POV-Ray : Newsgroups : povray.pov4.discussion.general : Curly braces replaced by indentations but only as an option ? : Re: Curly braces replaced by indentations but only as an option ? Server Time
18 Mar 2026 08:56:54 EDT (-0400)
Date: 3 Apr 2025 12:00:00
Message: <web.67eeaf567e3c5a99f671c51e6830a892@news.povray.org>
> > I don't know enough to have an opinion about using a database oriented POV
> > workflow, which does sound very powerful, but I did have a look at the  overview
> > descriptions of the nim language, and though there are some aspects that I don't
> > naturally enjoy in its syntax, they probably are specifically the ones that
> > every one around here seem to be asking for, also the fact that it can be
> > interpreted and compiled... Well, wouldn't this make it suited to be a scene
> > description language that could get accelerated as a compiled version just
> > before parsing?
> Using Nim and a library nimscripter I made a simple image renderer, the way you
> suggested here. Most of the rendering procedures are compiled and are made
> available to the VM so they run at "max" speed. Math functions already run at
> max speed in the VM. This all is then available in the scripting language.
> In my little app you can create patterns from math functions and render those.
> You can add POV style like turbulence and gray scale mapping, instead of our
> color_map.
> You compile the render engine and then render the .nims scripts with it. Just
> like POV-Ray renders SDL, but without the need for writing a parser etc.
> It does work, but it is not a smooth path yet. Not every thing is possible
> (yet?) with this way of creating an app.
> https://gist.github.com/ingoogni/8e1f74f8ea7250da778a202648e96e9b
> the script for the image:
> import math
> proc sincos(x, y: float): float =
>   return (1 + (sin(x) * cos(y))) * 0.5
> proc main() =
>   var img = initPGM("sincos.pgm")
>   img.gamma = srgb
>   let
>     gm = Pattern(
>       funk: sincos,
>       greymap: @[(0.0,0.0),(0.5,0.2),(0.8,0.7),(1.0,0.0)],
>       turbulence: (
>         strength: (x: 1.6, y: 2.2),
>         lambda: 2.5,
>         omega: 0.7,
>         octaves: 6
>     width = 640
>     height = 480
>     viewportWidth = 30.0
>     viewportHeight = 0.0
>     #viewportHeight = viewportWidth * (height / width)  # Maintain aspect ratio
>     grid = gm.render(width, height, viewportWidth, viewportHeight)
>   img.writePGM(grid)
> when isMainModule:
>   main()
The fact that it does work is already a huge achievement ! Ignoring the syntax I
wonder, did you create the previous routines in POV originally? and if so, do
you think there could be a way to compare fairly render times? Should rather
only the parse to render ratio be considered ? with your approach, would
separate builds have to be made afresh for every scene? About the nim script
language, though it is said to have some removed functionality, is it still
"Turing complete" ? ...Meaning, as much as POV/INC sdl?
