Does anyone else think it would be a good idea to have an option to produce
dithered output? If your scene consists of colour gradients between two
close colours, or two greys, even in 24bpp format you can often still see
"banding". Using some sort of dithering scheme in the output would vastly
improve images like this, and would be quite simple to implement. I just
wonder how the dithering would be handled across block borders between
different threads, maybe the thread stores float/double precision pixels and
then the final "block assembler/file writer" code will perform the dithering
on the whole image?
Just an idea.
> produce dithered output? If your scene consists of colour gradients
> between two close colours, or two greys, even in 24bpp format you can
> often still see "banding". Using some sort of dithering scheme in the
> output would vastly improve images like this, and would be quite simple
> to implement. I just wonder how the dithering would be handled across
> block borders between different threads, maybe the thread stores
> float/double precision pixels and then the final "block assembler/file
> writer" code will perform the dithering on the whole image?
> Just an idea.
I think crand can accomplish this, although it isn't applied scene-wide, but to
specific textures.
This sounds like something you could write with a generic post-processing
script (which future versions of POV-Ray should and will most probably
support).
> Just an idea.
specific textures.
> support).
I thought dithering had to know the exact value of a color so, for constant color, it
could cycle between discretized colors with a weighting depending on how close the
actual color is to each. (for graded colors, it's slightly more complicated). This
can't be done post-processing, by which point the precision has already been lost.
Dan
> > support).
it could cycle between discretized colors with a weighting depending on how close the
The floating point values of each color component of each pixel will,
obviously, be available to the post-processing filter.
Ahh! Apologies. I thought you meant "post-processing" as in Gimp or ImageMagick.
> ImageMagick.
OOC, does the current HDR output format contain the full precision pixels?
If so, I could just write a program to generate a dithered 24bit bitmap from
the HDR file?
I meant post-processing. Just because the post-processing filter has more
than the 8 bits-per-channel information to handle doesn't make it an less
post-processing.
> constant color, it could cycle between discretized colors with a weighting
> depending on how close the actual color is to each. (for graded colors,
> it's slightly more complicated). This can't be done post-processing, by
POV-Ray can already create 48-bit PNG images. You could post-process that to
generate a dithered 24-bit image.
