POV-Ray : Newsgroups : povray.pov4.discussion.general : superlinear transformations Server Time
13 Nov 2026 04:43:03 EST (-0500)
  superlinear transformations (Message 1 to 9 of 9)
Subject: superlinear transformations
Date: 26 Sep 2008 14:03:57
Message: <48dd240d$1@news.povray.org>
Presently, objects can be transformed according to a displacement vector plus a 3x3
matrix.  This is a linear transformation.  However, it would be useful if one could
also do nonlinear transformations.   For example, x -> x * y, or x -> x * (1 + 0.1 *
sin(y)).  I can easily see how this would become hopelessly complex, but it would be
useful.
Subject: Re: superlinear transformations
Date: 26 Sep 2008 14:58:58
Message: <48dd30f2@news.povray.org>
> vector plus a 3x3 matrix.  This is a linear transformation.  However,
> it would be useful if one could also do nonlinear transformations.
> For example, x -> x * y, or x -> x * (1 + 0.1 * sin(y)).  I can easily
> see how this would become hopelessly complex, but it would be useful.
  Actually objects are not transformed at all. That would be impossible
in the generic case.
  What POV-Ray does is a common raytracing trick: Rather than transform
the object with the transformation matrix, it transforms the ray with
the inverse of the transformation matrix. The end result is exactly the
same, but the advantage is that it's much easier (and in many cases,
*possible*) to do it like this.
  This is the reason why transformations must be linear. The straight ray
must be straight also after it's transformed. It cannot become curved.
This is the reason why only rotation, scaling, skewing (which is actually
a combination of rotation and uneven scaling) and translation is possible.
  Raytracing with curved lines cannot be done accurately, and would be
extremely slow.
Date: 26 Sep 2008 20:46:33
Message: <48dd8269$1@news.povray.org>
> extremely slow.
Excellent answer -- thanks.
I'm a bit confused about the skew argument.  There's
3×4=12 elements in a generalized linear transformation
matrix:
3 degrees of freedom: transformation
3 degrees of freedom: scaling
3 degrees of freedom: rotation
So this leaves 3 more degrees of freedom..... which are skew.
For example, the 3×3 matrix might be decomposed as follows
(right-hand coordinates)
| ax  0  0 |
| 0  ay  0 | : scaling
| 0  0  az |
| cz  sz  0 |
|-sz  cz  0 | : rotation about z (cz² + sz² = 1)
| 0   0   1 |   (permute for x, y)
So between scaling and rotation, I'm constrained to
antisymmetric matrixes.
A typical shear matrix:
| uz  vz  0 |
| vz  uz  0 | : shear perpendicular to z, (uz² - vz² = 1)
So this gives me 9 parameters:
ax, ay, az, sx, sy, sz, vx, vy, vz
the same number of parameters needed to specify the full matrix.
Date: 27 Sep 2008 00:40:41
Message: <48ddb949$1@news.povray.org>
>> possible.
> matrix:
That should be translation.
> | ax  0  0 |
> | 0  ay  0 | : scaling
> | 0  0  az |
> | cz  sz  0 |
> | uz  vz  0 |
After thinking more about this, I realized my mistake.
Matrix multiplication fails to preserve symmetry, only addition.
So given that, it's possible to generate a symmetric component (the
offdiagonal terms generating shear) in addition to a antisymmetric
component (the off-diagonal terms generating rotation) from rotation
and scaling together, as long as the scaling is non-uniform, as Warp
said.  My linear algebra is too rusty....
You can trivially see this in the following 2×2:
| 0 1 | |-1 0 |       | 0 1 |
|-1 0 | | 0 1 |   =   | 1 0 |
And my degrees of freedom argument follows only if one is allowed a single
rotation and a single scaling.  But generating pure shear requires two rotations.
Sorry....
Dan
Date: 27 Sep 2008 04:02:44
Message: <48dde8a4$1@news.povray.org>
Le Fri, 26 Sep 2008 21:40:57 -0700, Dan Connelly a modifié des petits
morceaux de l'univers pour nous faire lire :
> single rotation and a single scaling.  But generating pure shear
> Sorry....
> Dan
Might I remind people that the internal transformation matrix is a 4x4,
using weighted coordinates system (x,y,z,w).
Successive transformations are stacked together by matrix-multiplication
at parse time.
Now, I would be interested in seeing a screwing transformation-matrix...
Please enlight-me
Date: 27 Sep 2008 05:13:19
Message: <48ddf92f@news.povray.org>
> Please enlight-me
http://www.geocities.com/evilsnack/matrix.htm
Date: 23 Nov 2008 18:10:40
Message: <4929e2f0@news.povray.org>
Hmm I don't think nonlinear transformations would cause the ray to be a
curve. Non-linear transf. are already possible in isosurfaces.
All you need is a different matrix for each pixel. Or rather, instead of
using a matrix you multiply with, use a generic function.
Date: 24 Nov 2008 04:42:58
Message: <492a7722$1@news.povray.org>
> curve.
Of course they would, if I apply the following transformation to a sphere:
x -> x
y -> y^3
z -> z
Then it's impossible to convert this to a "straight ray intersecting with a
unit sphere at the origin" problem, which is what POV does for all linear
transformations.
Yes, and they are much slower than rendering primitives like a sphere and
take setting up to get correct results.  Primitives just work, fast.
Date: 24 Nov 2008 12:06:01
Message: <492adef9@news.povray.org>
> curve.
  Well, the very definition of "non-linear transformation" *is* that
straight lines don't necessarily remain straight after the transformation.
  Conversely the very definition of "linear transformation" is that any
straight line remains straight after the transformation.
  In the same sense as non-linear transformations are "possible" for
triangle meshes (although not really, but almost).
  You are not really transforming the isosurface object. You are modifying
its function, which is a different thing (from the point of view of
raytracing). You can't do that for other primitives.
  Simply changing the direction of the ray according to a function, while
keeping the ray straight, is *not* enough to achieve non-linear
transformations of objects.
