POV-Ray : Newsgroups : povray.pov4.discussion.general : Scale Postfixes : Re: Scale Postfixes Server Time
9 Apr 2026 11:21:27 EDT (-0400)
  Re: Scale Postfixes
Date: 3 Aug 2009 16:05:00
Message: <web.4a7741e8fd0f4b01a107abcd0@news.povray.org>
"Reactor" <rea### [at] hotmailcom> wrote:
> It isn't immediately clear to me why you couldn't implement units like that on
> your own.  One of the thinks that makes pov powerful is the fact that you can.
> Consider something like this:
(1) I would want to eliminate the need for the "*" operator (being lazy), and
the #declare intro needed (at least for the most common dimensions).
(2) Though of course your approach is perfectly possible, it doesn't come with a
standard framework; for instance, someone may use "m" while someone else may use
"meter" (or "metre" :P).
(3) Having a standard framework for distances would also allow to interoperate
with features inherently dependent on actual physical distance (like the
experimental Subsurface Light Transport code).
> #declare MyVar = 1.5;
> sphere{ Pos, 1.5ft }   // ok, fine
> sphere{ Pos, MyVarft } // wait, the value of MyVar used in feet, or MyVarft?
Definitely MyVarft of course. Can't be implemented any different, and I guess it
wouldn't be difficult to explain this to users.
