POV-Ray : Newsgroups : povray.pov4.discussion.general : Identifier declaration consistent with other languages Server Time
21 Nov 2024 14:17:10 EST (-0500)
  Identifier declaration consistent with other languages (Message 1 to 10 of 18)
Subject: Identifier declaration consistent with other languages
Date: 20 Jul 2008 13:56:59
Message: <48837c6b$1@news.povray.org>
Instead of
#declare myobj = object {
Why not use
object myobj {
It's more consistent with pretty much every other programming language
since BASIC dropped the "LET" keyword.
...Chambers
Subject: Re: Identifier declaration consistent with other languages
Date: 20 Jul 2008 17:59:46
Message: <4883b551@news.povray.org>
Chambers <ben### [at] pacificwebguycom> wrote:
> Instead of
> Why not use
> object myobj {
  The intention is to redesign the SDL for pov4 anyways. What we need is
a good overall design rather than just individual bits.
Date: 5 Nov 2008 15:25:00
Message: <web.4911ffd2909e69788f162dfb0@news.povray.org>
> > Instead of
> > Why not use
> > object myobj {
I'd like to see more powerful scripting support as well.  I use Python
frequently to generate POV-ray code.
An a syntax change:
Instead of
#declare count = 10
#declare pos = 0
#declare MyObject = union {
  #while(pos < count)
  circle {
    <0, 0, 5>, 0.5
    rotate <0, pos * 360 / count, 0>
        #if(pos % 2 == 0)
          color White
        #else
          color Black
  #declare pos = pos + 1
Why not simply have:
count = 10
MyObject = union {
  for(pos = 0, pos < count, pos = pos + 1) {
    circle {
      <0, 0, 5>, 0.5
          if(pos % 2 == 0) {
            color White
          } else {
            color Black
MyMacro = macro(p1, p2, p3) {
  /* Macro body */
MyMacro(x, y, z)
Date: 5 Nov 2008 16:15:01
Message: <web.49120bff909e69788f162dfb0@news.povray.org>
Other ideas:
Currently there is a difference between declaring an item and using it:
// Declare a circle
#declare MyCircle = circle {
// Use a circle
circle {
// or
object {
  MyCirlce
When you use the item you can't give its 'instance' a name however.  In most
languages you can declare objects and create named instances of these objects.
// Declare an object (but don't use/create and instance of it)
circle MyCircle
texture MyTexture
  pigment
    color Green
// Create an unnamed instance of an unnamed object
circle
// create an unnamed instance of a named object
MyCircle
// Create a named instance of a named object
circle1 = MyCircle
  // overrides
circle2 = MyCircle
  scale circle1.radius
  texture { MyTexture }
circle3 = MyCircle
  <(circle2.x + circle1.x) / 2,
   (circle2.y + circle1.y) / 2,
   0>
Better yet why not have a full scripting built on top of an existing scripting
language (of course security may be an issue) such as Python, or AngelScript,
etc
Date: 5 Nov 2008 16:31:36
Message: <491210b8@news.povray.org>
  Some could argue that this is why:
Date: 6 Nov 2008 18:15:01
Message: <web.491379d8909e69788f162dfb0@news.povray.org>
Yes, but how is that any worse than something like:
Date: 10 Nov 2008 02:40:00
Message: <web.4917e46c909e69788f162dfb0@news.povray.org>
Another way to do away with #end/{/} may be to adopt a Python-like blocking
mechanism where the indentation level affects the block.  Then a block as above
could simply be:
MyRing = union:
  for(x=0,x<10,x=x+1):
    circle:
One problem I've heard from critics of this system is that most editors can't
automatically detect and create folds.
Date: 11 Nov 2008 13:48:46
Message: <6B674F3794A14536BD48AF8381DFCBB5@HomePC>
I am categorically against whitespace having meaning.
...Ben Chambers
www.pacificwebguy.com
> -----Original Message-----
> From: Allen [mailto:bri### [at] yahoocom]
> Posted At: Sunday, November 09, 2008 11:36 PM
> Posted To: povray.pov4.discussion.general
> Conversation: Identifier declaration consistent with other languages
> blocking
> as above
> could simply be:
> MyRing = union:
>     circle:
editors
> can't
Date: 11 Nov 2008 18:00:01
Message: <web.491a0e1e909e697878dcad930@news.povray.org>
I tend to agree. It would, to my mind, create another level of difficulty in
trying to track down erroneous bits if code. Not being a programmer per se
(except with the POV SDL), I'm thinking that both the space bar and the tab
button would create identical(?) white spaces. Of course, that may be my naive
and uninformed notion. Please correct me if I'm wrong; I'm willing to learn!
Ken W.
Date: 13 Nov 2008 07:35:01
Message: <web.491c1e38909e69788f162dfb0@news.povray.org>
> Ken W.
I'm pretty certain that Python considers a tab character in the input to be
equal to 8 space characters.  It is really my only complaint with Python, in
all other ways I really enjoy Python.
With such code it is better not to mix tabs/spaces else visually you can't
really see where a block is at.  Nice thing about C/C++, braces can be anywhere
and statements are terminated with a semicolon so it can span multiple lines
anywhere.  Python can only span multiple lines with a line continuation or
inside of groups such as [], (), and {}
Invalid python:
list =
  1,
  2,
  3
Valid:
list = [
  1,
  2,
  3
