POV-Ray : Newsgroups : povray.pov4.discussion.general : Metadata : Re: Metadata Server Time
16 Mar 2026 16:08:40 EDT (-0400)
  Re: Metadata
Date: 14 Apr 2025 10:40:00
Message: <web.67fd1d1ca47621ffd5cc4ae625979125@news.povray.org>
"ingo" <nomail@nomail> wrote:
> Regarding state, maybe stop using the command line switches and start using the
> ini-file for it. That can be added in the DB / history.
I get all discombobulated with .ini files and .inc files.  I always start trying
to render the wrong file when I'm working on things.
I also need some sort of workflow roadmap that's laid out by people who already
use such tools, as I've been system-hopping due to HDD crashes and laptop
catastrophes - so I haven't ever had enough time to learn much command line fu,
or familiarize myself with the tools that are available.
So when I want to get something done, I want to stay "heads-up" and hammer out
the project, not be stuck "heads-down" trying install packages, learn
command-line tools, or basically sort out all of that low-level stuff.
It is, unfortunately, a self-reinforcing cycle.
> But with all that, I would still like some way to put user defined metadata from
> the scene file in the image.
https://news.povray.org/povray.windows/thread/%3Cweb.56d3b273af51b1d05e7df57c0%40news.povray.org%3E/?ttop=444751
Looks like you can use a post-render shell command to somehow insert the data
into the graphic file?
IIRC, there was a thread where I discussed using a shell command to overlay text
onto rendered frames . . .  it was a while ago.
- BW
