POV-Ray : Newsgroups : povray.pov4.discussion.general : On new directive to stop after parsing. A near term trick. : Re: On new directive to stop after parsing. A near term trick. Server Time
27 Mar 2026 17:19:35 EDT (-0400)
Date: 29 Mar 2024 13:10:00
Message: <web.6606f514ca6c83fa1686e436cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> This also works in my yuqk fork, though I doubt whether it will work for
> official POV-Ray releases. Pretending the following is all on one line:
> yuqk boom.pov fatal_error_command="echo \"Scene: <%s>
> fatal_error_command. RC: <$?>\""
> It uses the fatal_error_command facility of POV-Ray itself. The output
> looks like:
> ==== [Parsing...] ==================================================
> File 'boom.pov' line 2:
> Parse Error:
> Parse halted by #error directive: Boom
> Fatal error in parser: Cannot parse input.
> Scene: <boom> fatal_error_command. RC: <0>
> Render failed
> However! The return code (RC) reported by the 'fatal command' is not for
> the current running POV-Ray executable, but for the command previously
> run from the terminal, which is currently running the POV-Ray executable.
can you use BE's "to file" idea ?  ie write the exit / status code as last line
when 'all_file=true', perhaps.
regards, jr.
