POV-Ray : Newsgroups : povray.pov4.discussion.general : Feature *Adjustments* Server Time
22 Jan 2025 20:23:50 EST (-0500)
  Feature *Adjustments* (Message 1 to 1 of 1)
Subject: Feature *Adjustments*
Date: 29 Feb 2008 18:26:36
Message: <47c894ac$1@news.povray.org>
I'd like to see area lights consisting of a 1x1 array fully supported,
so that I can use the jittering of one light source to accomplish the
area lighting.  With a high AA level, this actually works quite well,
and if I'm already sampling at a high AA level for some other reason,
having one jittered point light is just as good, and much faster, than
an area light with more lights in it.
There is also a feature for meshes in which if the supplied normals are
all the same, the triangle is treated as a flat mesh and the normals are
ignored.  There are some effects that can be achieved by eliminating
this "optimization," such as making a polygon that doesn't have its
vertices all in the same plane, but has a uniform normal for lighting
calculations, so that it looks flat.
John
