POV-Ray : Newsgroups : povray.pov4.discussion.general : Possible solution for camera conundrum : Re: Possible solution for camera conundrum Server Time
21 Mar 2026 22:44:56 EDT (-0400)
Date: 6 Jun 2009 08:30:01
Message: <web.4a2a60aac526c1d1f708085d0@news.povray.org>
Chambers <Ben### [at] gmailcom_no_underscores> wrote:
> clipka wrote:
> This is the proper way to change the image... by changing the source!
> You should NOT change the image by specifying render options on the
> command line.
Says who? And why?
Don't start again with that "scene author's decision" argument, because that
would be a circular one in this case.
Render options are *THE* thing to use to adapt the scene to certain image output
constraints. Like file formats. Or pixel aspect ratios. Or media aspect ratios,
for that matter.
You should NOT change the scene to fit it to some particular, media-dependent
output constraints.
