What I'd like to see is an allowed comma at the end of the last element in a list.
This would facilitate the populating of lists from within a loop. There's now the
need (AFAICT) a silly check for the last element to omit the comma.
Dan
ing of lists from within a loop. There's now the need (AFAICT) a silly check for the
> Dan
Usually I workaround by adding the comma before the number, that way there is no
comma at the end of the list. This works usually because most items that I have
created that use lists (meshes, splines, polygons) have a float preceding the
list, usually the number of items conatined in the list.
-tgq
Trevor G Quayle <Tin### [at] hotmail com> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 14 lines --]
> > Dan
Also you could skip using commas completely. Just put your elements in
parentheses (to avoid ambiguity in situations like "2 -1") and you don't
need commas at all.
list. This would facilitate the pop
ulat
a.
> > > Dan
> need commas at all.
> - Warp
Yes that may be better. I was unaware that I could skip the commas in those
types of items (I knew you could in primitives). Is this stated anywhere in
the docs explicitly or is one of those read between the lines to discover?
-tgq
I don't remember the docs well enough to say for sure, but I would say
it's more or less an undocumented feature.
