POV-Ray : Newsgroups : povray.pov4.discussion.general : Feature un-request Server Time
22 Jan 2025 20:17:50 EST (-0500)
  Feature un-request (Message 1 to 10 of 11)
Subject: Feature un-request
Date: 29 Jan 2008 09:39:45
Message: <479f3ab1$1@news.povray.org>
I would like to see a number of features removed from the POV-Ray C
source code.  These include:
	- all primitive shapes - sphere, plane, cone, quadric, etc.
	- all defined textures - wood, marble agate, checker, etc.
	- all surface normal effects - ripples, waves
	- all light sources - spotlight, area_light, etc.
	- all atmospheric effects - fog, absorption, scattering, etc.
	- lots of other superfluous stuff
Once this is all gone, you will end up with a much simpler raytracer
that does very little.  This is the perfect starting point.
Now, you build a very simple but very expressive SDL grammar that allows
you to express graphical modeling concepts very simply.  With this SDL,
you can then define what "sphere" means but this time it's written in
the SDL language, not in C.  You can define what marble means.  You can
define what fog means.  All of these definitions become part of the SDL
and are included in a library which people can use.
Now, POV-Ray users can define their own textures and add them to the
system.  They can add their own shapes, their own light sources, their
own atmospheric effects.  They would have much more power than they ever
had.  If done well, users would hardly notice the difference unless they
wanted to use the extra power.
POV-Ray should be a small simple engine to render user-defined shapes
with user-defined textures and user-defined light sources.  To make them
user defined, you have to push them from the cryptic and inaccessible C
source into the SDL.
It will certainly take a considerable amount of redesign, but I feel
it's the best way to go.  Less is more - take advantage of that.
David Buck
Subject: Re: Feature un-request
Date: 29 Jan 2008 10:25:29
Message: <479f4569$1@news.povray.org>
POV++
-Nekar Xenos-
Date: 29 Jan 2008 10:25:49
Message: <479f457d$1@news.povray.org>
> With this SDL, you can then define what "sphere" means but this time it's
> written in the SDL language, not in C.  You can define what marble means.
> You can define what fog means.  All of these definitions become part of
> the SDL and are included in a library which people can use.
Your idea sounds good in theory.  In fact I would also like to see all the
lighting code removed, to be replaced by standard SDL libraries for
diffuse/specular etc.  The user is then free to implement their own lighting
models should they wish.
I suppose the SDL would also need to be extended so that users could specify
the ray/shape intersection algorithm - otherwise it's going to be like
making everything out of isosurfaces...
Date: 29 Jan 2008 10:27:00
Message: <479f45c4@news.povray.org>
  This is a good idea only if you want your renders to take at least
10 times longer than currently.
  Not only are the C(++) implementations of the primitives faster because
the compiler can optimize them, they are also optimized on a per-primitive
basis. For example, a sphere is not a generic polynomial object which is
solved while raytracing. A sphere is a very specific piece of code which
has been optimized to calculate the intersection points between a line
and a spherical surface.
  If, however, now you would change that to a generic surface definition
language where the user specifies that "a sphere is an isosurface defined
by the function ..." the render times will sky-rocket. Solving a generic
user-written isosurface function is much slower than the optimized
ray-sphere C++ code.
  If the answer to this is "ok, then let's add an internal 'sphere' function
which is optimized for speed and which the user can call" then we are
exactly where we are now. Nothing would have changed.
  The whole idea of POV-Ray is speed. Why do think that thousands of
hours of work has been put into making POV-Ray support multi-threading?
For speed, only speed and nothing but speed.
  Killing this speed kind of defeats the whole purpose.
Date: 29 Jan 2008 10:36:46
Message: <479f480e$1@news.povray.org>
I don't want to get into an argument with povray's father, but...
but aren't functions already available for user-defined shapes and
textures?  Aren't isosurfaces slower to calculate than the quadratic
primitives?  Isn't SDL parsing time an aditional problem?
yes, but optimized solutions are good too.  C is very good at that.
Besides, all renderers I know of offer the quadratic geometric
primitives for granted, including Renderman.
I see no reason why user-defined and slower shapes, textures or shaders
should take precedence over well-known and optimized builtin techniques
for rendering quadratics, phong shading and company...
certainly, it'd be cool to have user-defined shaders, but also keep with
the oldies and fasties...
Date: 29 Jan 2008 11:06:39
Message: <479f4f0f$1@news.povray.org>
And I am willing to back down considerably from my extreme position :-).
  My point is that it should be possible to define a sphere or a plane
in the SDL.  If performance dictates that a primitive shape is more
efficient, then move it down to the C level for efficiency purposes.
But keep the ability for the SDL to define new shapes, new textures, new
light sources, etc.  Some of the lesser used ones may even stay at the
SDL level.
There are ways to do this nicely. One important aspect is to try things,
measure the performance, and optimize accordingly.  You'd be surprised
at how many things you think are bottlenecks really aren't.
BTW, I implemented a quick raytracer in Smalltalk and rendered a simple
scene only 5 times slower than POVRay (and I didn't work too hard at
optimizing it).
David
Date: 29 Jan 2008 11:29:53
Message: <479f5481@news.povray.org>
> in the SDL.
  It is, using an isosurface or a poly object.
> light sources, etc.
  A shader language is one of the ideas for pov4. It's not mutually
exclusive with existing textures.
  It's relatively easy to make a raytracer in any language which renders
a *simple* scene in a comparable time. However, put for example 100000
spheres in that scene and them compare. ;)
Date: 29 Jan 2008 12:00:00
Message: <web.479f5af26a92b4f494e61a50@news.povray.org>
> SDL level.
That seems like the best of both worlds people for people who want better ways
to define custom objects in the SDL, versuses people who would rather use
primitive to maintain render efficiency. It would be awesome if both were
included!
Just be sure to keep the SDL simpler than C or C++; One of the main reasons
POVRay is so attractive to people (myself included) is its simplicity in use
compared to those other cumbersome programming languages.
-Woody
Date: 29 Jan 2008 12:15:01
Message: <web.479f5eee6a92b4f494e61a50@news.povray.org>
And other raytracers with scripting capability. Anim8or uses a scripting
language suspiciously like C/C++. (Possibly making it easier to parse, but
can't say).
-Woody
Date: 29 Jan 2008 12:20:00
Message: <web.479f5f1b6a92b4f4c150d4c10@news.povray.org>
> > SDL level.
> included!
> -Woody
I do like the idea of having two levels of SDL.  While the predifined stuff is
what I use mostly, lately I've been mucking about with the user defined camera
in megaPOV to achieve cameras that I can't otherwise.  I do think there would
be some advantage to other user-definable properties as well.
-tgq
