POV-Ray : Newsgroups : povray.pov4.discussion.general : Conditional Directives within the inifile : Conditional Directives within the inifile Server Time
19 Mar 2026 08:44:18 EDT (-0400)
Date: 2 Jun 2011 20:35:01
Message: <web.4de82b4da1aea573a3bfeb720@news.povray.org>
I've done some animation for the election-day on my little island, using PovRay.
To set-up the project was a little to complex for the ini-files.
It would be a very cool thing, heaving conditional directives within the
ini-files, like:
Antialias=Off
Input_File_Name=election.pov
Initial_Frame=1
Final_Frame=23
Display_Gamma=2.0
Width=1440
Height=115
Declare=FileToImport=2
#switch (FileToImport)
  #case (1)
   Output_File_Name=Canditates-01-a
   Declare=GlobalDivider=20
   Declare=FramesAtTheEnd=250
  #break
  #case (2)
   Output_File_Name=;02 = Canditates-01-b
   Declare=GlobalDivider=25
  #break
In this case, I would only need to edit the "Declare=FileToImport=..." entry and
everything else is done automatically.
I had more then 17 different files to import and all with different conditions
ahead...
The result can be watched here:
http://www.youtube.com/watch?v=SQcsNXEpTRQ
After rendering, I've used Avisynth for the quick-compositing. The rendering
took just a view seconds, it was "almost realtime" ;) but the fiddling with the
inifile took unnecessary long time.
Best rgds,
Holger
