not the other*/) then? In most languages
you have to specify all arguments or none... Seems to be a personal
dislike, though ;)
> of objects vs. functions: It's just a common convention of most
> programming languages that function parameters are passed by position
> instead of by name.
Right. Perl has named parameters but how they work seems rather obscure
to me. Just what you'd expect from Perl ;)
>> to our language then functions and prototypes can perform the same task
>> with a different syntax. I'm not to happy with that, _one_ way to do
>> things should be enough.
> delaying the calculation of a whole entity would be hard to grasp for
> the average user, or even for the average programmer (it is for me, at
> any rate ;)).
It's just the other way round: The program doesn't follow a sequence of
instructions but has a number of goals it has to achieve. Each time a
resource needed to achieve the current goal is missing, the program goes
to the next. Hopefully the resource will become available later, perhaps
as the result of another calculation.
>> perhaps
> copy, but modifies the copy of the prototype. Would the tilde operator
> force creation of a new copy?
> question whether the following would be possible, too:
> shapes of the symbols :))
Supplying your own rules for applying a object to some other object would
just be an act of overloading the ~ operator. Something like
PaintInHappyColors = basic {}; //clone the most fundamental prototype
operator(object ~ PaintInHappyColors)
  pigment { color = <rand(), rand(), rand()>; };
>> variable.
> number - or some other sub-statement, for that matter. So sometimes I'd
> like to be able to write:
> give it a line of its own?!", partially "duh, now I have to cut and
> paste that sub-expression to its own line" laziness, and partially
> avoiding to type one instance of the variable name, as in:
>     MyRand = rand();
>     FooBar( This + Is(A * MyRand - 0.4) / Stupid + Example ); Fnord =
>     <1,2,3> * MyRand;
> statement is much cleaner. But sometimes, to me a value has the quality
> of no more than a "spin-off" of some other computation. So I'd love to
> have a statement saying "oh, by the way, just remember this one for
> later".
> assignment", it is a piece of cake; no need stripping it down to
> individual terms (and risking to break it again as soon as you
> re-assemble it because you don't want 20 lines of assignments where a
The C way to do that:
while((error_code = function_returning_error_code()) == 0)
  /*do something*/
Easy, because = returns the assigned variable. That does definitely
confuse a non-programmer who doesn't know the difference between = and ==.
So your example would become
FooBar( This + Is(A * (MyRand = rand()) - 0.4) / Stupid + Example );
> sphere {
>   .center = <0,0,0>;
>   .radius = 1;
>   temp = rand();
>   texture {
>     test = temp + 1;
>     .answer = 42;
>   .foo = bar;
> accustomed to the "foo.bar" field/member notation that .center is a
> property of the sphere, while for instance temp is not, and texture is
> defined in some other scope as well.
Would it? I never write "this->member" in C++, just member. Some people
prefix their members with "m_", I don't. It's a matter of personal
taste...
Every reference to a variable outside the current scope necessarily does
this, if I understand you correctly.
> "beauty" as well - because with code, somehow beauty is almost always
> related to readability (unless of course you're going for the "exotic"
> beauty of some artificial languages like whitespace, c00l or such :P).
>> hard to read.
> that actually use indentation levels to open and close blocks.)
> distinction between the "modification blocks" - which open up a new
> context for "applying" things to - and control blocks.
Another matter of taste, I suppose. It's just that when I want my code to
be verbose, then _I_ want to introduce the verbosity, not the designer of
the programming language I happen to code in.
>> variable it should modify is not a reference...
> of creating a reference.
> block, unless explicitly used with "modify":
>     MySphere = sphere;
> sphere.
> any modifications to it anyway.
Sounds good :)
>> with keywords. When I started writing #macros I just wanted to call a
>> variable "x"... guess what happened ;)
> starting your variable names with uppercase letters. (I must confess I
> don't have such a habit myself ;))
> (yeah! my personal friend in POV 3.x!) would be made available at least
> for local variables if desired.
As all objects will be prototypes I don't think any special treatment
will be required. These prototypes could even come from special internal
includes. Most of the time I won't need a poly and if I want to create
one I just write
include "internal:poly"
poly
{ /*blahblah*/
Of course cameras and basic modifiers should be included by default.
Namespaceing on the other hand is just too much typing for a lazy person
like me :P
> over POV-Ray 3.x convention for control keywords to start with "#"?
> So we'd have:
> #end
> seems to be more seldom used for variable names (possibly because it
> requires one more key to be pressed):
> END
There should really be opinion polls among POV-Ray users to decide on
prettyness ;)
