POV-Ray : Newsgroups : povray.pov4.discussion.general : Suggest v4.0 f_kappa_2d() function. (yuqk R19 v0.6.13.0) : Re: Suggest v4.0 f_kappa_2d() function. (yuqk R19 v0.6.13.0) Server Time
15 Mar 2026 03:05:03 EDT (-0400)
Date: 23 Feb 2025 09:10:00
Message: <web.67bb2b99a6f11ac71f9dae3025979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> This a general helper function / technique to match any two curves at
> their endpoints given you have the means to calculate the first and
> second derivatives for both curves being glued together at (t).
Are f' and f" arguments to the function?
> The function will calculate and return 'k(t)' or the 'radius of
> curvature' (1.0/k(t)).
> Attaching images showing on the left k(t), and on the right the 'radius
> of curvature' at t, as the length of the normal vectors for a
> f_bezier_2d_cubic() curve.
That's pretty slick.
(If you add f'", then you can match RATE of curvature, so that reflections are
smooth as well.)
Do you plug f_bezier_2d_cubic() into your function and it calculates the
derivatives?  Can you plug in, say, Perlin Noise, and have that work?
You've been busy!  :)
- BW
